Question about Hoover Washing Machines
Bits of dirt ( gunky stuff) coming from water outlet
Dirt chunks,and gunky water after each cycle has been completed.
Always lots of fluff on the clothes and dirt through clothes at times from I assume the dirt gunk
The washing machine is a, Hoover Boss 7.00kg, model No 2305L
do these have a filter somewhere that perhaps needs cleaning, and if so where can they be found ?.
Many thanks for any info you can supply us with.
Cheers Julie Spencer
  • 15 Answers
SOURCE: LG WFT851 - Flakes of dirt problem
try putting some milton or baby bleach into the machine with the hottest possible wash with no clothes with the highest water level
Posted on Jul 19, 2007
Bob Gemmell
  • 212 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
gittos73
  • 244 Answers
SOURCE: dirty washing
what this could be is your bearings check if there is any amount of movement from the drum by opening the door place your palm onto the front of the washer so its on the bodypart of the washer now place your fingers into the washer facing down so you can grab the drum with them now pull up and if there is any movement then its confirmed bearings need replacing m8 get the warranty company out its a big job some companys just replace the washer m8.It will be the bearings though what those black marks are is the grease out of the bearings cause the seal has gone ive done hundreds of bearing jobs let me know how u go on m8
Posted on Jan 24, 2008
  • 1294 Answers
SOURCE: hoover six express wdm130 1300 washer dryer
Click on your model number above, (below FIXYA) on this site, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
And dont forget to rate me on this great site.
Posted on Jan 26, 2008
SOURCE: Black stuff in washing machine
You need to clean the filter out (look in your machine - it's on the side of the tub) then run a wash with a cup of vinegar in it (or on soak with napisan or something like that in it). It's just gunk build up.
Posted on Feb 18, 2008
02661402000 kenmore washer wont get water out stops on rinse cycle
If the outlet water pump works, the most common solution for this type of problem is cleaning the filter which gets stuffed with dirt and bits and doesn't let enough water out. At that point the pump will stop as a self protective action. To clean the filter, take off the long rectangular cover on the bottom front of the machine (you shouldn't need to unscrew anything, it should just clip off). Then unscrew the filter BUT WATCH OUT, water will come out. Be prepared. Clean the filter, screw it back in and test it by starting the program you usually set it on. Hope it helps.
Aug 18, 2014 | Washing Machines
It is not picking up dirt
Was it picking up dirt before?
If so then perhaps the suction hose has a buildup of dirt/fluff somewhere along it. If a large piece of material went up the hose it often sticks and small bits gather around it to cause a complete blockage. Can you take the hose off and check? Or shine a torch down?
Dec 09, 2010 | Eureka Capture Upright Vacuum Vacuum
Dishwasher deposits dirt on dishes. Grit, small particles.
I have the same problem. We cleaned the dishwasher out because the grit was coming from the dishwasher...however, we still have dirt/grit in our dishes, but a lot less. How do we get rid of this all together?
Oct 03, 2010 | Maytag Dishwashers
My dishwasher washes and drains ok but there is always about 2-3 cups of water that remain in the dishwasher after the cycle is complete. This water never drains out.
If the dish washerr is kept at a tilt, then it is possible that the pump never gets a chance to pump out. Use a good spirit level to set this right. If nott Please open your washer, open the outlet and check for any dirt accumulation, check to the pump for low action if so replace, check for the outlet for clogging, clean if the pores are dirty. I think this must solve the issue. Good day
Jun 21, 2010 | Dishwashers
Hotpoint Aquarius WF740 My washing is coming out with dirty marks and bits of slimy dirt. I wonder if it is from the door seal as this is dirty or could it be something else? I used the persil gel filled...
Your pipe to the water pump exit is probably blocked with bits of old fluff or missing sock, i found that the clothes had slimy bits on mine, i tilted it up and removed the rubber water exit pipe from under neath, cleaned out all the rubbish and works a treat now.
Oct 19, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
My Bosch dishwasher is 8 years old and always worked well.. About a year or two ago the dishes started coming out dirtier than when they were put in, frequently encrusted with dirt and shredded dirt...
I do know this on most dishwashers water temp must be @ least 120 and not exced 150 degree`s before they will go into a complete wash cycle
Oct 07, 2009 | Dishwashers
Blowing the dirt out
This dirt or fluff is coming out of the blower area of the furnace. If you have a filter in the proper area then the debris you are describing may be from the insulation around the fan where it is located in the furnace. If these bits of debris has the apperance of black fluff then that is whats going on the insulation aroung the fan inside has come loose and is being picked up by the fan blowing it into your house. The way to repair this is to access the fan area of the furnace and remove the loose insulation. Remember to disconnect power to the furnace to ensure system does not turn on while you are removing the debris. Also remember that there will still be some debris coming out of the system for a while once you have corrected the problem due to the debris being in your duct work from the previous problem however it will slowly disapate.
Good Luck on your repairs
Dave
Sep 01, 2009 | LG LSC121PMA Split System Air Conditioner
Jan 28, 2008 | Washing Machines
Intermittent wash cycle
If there is a filter on this model, make sure it is clean, a lot of fluff and other stuff can accumulate in the filter preventing the water from draining fast enough. Sometimes the pump can get blocked with the same effect. Tom.
Feb 26, 2007 | Haier XQG50-QF80 Front Load Washer
Washing Machines Logo
Top Hoover Washing Machines Experts
shaun taylor
Hjalmer Lamminen
Hjalmer Lamminen
Steve F
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
