Question about Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher
Steam eating my cabinet top up
When my dishwasher pld2560lcc is drying the steam comes out the top around my cabinet top edge. The mosture is eating away at the pressed wood material. Is there a way to deflect this stream or reroute it? I am afraid it will destroy my cabinet top.
  • tjwatsn Dec 22, 2008
    If thats the only solution I will give it a try. I was thinking of using a thin sheet of plastic to prevent rust or stainless.
    Thanks
You can buy a metal strip with a small angled edge to fit under the worktop above the dishwasher. I have one of these and it has protected the worktop for 10 years,
Posted on Dec 22, 2008
When we take the dishes out they are all wet
Choose the hottest rinse cycle first Economy cycles don't work properly Make sure you have rinse aid in the dispenser. Make sure the machine is heating properly too. An aid do drying is to open the door of the dishwasher just when the cycle finishes steam should come out and the water in the cabinet will condense to the walls and dry the dishes. some top end models do this with a push rod..... believe it or not (Miele) go to my website for a detailed explanation about drying www.appliances.cjb.net you can contact me from there too for further follow up good luck
Mar 01, 2011 | Dishwashers
How do I adjust top drawer height? The seal around top drawer appears to be leaking and there is a lot of dried residue around the top edge of the drawer. Water appears to be leaking from the top.
Not sure if adjusting top drawer height will fix the leak. The only way to fix the drawer seal leak is to take the drawer out and check what is wrong with the seal which is located around the top edge of the cabinet from inside.
Hope this helps. Please rate this solution if helpful otherwise please post a comment
Sep 01, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
New whirlpool dishwasher when in use drips from right side.
Check if the dishwasher is level side to side and front to back. (you can generally tell if the edge of the tub has an even space between it and the cabinet at top and bottom, and the tub is not further in or out on top or bottom in relation to the edge of the cabinet. Also, make sure the door is not hitting the cabinet edge when you close the dishwasher door.
Feb 05, 2010 | Dishwashers
How do you anchor the dishwasher so it doesn't move around? There are no brackets on the front to anchor to the counter.
Open the door and look at the top edge of the washer. It should have 1 or 2 small straps to screw down to the cabinet. If no straps look for small holes to screw a piece of metal strap to the cabinet.
Nov 02, 2009 | Dishwashers
Is it normal to see steam coming out of the dishwasher in the drying cycle?
Yes, The colder the room its in the more steam you will see. It will look like more steam if sun light is shinning over it. Just like your clothes dryer blowing steam out side. Its just drying.
Oct 30, 2009 | Dishwashers
Jenn-Air JDB8910 dishwasher moisture coming out left side.
thats a vent fan to help with drying cycle its normal for steam to come out during cycle of drying you might use no heat air dry and turn your jet dry disp up but its a normal part of drying cycle
Feb 11, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
Ge dishwasher gld4160looss
Where's the vent on top/or the end of the door under the cabinet? Some steam is normal.
Nov 21, 2008 | GE 24 in. GLD5560LSS Stainless Steel...
Electrolux dishwasher leaking steam when on finishing/drying cycle
Steam is normal, its getting rid of the mosture inside the dishwasher.
Sep 15, 2008 | Electrolux Dishwashers
Fridgidaire dishwasher pld2560lcc
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Jun 27, 2008 | Frigidaire 24 in. PLD2560LCC Energy...
Kenmore Elite coffeemaker - excess steam
Fold a large piece of foil into quarters. Place foil over reservoir and firmly close lid. Open lid and massage edge of foil inside and out with finger to get a kind of cap. Remove foil and trim neatly around outer edge of lip. Fill reservoir with water, place cap on top and close lid. Make coffee.
Mar 02, 2008 | Coffee Makers & Espresso Machines
Frigidaire 24 in. PLD2560LCC Energy Star® Built-in Dishwasher Logo
316 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Archie Ferrarini
Archie Ferrarini
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
