Question about Dell Inspiron B130 Notebook
When I try to boot my Dell intel inspiron b130, I get a white screen that says: "the device in the system modular bay cannot be identified. It may not be completely inserted or may have some other problem. Please read and complete the following steps in order: 1) Press the device firmly into the bay 2)Power off the system 3)Press the power button to retry detecting the device" So far I have tried removing and reseating the optical drive. I don't know what else to do, but I need to boot my computer so I can access a couple of files that I didn't get a chance to back up.
  • 1 more comment
  • Anonymous Jan 05, 2009
    Could a dead battery be the problem? Mine was approaching the end of it's useab life. If I replace the battery will that fix it?
  • marygirl_mh Jan 05, 2009
    Could a dead battery be the problem? Mine was approaching the end of it's useable life. If I replace the battery will that fix the problem?
  • Roberta Smith
    Roberta Smith May 11, 2010
    if the device is not critical to your backing up the files.... unplug it and reboot and do that ....what is the device by the way ?
  • 837 Answers
It sounds like either the battery or the drive (floppy or CD-ROM) is not seated correctly. Try removing each of them and inserting them again.
Posted on Dec 22, 2008
Dell Inspiron 1100 problem
For Dell Inspiron 1100 Support just dial 1-800-204-4427 Dell Inspiron laptop support number to fix you error by expert technician. For more Click here : http://www.delltechnicalsupportphonenumbers.com/dell-inspiron-laptop-support
Jul 08, 2017 | Dell Inspiron 1100 System Board (...
I want to know what drive fits the bay by the headphone jacks
That is an Express Card slot
http://support.dell.com/support/edocs/systems/ins1300/en/om/om_en.pdf
Express Cards are the replacement for the PCMCIA/PC Card modular devices.
Here are some examples of what can be done:
http://www.expresscard.org/web/site/ecu03.jsp
Oct 20, 2009 | Dell Inspiron B130 Notebook
Either issue with system modular bay or system file removed
remove any cd or floppy disks from the pc...reboot ..if the black screen reaper with the same message about the missing file ..you have to insert the windows instalation cd ...and repair..the missing file
Jan 28, 2009 | Dell Inspiron 2200 Notebook
Dump of Physical Memory
Put the Dell CD in the drive bay. Turn on the computer and start pressing <F12> key. It should say "Preparing one-tome boot" When the screen shows a selection menu for the boot device, use the arrow keys to select the CD and press <Enter> key. That should run the Dell CD. Follow the onscreen prompts to run diagnostics checks
Dec 16, 2008 | Dell Inspiron 8600 Notebook
I need solution
Ok, this is a misworded error message on dells end. this laptop does not have a modular bay instead it has a locked in disc drive. Based on what i have seen on other dell laptops i would have to say the cd drive is going bad. To test this try removing the cd drive. Power the laptop on and push the eject button then power the laptop off. Flip the laptop overand there will be a screw to hold the drive in, this screw will be close to the center and will be the only screw in a square hole, remove this screw. Now if you followed my directions, you should have the drive out. Pull the tray out as far as it will go then grab the two sides closest to the laptop and gently pull it out. If you are having problems you can stick a flat screw driver in the square hole and push the piece of metel to the side to remove.
Now power the laptop on it may say something about there not being a cd drive(optical drive) if it does not say: "the device in the system modular bay cannot be identified" then you need to replace to CD drive.
Dec 04, 2008 | Dell Inspiron 2200 Notebook
It won't boot to the os
The modular bay refers to the optical drive (CD drive). There is a small screw holding it, I've had machines at my shop that this screw fallen out and the drive wasn't making a good connection. Be sure that the drive hasn't slid out a bit. Take it out clean the connection and put it back, making sure it's seated properly. Try this, then let me know, and we'll go from there.
Jul 29, 2008 | Dell Latitude D600 Notebook
This screen comes up when it is turned on: "The device in the system modular bay cannot be identified, etc.
I had the same problem.  I took out the optical drive, and powered it on, and it worked.  I may have to purchase a new optical drive?
May 22, 2008 | Dell Inspiron B120 Notebook
Bought second hand c640
Power off even it it takes a battery removal. Now check modular bays and remove then fully insert each device and retry power up. If same results, try repeating above with one of the modular devices removed.
Sep 09, 2007 | Dell Latitude C640 Notebook
Dell Inspiron B130 Notebook Logo
639 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
