Question about Medion md40298 Notebook
Sd card reader doesnt seem to work
I've only used the card reader once but now I want to use it again, it doesnt acknowledge the sd card. I would like to know if I can get the program downloaded if it has been erased accidentally.
  • poulosj Jan 05, 2009
    I have used a compact flash card and memory stick card in the past on my computer. Today, I am trying to put photos on a SD Card. My computer is suppose to read SD Cards. For some reason, I can not get SD card to work in my computer. I have tried 3 different SD cards. When I try to move a photo to the SD Card, my computer tells I need to format the SD Card. When I select to format it, the computer tells me it can not be formatted. I then looked at properties when I did a right click on the SD Card and it shows the card is full. These are new cards out of sealed package. I am finding nothing on the SD Cards. I then have a card reader I can use with my computer ... it is a USB cable attached to a small card reader. When I put the SD Card in the reader, it does not recognize the SD Card ... in other words, when I go to "My Computer" ... the SD Card is not showing up. Noted the SanDisk brand SD Card is made in China.
    Humm ??? have I got 3 bad cards .... or is it something wrong with my computer. Note, my son was here with his laptop when I bought the first SD Card and it would not work in his computer either. He is very experienced with computers and builds them. He has not been here to try for the two other cards I just bought. Thanks for any help, Jan
  • dragonwych Jan 31, 2009
    The SD reader in my Medion P6611 worked fine the first time. I put half a dozen cards of various sizes and brands in it and had no trouble accessing and uploading the contents.
    The next time I put in a card, the computer said there was nothing on it. I put in a different card. It was not acknowledged at all. I rebooted the computer and put in a card that had worked before. No acknowledgement.
    I put the "empty" card back in the camera and uploaded the pictures using a USB cable. Same for the second card, no problems.
    There is, obviously, no problem of incompatibility of technologies here. The reader has stopped working, but why?
I had the same problem as you describe on my Medion P6611 laptop (and on a previous Medion desktop that was, sadly, stolen from my apartment in early December. But I digress...) I called Medion tech support (which I have never found to be anything less than excellent), and the representative said:
The problem *may* be due to a buildup of static electricity, either on the card itself or in the card reader (I forget which it is). To fix it, do the following:
  • Tturn off your computer, remove the battery and unplug the AC power adapter from the laptop if it's also attached.
  • Press and hold the power button for 60 seconds or so. (This discharges the electricity from some internal component[s]--capacitors, perhaps?)
  • Replace the battery, reconnect the AC adapter (if you use it) and turn on the computer.
With any luck, that should fix your problem.
P.S. One slightly related tip: When you remove a card from the card reader, just remove it. There's no need to click on "Safely remove hardware" and select the card reader's drive letter. If you do, it won't recognize cards again until you reboot or turn the machine off and back on. Different problem, but same behavior.
Posted on Feb 16, 2009
  • jbh_stl Feb 16, 2009
    Uh, I meant "Turn off your computer" (not "Tturn"). Sorry for the typo.
    Scholar:
  • 108 Answers
Some older laptops cannot handle the newer sd cards like it's sdhd so check the card and see if it shows HD on it if so that might be your problem.
It's rare the readers go bad so that should be the issue that you are having.
When you put the sd card in there should be a folder that pops up that shows the file if not check through going to the windows explorer folder in start programs accessories if you are using windows xp and seeing if the removal disk is there which it should be the card itself
Happy Holidays
Posted on Dec 25, 2008
Not acknowledging SD card
E-Machines eMachines Desktop PC Sd card reader ... - Fixya
www.fixya.com > ... > E-Machines > E-Machines eMachines Desktop PC
SD card in the 9 in 1 card reader, but it does not read. please check the SD Card ...SD card readers aren't capable of reading SDHC cards, even though the card will physically fit into the card reader slot. ... E-Machines T5082 PC Desktop.
