Question about Car Audio & Video
Pioneer deq 7600 display went black today the eq works fine.
  • r stimac Dec 26, 2008
    pioneer deq 7600 faceplate is hard wired to main board
  • 15,935 Answers
The faceplate contacts may need to be cleaned. remove the faceplate, and using an eraser, clean the metal tabs on the main unit and rear of the faceplate.
If this doesnt remedy the problem, service is required. May be the light unit in the faceplate.
Posted on Dec 22, 2008
  • blueextc3221
    blueextc3221 Dec 26, 2008
    I could have helped with a little clarification, as I was thinking of the 9600.
Pioneer deq-7600 lcd very dim, lcd problem?
The LCD display is failing, or the driver ic is the issue, or the B+ is to low causing the dimming effect, a resistor gone high in value would explain this.
Mar 19, 2012 | Pioneer Audio Players & Recorders
I have a Pioneer DEQ-7600 and every so often I have to tap my dash board in order for the display lights to come on the front of the unit, like it goes in and out every so often, thanks Nick
Nick i believe that you have a simple ground loop problem. To fix that you'll need to run a ground wire from your EQ to the body of the car. (the shorter the wire,the better the ground)
Find the ground wire (black wire) coming out of your EQ. Splice a wire into that wire,and then connect that wire to the black wire coming out of your Head Unit,and that should solve your problem.
Feb 11, 2011 | Pioneer DEQ-7600 15-Band Car Equalizer
My pioneer deq 7600 keep resetting it wont memory
do you have the yellow wire going to a constant power source??
Sep 24, 2010 | Pioneer DEQ-7600 15-Band Car Equalizer
I'm searching for a visual diagram to show the power hook up on the Pioneer DEQ 7600. I need a description of each wire and how to connect.
go to crutchfield.com and type in your model.on the right side of the screen it lists whats in the box.from there you can print a diagram.
Sep 06, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
Need wireing diagram for pioneer deq 7600 4pin plug
I need to see a diagram how or how to setup my equalizer and reverb to my amp all pioneers old stuff sg60 and sg540
Jun 28, 2009 | Pioneer EQ-6500 9-Band Car Equalizer
How to change the color display and brighten it up for a Pioneer deq-7600?
Here's a link to the manual in english...
http://akamaipix.crutchfield.com/Manuals/130/130DEQ7600.PDF
I read thru it, and no mention of how to do it. I do believe it can tho.
Jun 07, 2009 | Pioneer DEQ-7600 15-Band Car Equalizer
No graphic display
If blank, or some segments missing, it can be the connector to the main board, (usually a ribbon) or it can be the rubber connector electrode that links the lcd glass to the circuit board connectors. If you have the inclination, and patience, and a steady hand, and are confident... (alot of "and's" there ;-) you can take it apart, remove the LCD display, take it apart (usually by bending a few metal tabs, the thing will come out, and if you gently separate all the layers it will come apart fairly easy. Then you will see the rubber edge connector that goes to what looks like clear glass (but it actually makes contact there) to drive the segments. What you need to do is gently clean the rubber (both sides) and the gold board contacts (leave the glass display conmtacts part alone) then re-assemble the thing and you may get your display back. This symptom can happen to some LCD displays left in extreme temperature cycle enviorments, or other harsh conditions... or a garage for a few years.. You never know ...
If this does not bring it back, check the cconnectors for dirt (if face is detachable, I don't recall on that exact model if it is or not).
and then go further to the driving circuitry on the board.
Dec 22, 2008 | Pioneer DEQ-7600 15-Band Car Equalizer
Manual book for a pioneer equlizer eq-6500
Here is a link to a deq-7600 manual. It's not exactly the same, but it should be the same install instructions, or enough to get you by...
Nov 30, 2007 | Car Audio & Video
Car Audio & Video Logo
198 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
