Question about LG LMV1925 Microwave Oven
LG light bulbs
Both of my microwave over range bulbs burnt out. We took them out and one rolled of the counter and broke. The other one, which I thought was safely wrapped up in my purse, also broke. I have no idea what type of bulbs they were but I do know the microwave brand. I have been searching for the right bulb for over a year. Can you help?
  • 5,911 Answers
The part number you need is 6912W1Z004B. You can this part at repairclinic.com for about $4 each. I hope this helps you.
Posted on Dec 22, 2008
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
How to change the light bulb
What kind of microwave oven is this? A counter-top model or an over-the-range microwave? Do you have a brand and model number? And which light bulb do you want to replace - the cavity light bulb, or the bottom light(s) of an OTR microwave?
Oct 19, 2014 | Microwave Ovens
Do the lighbulbs underneath the microwave screw in or pull out- in the process of trying to change the burnt out bulb- i broke the bulb off of the base.
Most moderately new microwaves have a two prong pin type connector that is simply pushed strait in and pulled strait out. I presume the you tried turning it out when it broke?
Oct 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a light bulb that broke and I cant get it out, does it push in or screw in?
Chances are it is a boyonet base bulb. Unplug or turn off the power to the microwave. To remove the bulb, press in lightly, turn the base of the bulb counter-clockwise about 20 degrees till it stops, then it should pull straight out.
May 08, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace bulb in #3501 Westinghouse Microwave
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Dec 23, 2008 | Westinghouse WST3501 Microwave Oven
How to change microwave bulb
Nov 25, 2008 | GE JVM1650 1000 Watts Microwave Oven
Replacement light bulb for GE spacemaker microwave
That model number doesn't look quite right, but nevertheless:
If there's no obvious removable cover over the bulb (and the owner's manual doesn't address it) some disassembly may be required.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
Sep 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Light in sharp carosel went out. do i replace light [how] or replace microwave?
On a counter top model, you'll have to remove the outer cover.
The screws you need to remove should be pretty obvious, and a special driver (such as a T20H Torx type or GTXH20-100) may be needed.
You can find helpful exploded view diagrams and for many brands by entering your full model number here: http://www.searspartsdirect.com
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed behind there.
Once your over the range type is out of the wall, or if yours is a counter top model, the outer cover (wrapper) will need to be removed.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 04, 2008 | Microwave Ovens
Burnt bulb in kitchenaid microwave
You may have to remove a panel on the bottom or remove the grille across the top.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. Other models are similar. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
In some over-the-range models, that can mean having to take the oven down from the wall! For safety's sake, that should be a two-person job and it's really helpful if you have your original installation instructions to do this.
Many models use halogen lamps. You must not touch the new one with your bare skin as the oils will shorten the bulb life.
Apr 24, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
LG LMV1925 Microwave Oven Logo
429 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