Oct 02, 2015 | E-Machines T5082 PC Desktop
Camera fails to acknowledge memory card
Try cleaning SD card connectors with clean rag, and blow some dust out of a SD card connecting place, if it doesnt work try checking that SD card on some other camera, if it works take your camera to service, if SD card doesnt work on othar camera than SD card is broken.
Feb 16, 2013 | Kodak EasyShare One Digital Camera
SD CARD reader error: Insert removable disk into drive F:/
One of two I was say is the issue.
  • When you improperly ejected the card you messed up the MFT (master file table) on the card. You will want to format the card.
  • You could have hosed the drivers. In Device manager look under the driver details there should be some files listed. You will probably need to delete these and replace them. Since they may be system files you would need to replace them in a live boot environment such as a linux live boot cd (ubuntu.com) would be the easiest. Get the drivers it has listed copy them to a thumb drive. Boot the computer to the live CD, delete the driver files and replace with the new ones.
Dec 18, 2012 | Electronics - Others
I hav a 16 gb sd crd and it says blank sd ca?rd I've tried formatting it but still reads blank
Ur cellphone may not be compatible with 16 gb card. Try using it with pc with a card reader. If it doesnt work there then the hw of card is damaged and u need to replace it.
Jul 16, 2011 | Cell Phones
Why doesnt my sd card reader work? I put in my gateway laptop and it doesnt work nothing pops up??
You might just have a bad SD card. Also, if you bought a card that is 4gb or more then you need a SDHC card reader. The HC stands for High Capacity. Look at the card to see if it shows HC under the SD. If it does then you need to find out if your card reader can read SDHC. If it can't then you need to go buy a new card reader that can do SDHC.
Jan 28, 2011 | Computers & Internet
My Hp SD card reader doesn't work how can I make it work again?
Did you insert the memory card properly? because if your memory card is not inserted properly, the SD card reader may seem not to work. And if probably the problem is from the SD card reader slot, then you have to give it to an engineer for repair or better still take your laptop to Hp customer service center for repair. Thanks
Sep 24, 2009 | HP Pavilion dv1000 Notebook
Acer Aspire card reader not acknowledging SD card
go to Wal-Mart or K-Mart and such, you can get a SD reader/ writer (such as Targus, about $9 USD, what I use) and put your SD card into it, then plug into USB (USB 2.0 is current standard, but will work with USB 1.1, just slower). PC will ask if you want to play/record from/to the removable drive, select "take no action" then go to the "my computer" icon (or what ever you have named it) double click the drive letter for the flash/SD card (E,F,G etc.). open the file folder that you want to copy from <usually something like "100MEDIA" or such> (I STRONGLY recommend that you "COPY FILE(S)" and NOT "move file(s)" as that if something crashes you still HAVE the orig. files) select to copy to the correct drive letter/ file name(s) and PLEASE remember to "remove hardware safely" or you could KILL the files and/or the drive(s) that you were using. (did that TWICE before I realized what I was doing wrong). good luck!
Mar 31, 2009 | Acer Aspire 5050-3242 Notebook
Memory card reads Media Error
it sounds like you have a system conflict with the readers on the sd cards they wont last long if you use them alot going back and forth on it what i'd do is get 2 cards one for each system and only use them for that system only but the problem is the more you transfer media and erase it and do again it burns out the disk about the best you can do is get a bigger sd card and send all the info to 1 system then print it from your computer
Mar 20, 2009 | SanDisk Memory Media
Sd card reader does not work
you might need to remove upper and lower filtrs with filtercheck 4.6
then repair sonic dla (if it has sonic burning software you use)
www.cdr-zone.com/forum/about4719.html&highlight=filtercheck
Aug 19, 2008 | Dell Inspiron 1501 Notebook
Medion md40298 Notebook Logo
804 people viewed this question
Top Medion Computers & Internet Experts
Larry Chandler
Are you a Medion Computer and Internet Expert? Answer questions, earn points and help others
