Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
Honeywell Chronotherm III Thermostat does not show temperature
We have a Honeywell Chronotherm III thermostat. The time and the temperature is not showing on the display. I do believe the batteries are working because the display is still showing some of the settings. None of the buttons respond to reset the time. The fan does will blow in the on position. I switched the thermostat with another one in the house, and it appears that the problem is just with this particular unit. Any tips?
  • 10 Answers
SOURCE: -AC appears in the display of chronotherm III
I have had the same problem- twice. It was a similar but different problem each time. The -AC means the ac control voltage isnt making it to the thermostat. In my case both times it was a switch in the control circuit that wasn't closing properly. The easiest was the front cover switch. If the front cover is removed from the furnace or has vibrated loose, the switch will open, preventing the furnace from running. The other instance I ran into was a flow switch on the exhaust blower which ensures the there is flow OUT the chimney. The switch wasn't functioning, so the furnace wouldn't start. The blower would come on for a short time, but the burners wouldn't light.
Hope this helps,
Posted on Dec 12, 2008
  • 252 Answers
SOURCE: I have an old Honeywell thermostat (Chronotherm
you are not geting AC power from the furnace
Posted on Sep 27, 2009
  • 588 Answers
SOURCE: Thermostat does not read current settings or respond to commands.
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
Posted on Oct 11, 2009
roniecon
  • 6927 Answers
SOURCE: What does -AC mean on a Honeywell programmable
If it is just a heater,it means no power.
Posted on Nov 08, 2009
  • 308 Answers
SOURCE: my honeywell chronotherm III says -AC any ideas
The problem is your 24v power source. I am unsure as to why you put "other than power source or batteries". If you did indeed check that your thermostat is receiving 24v, then I would say that you have a bad thermostat. Hope this helps
Posted on Jan 23, 2010
Display shows LLL
PDF]Chronotherm III 7 Day Programmable Thermostat - Honeywell
https://customer.honeywell.com/resources/techlit/.../69.../69-0352.pdf
O I" O 0. HEAT M10 COOL OF ow to operateyo. This Owner's Guide will show you how to get the most benefit from your new thermostat. Your new Honeywell ...
Sep 13, 2015 | Cars & Trucks
Honeywell Chronotherm III Thermostat shows time of day-AC. No heat in the 2 zones with this message.
Hello,Message AC means that there is no 24volt power to the thermostat from the unit/s it controls.Please check all switches & curcit breakers to the unit/s as there is no low voltage power to the thremostat from the transformer in the unit/s.Maybe got turned off by mistake.
Nov 01, 2010 | Honeywell Electronic Programmable...
Honeywell Chronotherm III Lowest temperature setting is 45F Any way of getting it lower thanks
If you are successful in setting it lower , you will end up with frozen pipes and large plumbing bills. Since the internal walls of a building can be as much as 20 degrees lower, that the room.
And the location of the thermostat, may be even warmer, that that of the areas where the plumbing is.
Now what is your reason for wanting the thermostat operate at a lower temperature?
Jan 31, 2010 | Honeywell Heating & Cooling
My honeywell chronotherm III says -AC any ideas
Jan 22, 2010 | Heating & Cooling
HONEYWELL WEBSITE:
Go to honeywell.com
Oct 08, 2009 | Honeywell Power Humidifier: Furnace...
I have a honeywell III chronotherm thermostat /It won't turn on the heat or the air conditioning when turned to those settings, but it sometimes will when turned to "auto". The batteries seem fine, no...
it sounds like it is time to repalce the stat, auto is set to allow the fan to run only when the heat or a/c is on, the switch for heat and cool will select either, and the temperature lever should allow contact for the bulbs to bring on the desired component. there are no replaceable parts on a thermostat, or I would try to walk you through replaceing them. good luck.. I prefer the honeywell vision pro or the white rodgers 9500 series stats
Jul 11, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
905 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
