Question about GE 21095GE2 Cordless Phone
Keypad is fading
Hey everybody, I'm having the same problem with this GE phone I eventually had with my previous cordless: some of the numbers are becoming unresponsive, requiring super-heavy pressure to get a response. It's only on the handset, not the base (but of course that's where all the heavy usage has been). I actually tried to take apart the handset to scope things out, but somehow couldn't quite get it apart. It's like there was an invisible screw somewhere. I sure hope this is something I could actually fix myself, since it seems to be a mechanical wear-and-tear thing, not a microchip, high-tech thing. Thanks! adam
  • Adam Abrams
    Adam Abrams Apr 21, 2007
    Thanks so much lolohayma, I'll give your procedure a try!
  • Adam Abrams
    Adam Abrams May 07, 2007
    One question, lolohayma, can I use rubbing alcohol, or lighter fluid for a cigarette lighter perhaps? I don't relish having to buy a big canister of barbeque lighter fluid just to use a tiny amount...
Thanks! Worked for me!
Posted on Oct 06, 2008
Yes, that will work just as good.
Posted on Oct 31, 2007
    Problem Solver:
  • 5 Answers
The Problem is caused by a build up of a grease like substance between the conductive rubber on the key pad and the circuit board. To solve the problem you will have to take the handset apart. To do so remove the two screws in the battery area. Then using a knife that has thin blade separate the face of the phone from the back cover. Once that is done remove the screw that hold the chassis to the front of the phone. Lift the chasses from the front taking care not to break the wire going to the speaker. Take the Pad out. Clean off any residue on the chasses of with some charcoal lighter fluid applied on a piece of soft cloth and wash the pad of with soap and water using a tooth brush to ensure that you get all the grease of. The Pad is very fragile so take care not to apply too much pressure and tear it. Dry it of properly before re applying. I use charcoal lighter fluid on a piece of soft cloth to clean of any remaining residue on the pad. This will take some of the rubber but it is then able to make contact with the circuit board. Before closing up the handset reconnect your battery apply the pad to the circuit and check the pad to see if you still have the problem with any of the buttons. If you do clean the button again with the charcoal lighter fluid. This will solve your problem
Posted on Apr 21, 2007
SOURCE:
How to unblock previous blocked numbers
Step 1 Press the "Menu" button followed by the "#" key on the handheld unit.
Step 2 Enter "217" on the numeric keypad to access the blocked numbers menu.
Step 3 Press the down arrow on the keypad. Scroll through the list to select the number you wish to unblock.
Step 4 Press the key under "Erase" to remove the phone number from the list.
Step 5 Select "Yes" to confirm your selection.
Nov 12, 2015 | Panasonic KX TGA641 Cordless Phone
Cordless phone GE model 2-9635 Instructions to program speed dial
After a lot of research, I have found that GE has handed the phones and their manuals down to a company called "ThomsonTM" And if you come across any of problems for this phone in the future, I'll give you their phone number so you can still get help, at: 1-800-447-1700
Otherwise for help right now for the speed dial issue, I could only find directions that were of general use of multiple GE Cordless Phones, so it's worth a shot if you've got the time, otherwise, I suggest calling the number above.
Here is goes:
1.)Raise the phones reciever, or push the "Power/On" button.
2.)Press the "Store" button.
3.)Press the number 0 through 9 or a quick dial letter A, B, C,... to assign, then press the "Store" Button again to confirm the entry.
4.)Enter the number you want to assign the speed dials memory location, and press "Store".
5.)If your GE Phone prompts you to enter a Contact Name, use the keypad to enter it. Press the "Skip" button to enter a space, and the "Store" button to confirm your entry once again.
Once again, this is just a generalized GE Cordless phone guide, and may not be exact to your phone, in which I further suggest calling the electronic product's helpline by
ThomsonTM at:
1-800-447-1700 begin_of_the_skype_highlighting
Hope this helps!
Remember to give me 4 Thumbs Up
for all the hard work to the Community! :D
~~Dayminner
Jun 06, 2011 | GE 27928GE5 Cordless Phone
Move residences, previous phone number has voice message. need to program with current phone number and name
Since you declined to name the model of your GE system, I can only direct you to select it from this list to download the manual.
Mar 03, 2011 | Uniden Cordless Phone
ID fading unable to see number or letters, can this problem be solved?
Try putting new batteries in the handset. Many phones will dim their displays when the batteries start to run low in order to save power.
Hope that helps!
Jul 10, 2010 | GE 25952EE1 Cordless Phone
I have three handsets and two of the phones caller id is not show
yes if its fading out .its possible that the battery is causing this.also other possibility is that the internal cicuit of the device is moistened or may be needs to be resoldered as some connections may be loosened up too. its a common problem and will get fixed once above things are checked 1 by 1. thanks.
Jul 08, 2009 | Uniden Cordless Phone
Caller id display screen
I can't read my caller Id Screen numbers are disappering
Jul 27, 2008 | GE 25951EE2 Phone
MY GE 5.8 GHZ phone
fading as you watch
or less bright than yesterday
if the latter there are screen contrast adjustments in your menu system that allow you to bring it back,
Jul 17, 2008 | Uniden Cordless Phone
How to turn off the keypad beep
For the 6.0 gig phones, the manual explains in the handset set-up how to turn the keypad beep on and off. I rather like it as it serves as an audible indicator that the key was hit. Otherwise it is possible to have missed a digit. Of course, you can see the number on the display, but who looks?
Dec 04, 2007 | GE 25932 Cordless Phone
Programming instructions for used phone
Program Thomson Consumer Electronics (GE?) 2-9316A Speaker Phone (what we found works)
To program:
1. press speaker or lift handset.
2. press STORE
3. dial the number to be stored
4. press MEMORY DIAL
5. press location (0-9 on keypad or 1 of the 3 emergency quick dial)
6. press speaker or hangup.
To dial emergency numbers:
2. press any of 3 emergency quick dial
To dial stored numbers:
2. press MEMORY DIAL
3. press location (0-9 on keypad)
Does anyone know how to add PAUSE in a stored dial string?
Aug 27, 2007 | GE Corded Speakerphone with 2 Cordless...
GE 21095GE2 Cordless Phone Logo
222 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Marvin
Marvin
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
