Question about Gateway MX3228 Notebook
Cooling fan doesn't seem to be working
Is there any way to test the cooling fan on a Gateway MX6027 laptop?
    Problem Solver:
  • 9 Answers
If you have a volt meter you can see if the computer is putting out power to the fan, also you should
be able to test the fan on an external power supply, if you dont know the fans voltage start off at 5vdc
, most fans are 5 to 12 volts. Hope this helps
Posted on Dec 22, 2008
Gateway ma2 mx6027 not turning on help?
Find another charger and try again! You may have a dead battery and can't get the unit to work because the charge is bad.
Nov 25, 2013 | Gateway MA2 MX6025, MX6027, MX6028 Laptop...
Gateway laptop won't come on
Here below are possible causes and troubleshooting steps of laptop that can't power on, hope it may help:
Possible causes:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solutions:
1. Test the AC adapter with a digital multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
2.It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one. Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Nov 04, 2012 | Gateway MX6027 PC Notebook
What is the maximum memory capacity for the MX6027 model ?
Hello Marc,
The maximum is 1 GB. Standard, it comes installed with 256 MB but you upgrade with additional 256 MB or 512 MB memory modules. The modules you are looking for are:
256 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
512 MB DDR (1 x 256 MB) SODIMM (PC2700) 2.5v SYNC
There are lots of places on the web to find decent prices for this memory. I have included a few below.
http://www.memorystock.com/memory/GatewayMX6027.html
http://www.pcmemorystore.com/Gateway-M_Series_Notebooks-MX6027-ram.htm
http://www.computermemoryoutlet.com/Gateway-M_Series_Notebooks-MX6030-memory.htm
This document includes instructions for replacing the memory. It's a simple straightforward process.
http://support.gateway.com/s/Mobile/Q106/Blade/8511418.pdf
Hope this helps.
Have a blessed day.
Thanks for using FixYa
Jul 29, 2011 | Gateway MX6027 Notebook
I INSTALLED 2X512,COMP WON'T BOOT,INSTALLED 1X256 & 1X512 AND IT WORKS FINE.GATEWAY MX6027 SUPORTS 1 G.
If the single memory modules you installed worked in the same slot, then the second slot might either be defective or need to be cleaned.
Feb 19, 2011 | Gateway MX6027 Notebook
I am trying to reload my computer and about 10 minutes into the recovery process it shuts down. I have replace the fan, the hard drive, the battery, the keyboard, the power cord, and memory. Why does it...
90% of the time shutdowns are related to heat problems in the CPU or GPU (Video). The laptop will shutdown to avoid damage. Verify the cooling fins on your heat sink are not clogged as an external cooling fan will not correct this problem. If the fan is running test with a strip of tissue or candle and verify you have air circulation.
If you are certain temperature is not an issue, the next step is to insure you are not having hardware related errors.
You should always start with a completely charged battery and also have your adapter plugged connected.
Finally be sure you are using the original recovery software (incorrect licensing will abort the recovery process).
Feb 17, 2011 | Gateway MX6027 Notebook
Gateway MX6027 I cannot get my WiFi turned on How do I do it?
Gateway Laptop ---- Switch on side and then Fn / F2
Feb 27, 2010 | Gateway MX6027 PC Notebook
I have Gateway MX6027 laptop. My ac adapter get real hot. i went through 2 chargers in the last 2 months. I am wondering if I got a short on the motherboard, or maybe if there is a voltage regulator that...
Does the AC adapter get hot if you use it to power the notebook with the main battery removed? If not, the battery or internal charging board may be faulty/
Mar 03, 2009 | Gateway MX6027 PC Notebook
RAM UP GRADES
it's usually located under a small cover at the bottom of your laptop or under the keyboard... one of my laptops has both
Feb 23, 2009 | Gateway MX6027 Notebook
Gateway Notebook MX6027 - Dim Screen
Sorry to say the monitor is poked try to use a external monitor because theyre not cheap to replace. These guys are good and most likely tell you the same!!!
Oct 02, 2007 | Gateway MX6920 Notebook
Computers & Internet Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
