Question about InstallShield 11 Professional Edition
Modify Web.config file at Run time
We are going to buy Installshield 2009 Professional. Now We are doing a research before buying it.
We are using a evaluation version of Installshield 2009 Professional. I need to update Web.config file according to the selected Database server , user and password at Run time. So please advice me how to do this.
Many Thanks
2 Suggested Answers
SOURCE: Modify Web.config file at Run time
Hello all,
Below is a nice link which talk exactly what you want
http://aspdotnethacker.blogspot.com/2010/05/modify-webconfig-file-at-runtime.html
Posted on May 14, 2010
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
Hi I am getting windows installer error 1721 when running install
I have had many installation errors through the years. Seems some cd or dvd players work better than others for this, I don't know why. So when I run into this, I usually use an external DVD player to do the setup. you should be able to do this through the BIOS.
Nov 28, 2017 | InstallShield 11 Professional Edition
Error 1607 unable to install InstallShield
how you fix it
Reinstall the InstallScript engine loadTOCNode(2, 'resolution'); To reinstall the InstallScript engine from InstallShield Developer, follow these steps:
  1. Download the ISScript7.zip file. To do this, visit the following InstallShield Web site: http://consumer.installshield.com/kb.asp?id=Q108322 (http://consumer.installshield.com/kb.asp?id=Q108322)
  2. Extract the ISScript7.zip file.
  3. Double-click the ISScript.msi file.
Running Setup from a virtual drive loadTOCNode(2, 'resolution'); If you are running the Setup program from a virtual drive created by using the SUBST command, you can delete the virtual drive and instead run the Setup program from the physical hard disk. To delete the virtual drive, click Start, click Run, type subst drive_letter: /d, and then click OK.
good luck
Mel
Jun 05, 2010 | Microsoft Windows Vista Home Basic for PC
I just installed windows XP service pack 3, installshield errors
Hi, "I hope this will help you out with the problem! Try this Link: http://www.technospot.net/blogs/download-directx-10-for-windows-xp-from-alky-project/ "If this help? Feedback is appreciated, thanks paul7of9."
Feb 04, 2010 | InstallShield Update Service Version 3
Pop up saying you have a virus, i try to go online, or into properties and it keep saying, wmiadap.exe is infected. It always pop up to buy antivirus software.
It seems as if you have downloaded a spyware program such as a wallpaper which has caused you to have a fake antivirus 2009 running. Make an Ultimate Boot CD and run every AV tool and spyware/malware that was on the CD. After running all the tools install your XP SP2 CD to repair the installation Download and run hijack this to see if still have the virus lurking on the computer.
Jan 17, 2010 | Microsoft Windows XP Professional
http://www.west-wind.com/Weblog/posts/5688.aspx ~This sets the basic idea in motion. Regards Gewiz
May 28, 2009 | InstallShield 11 Professional Edition
Audio video occasional freezing on p5gc-mx/1333
ok now u say that u have 2 hard drives ok then pls check the cable and port and jumper config see which drive is slave and which is master may be jumper config is giving problems , i think ur maxtor drive is not too old it is 160GIG but u never know if the internal health is not good one way or the other ur drive is the main culprit if files run OK on other HDD then u know what to do
pls Defrag ur faulty drive once thru windows and see if it helps this also happens when files are fragmented and drive head has to move alot for reading pls try it first b4 buying a new drive
pls let me know abt these things
check cables
Check Jumper config on the drive back side
check which port they are both attached
pls rate me FIXYA when ur problem solves
Mar 17, 2009 | ASUS P5GC-MX/1333 Motherboard
When I put the disk in for Panda Internet security 2009, after I hit 'allow' and it first starts, "Lanzador Instaladores has stopped working" comes up, and a box that lets me try Windows to try to fix it,...
This is a problem with flash on your computer which is what is crashing when the CD is auto ran. To work around this you need to leave the CD in the tray after you get this error and go to My Computer and look for the CDrom there and right click on it and select explore. While exploring the CD you will want to look for the folder that is the name of the version of Panda you have. Inside this folder there will be a SETUP file which you could run from.
If the above is unable to be done, you may download your version of the software from the below link
Panda Internet Security 2009
http://support.us.pandasecurity.com/retail/Products/PIS09.exe
Hope this helps
Ernie
Panda Support
Mar 16, 2009 | Panda Internet Security 2009 - 3 User for...
Installshield 3 Help (maybe)
I didn't get a solution but the project was dropped. I don't have to do this install.
