Quickbooks problem c=44. what does it mean? Is there a way it can tell you WHERE the problem is? Rather than going through every little bit of data (needle ina haystack method!)? thanks.
  • 837 Answers
C=44 (can't write transaction - usually incomplete transaction)
try reindexing
Posted on Dec 22, 2008
Fleetwoodmac rumors
Posted on Jan 22, 2012
Tell me how to install QuickBooks on windows 8?
Please call quickbooks (844) 414-4868 & have a tech help you so you dont loose sensitive info.
Oct 30, 2015 | Intuit QuickBooks Pro Edition 2009 Full...
Meaning of duplicate invoice
As per time efficiency you can use duplicate invoice when you want little bit change in another client invoice.
so you can create a duplicate copy of original one (need changes) with some customization .
You can duplicate forms such as estimates, purchase orders, credit memos, and invoices by Duplicate template and if need any guidance during this process follow Intuit Customer Service .
Mar 12, 2014 | Intuit QuickBooks Pro Edition 2003 for PC
What is error c=44
QuickBooks attempts to change a damaged transaction or record, you may receive a fatal or unexpected error that contains the value C=44. The C= value in the message indicates the type of error the program has encountered. Typical causes include system lockups and power failures while using QuickBooks. To resolve this issue:
  1. In QuickBooks, select the Window menu and select Close All.
  2. Select the File menu and select Utilities >Verify Data.
  3. If the message "Your data has lost integrity" appears, or the error also occurs while running Verify, select the File menu and select Utilities > Rebuild Data.
  4. When the Rebuild utility has completed, run the Verify utility again to ensure that all problems have been corrected (see step 2).
  5. If the error persists after rebuilding, restore a recent backup that does not generate the error.
Jul 30, 2010 | Intuit QuickBooks Simple Start Edition...
Printer continous initialise no error coming & 5 arrows appear on display panel
You have to be a little bit more specific next time, we have 2 possible scenarios:
A) The printer freezes while initializing with some arrows
B) Blank display / No display
Both are usualy caused by a problem in the formatter (Mainboard) . There is nothing you can do to recover it. If the printer is still under warranty you will need to call HP (1 800 334 51 44 begin_of_the_skype_highlighting 1 800 334 51 44 end_of_the_skype_highlighting) or take the printer to an athorized warranty depot in your area. This link will help.
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
I can tell for sure that the warranty for this specific model M1522NF will be extended 1 extra year (means you have 2 years coverage) if the printer has one of the issues listed above I Hope this can help You can contact me directly on : eliteprintersolutions@hp.com
Jul 21, 2010 | HP LaserJet M1522nf Multifunction Printer...
Got This Message When Starting up Program HELP You cannot open the application ?QuickBooks 2009? because it is not supported on this architecture
Sounds like you may be trying to run a 64-bit app on a 32-bit OS, or vice versa. Check your version of Windows (right-click My Computer, select Properties. The General tab should show you "System:" information to tell you if you have 64-bit Windows or 32-bit. The QuickBooks version you are using should match the OS.
Aug 21, 2009 | Computers & Internet
I couldn't write any date on quickbook 2004. The error codes are C=44 and C=47. How can i fix it?
  • C=44 (can't write transaction - usually incomplete transaction)
  • C=47 (can't find transaction - usually while running a report or opening a file
  • 1> Run Quickbooks update
    2> Run a consistency check on the QB file
    Jul 22, 2009 | Computers & Internet
    Email invoices from quickbooks
    Qb 2009 is a 32 bit application and cannot operate well in a 64 bit OS.
    It will not successfully work with the email.
    Mar 26, 2009 | Intuit QuickBooks Premier 2009 Full...
    Quickbooks 2005 Error 1603
    Explore the QuickBooks 2005 CD, go into the QuickBooks folder and double click quickbooks.msi - this will install QuickBooks without checking for the old/outdated Flash Player 7.
    Sep 30, 2007 | Intuit QuickBooks: Pro 2005 for PC
    Computers & Internet Logo
    42 people viewed this question
    Alun Cox
    David Payne
    David Payne
