Question about Garmin StreetPilot 2720 GPS Receiver
Garmin 2720 lost sound
My Garmin 2720 has recently developed a problem of losing its ability to "speak."
Switching the unit on normally and asking for it to provide directions to a given location, the unit begins performing normally. But after 5 to 10 minutes of normal operation, a spoken direction will be garbled, and then after that there is no sound at all.
Immediately switching the unit off and then on has no effect. Leaving the unit off for several hours will result in the pattern above where it works for a little while and then goes silent.
Any ideas?
  • rigarunner Jan 26, 2009
    Thanks for a good suggestion which may be relevant regarding heat, but in the speaker unit. I have solved the problem by purchasing a new power cord/speaker unit -- everything is working perfectly. I have to conclude that the previous power cord/speaker assembly was the culprit.
    Problem Solver:
  • 7 Answers
It sounds like the audio power amplifier is failing in the unit, it's kinda classic for an audio amplifier to fail when it gets hot, then work again when it cools down.
I'd suggest deleting the language you're using, then reload v7.2 firmware and the language. No reason why this should work, but it doesn't cost anything. If not you're looking at a $250 Garmin flat rate repair.
Posted on Jan 24, 2009
  • Tom 2720 Jan 26, 2009
    Of course! The speaker wires shorting together would cause the audio amplifier heat up, and all good amplifier circuits have a thermal shutdown feature. Sorry I didn't suggest that. Glad you found it. Tom
I've recently lost the "Stop sign" and the ability
TRY UPDATING, PLUG IT INTO YOUR COMPUTER AND GO TO GARMIN WEBSITE.
Nov 08, 2010 | Garmin nuvi 1250 Car GPS Receiver
do not buy any this product garmin does not warranty or stand by its products, if have this fixed it will cost 300 but if you buy a new gps it will cost 150.00 can you understand this ?
May 09, 2009 | Garmin StreetPilot 2720 GPS Receiver
FIXED! Garmin 2720 Power Cable Defect
Thank you for the tip. Sorry for the trouble you had.
Mar 01, 2017 | Garmin StreetPilot 2720 GPS Receiver
Garmin GPS 2720
Unfortunately, Fixya is not associated with Garmin. We can only answer device questions and can't speak for the company.
Unfortunately, the unit cannot be upgraded. Garmin provides both in and out of warranty repair service if the unit is having a problem. The 2720 sells for $49 on Amazon, so it probably is not worth your while to have fixed.
The 2720 is known to have issues unfortunately, it is pretty lowly rated on Amazon.
Mar 23, 2017 | Garmin StreetPilot 2720 GPS Receiver
Unit Locked Up
When turning on the unit, hold these two keys down: MENU/MAP for about 5 sec then release. That should reset the unit.
Jul 05, 2008 | Garmin StreetPilot 2720 GPS Receiver
Unlock Code
When updating the maps, you need to be registered with Garmin. All the numbers came with the unit. If you turn over your Garmin 2720, there will be a number flanked by "*". That is your unit ID. When you register, you must provide that ID. From the site, you can update your maps and you shouldn't need the 25digit key. It's programmed into your unit.
Jul 01, 2008 | Garmin StreetPilot 2720 GPS Receiver
Software Update - Non-working Garmin Lock
Check to see if "Recent Selections" contain any of your favorites. You can then rebuilt Favorites from the Recent Selections. If the Recent Selections contain any of your favorite just select it and then select Save.
Jan 15, 2008 | Garmin StreetPilot c550 GPS Receiver
Map Unlock Code
Garmin normally replace your unit with a refurbished unit. Yes call Garmin and ask for a new unlock code. Normally they provide a new registration ID (yellow piece of paper with the unlock code for the latest mapsource map and accessories which it also included with the refurbished unit.
Jan 05, 2008 | Garmin iQue 3600 GPS Receiver
Clock doesn't update
Ensure you have the latest software....7.10
Also, hold down the menu and map button when you power it up for 15 seconds or so.
Make sure you have a clear view of the sky....let it sit for 20 min.
Answer the questions on the screen and try again.
Note: doing the above will cause the unit to lose all your favorites, recent finds etc., so do a back up.
Dec 07, 2007 | Garmin StreetPilot 2720 GPS Receiver
Restarting while in use
Mine just started doing the same thing. I took apart the speaker power cord, but don't see anything wrong with it. I thought I saw the unit turn off/on one time when I moved the cigarette plug back and forth, but as I said the wires are fine. I have the power cord apart right now and have 12 volts hooked up to the wires directly and the unit has been sitting here for 30 minutes without resetting.
Oct 17, 2007 | Garmin StreetPilot 2720 GPS Receiver
Garmin StreetPilot 2720 GPS Receiver Logo
180 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