Sep 19, 2008 | InstallShield Update Service Version 3
Camera wont download the photos.
http://digiblue.com/customer-service/downloads/drivers/SQ905C_DSC_Drive_XP_Vista_DigitalBlue_V2.005_2007MAY24.exe
if you are using windows vista use the following above link to download the new driver.
1) Please install the Disney Pix 2 software and the Disney Pix Micro Downloader to your computer via the software CD that came with the Disney Pix Micro
2) Please double-click on the "Setup" to begin the install of the Pix Micro drivers. The User Account Control will appear warning you that a program is trying to run. Please click "Allow".
3) Complete the install of the driver by following the prompts.
4) After the install completes, you are prompted to restart the computer. Please select "Restart now" and then click "Finish".
5) You can now delete the Setup program from your computer
6) Connect your Disney Pix Micro to the computer and wait for the device to install.
7) Double-Click on the Downloader shortcut to open the downloader
Now the Pix Micro Downloader is open with the correct privileges and the Pix Micro camera is connected. If you click the "Download" button. A dialog box appears saying "Pixel Up".
Please click the "OK" button and the download will complete successfully. The images can even be deleted via the downloader after the images are downloaded. Although, every time you open the downloader, you must run it as an administrator and every time you download, the "Pixel Up" box will appear.
If you are having a problem installing a product that uses InstallShield as their installation tool, and the steps below do not resolve your issue, you will need to contact the vendor of the software, as we cannot provide further support. Your vendor, who used InstallShield as an installation tool, created the product that you are trying to install. It is very likely that the error you are getting is related to how the vendor used our product and only the vendor would know which InstallShield product they used, which version and how they programmed it. Thank you for your understanding and patience.
This article applies to the following errors when trying to install an application that uses InstallShield:
Error extracting support files
Error installing Ikernel.exe (0x any number)
Access is denied
Error loading Type Library/DLL
Discussion
Detect Version
Different troubleshooting steps are necessary for different version of InstallShield. To check the version of InstallShield Professional that was used to create the setup, take the following steps:
1.Right-click on the setup.exe
2.Select "Properties".
3.In the Properties dialog, select the tab labeled "Version".
4.Near the top there will be a filed labeled "File Version". The number specified here will tell you approximately what version of InstallShield was used to create this install.
InstallShield 5.x and 3.x
If the version of InstallShield is less than 6.00, see article Q100198, HOWTO: Eliminating General Setup Initialization Errors.
InstallShield 6.x
If the version is 6.00 or greater, continue with the following steps.
Setup initialization errors can be caused by a number of factors. This is a non-exhaustive list of possible resolutions:
1.Insufficient permissions on the machine. If you are using a Windows NT or a Windows 2000 machine, you need to have administrative permissions to run an InstallShield Professional 6.x setup. Make sure you have the correct permissions.
2.If you just ran an InstallShield setup, the engine takes a few seconds at the end of the installation to clean up. During this time Ikernel.exe (the engine file) is running in memory from a previous process. That is why you are not allowed to launch another setup. Waiting a few seconds and running the setup again should resolve this.
3.Check and make sure Ikernel.exe is not in memory. If it is, and no setup is running at the time, end that task and restart the system.
4.Clean out the Temp directory.
5.Delete the Program Files\Common Files\InstallShield\Engine folder and then rerun the setup.
6.Reinstalling Internet Explorer (IE) 5.x can also repair a number of corrupted/missing core Windows files from your machine, so reinstalling IE 5.x and the NT service pack is also suggested.
7.Another possibility is that you do not have sufficient COM permissions. For information on how to troubleshoot this, see article Q104986, INFO: Initialization Error Troubleshooting.
8.The other potential cause is a missing Stdole.tlb file. This is a core Windows file and should exist on your machine. Make sure that if you get this file from another machine, the machine is running the same operation system as the machine you are trying to run the setup on.
9.If you are trying to install to a Windows 98 machine, download and run Dcom98.exe from the following site: http://www.microsoft.com/com/dcom/dcom98/download.asp.
10.Make sure that you are using the latest version of the InstallShield engine. To install the latest engine see article Q105097, INFO: Install the Latest Version of Ikernel.exe
Aug 01, 2008 | Disney Pix Micro Digital Camera
Computers & Internet Logo
117 people viewed this question
Top InstallShield Computers & Internet Experts
Rob Hill
Rob Hill
Alexey Krenvalk
Alexey Krenvalk
Jon Slaton
Jon Slaton
Are you an InstallShield Computer and Internet Expert? Answer questions, earn points and help others
