Pioneer DEQ-7600 15-Band Car Equalizer Logo
r stimac Posted on Dec 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No graphic display
Pioneer deq 7600 works fine but the graphic display is blank
  • mdavis726 Feb 10, 2009
    i have same problem no screen display
Anonymous
Level 2:
Scholar:
  • Expert 80 Answers
  • Posted on Jun 12, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
80
Questions
0
Helped
39363
Points
167
If blank, or some segments missing, it can be the connector to the main board, (usually a ribbon) or it can be the rubber connector electrode that links the lcd glass to the circuit board connectors. If you have the inclination, and patience, and a steady hand, and are confident... (alot of "and's" there ;-) you can take it apart, remove the LCD display, take it apart (usually by bending a few metal tabs, the thing will come out, and if you gently separate all the layers it will come apart fairly easy. Then you will see the rubber edge connector that goes to what looks like clear glass (but it actually makes contact there) to drive the segments. What you need to do is gently clean the rubber (both sides) and the gold board contacts (leave the glass display conmtacts part alone) then re-assemble the thing and you may get your display back. This symptom can happen to some LCD displays left in extreme temperature cycle enviorments, or other harsh conditions... or a garage for a few years.. You never know ...
If this does not bring it back, check the cconnectors for dirt (if face is detachable, I don't recall on that exact model if it is or not).
and then go further to the driving circuitry on the board.
2helpful
Pioneer deq-7600 lcd very dim, lcd problem?
The LCD display is failing, or the driver ic is the issue, or the B+ is to low causing the dimming effect, a resistor gone high in value would explain this.
I have a Pioneer DEQ-7600 and every so often I have to tap my dash board in order for the display lights to come on the front of the unit, like it goes in and out every so often, thanks Nick
Nick i believe that you have a simple ground loop problem. To fix that you'll need to run a ground wire from your EQ to the body of the car. (the shorter the wire,the better the ground)
Find the ground wire (black wire) coming out of your EQ. Splice a wire into that wire,and then connect that wire to the black wire coming out of your Head Unit,and that should solve your problem.
My pioneer deq 7600 keep resetting it wont memory
do you have the yellow wire going to a constant power source??
I'm searching for a visual diagram to show the power hook up on the Pioneer DEQ 7600. I need a description of each wire and how to connect.
go to crutchfield.com and type in your model.on the right side of the screen it lists whats in the box.from there you can print a diagram.
3helpful
Need wireing diagram for pioneer deq 7600 4pin plug
I need to see a diagram how or how to setup my equalizer and reverb to my amp all pioneers old stuff sg60 and sg540
How to change the color display and brighten it up for a Pioneer deq-7600?
Here's a link to the manual in english...
http://akamaipix.crutchfield.com/Manuals/130/130DEQ7600.PDF
I read thru it, and no mention of how to do it. I do believe it can tho.
Pioneer deq 7600 display went black today the eq works fine.
the faceplate contacts may need to be cleaned. remove the faceplate, and using an eraser, clean the metal tabs on the main unit and rear of the faceplate.
If this doesnt remedy the problem, service is required. May be the light unit in the faceplate.
Top Pioneer Car Audio & Video Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Grand Canyon Tech
Grand Canyon Tech
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
