Question about Microsoft Xbox 360 Console
Microsoft xbox 360
There is raddleing where you plug in the hard drive. Do you know what i can do to fix it?
    Scholar:
  • 59 Answers
Not a whole lot, some hard drives just make noise, if you console is on its side try standing it up or if you want to take the risk you can open the hd enclosure and unmount and re-mount the actual drive its possible that it vibrated loose at some point. another solution might be to set something on top of or against the attached enclosure to quiet the sound of the vibrations.
Posted on Apr 21, 2007
How to fix a grey screen on the xbox360??
How to Fix Xbox 360 Green Screen:
1)
Check for loose cables.
2) Try to unplug all cables except the power cord, and plug them back in.
3) Remove the hard-drive, then restart your console.
4) Once the Xbox 360 green screen problem is gone, get the hard-drive back in while your console has been shut down.
If these tips didn't fix your console, then you have to send it to Microsoft.
Microsoft has some kind of repair service to fix your Xbox 360 green screen error, but it's obvious that it's not for free.
Feb 19, 2011 | Microsoft Xbox 360 Console
Xbox360 E73 proplem
this microsoft xbox 360 problem will be easily solved by our own , you dont want to get your xbox to the repair shop, use repair guide and fix your problem.
click here to download repair guide.
Apr 15, 2010 | Microsoft Xbox 360 Console
Xbox 360 hard drive issues
Maybe the socket where you plug the hard drive into is dirty or broken. Try checking it out and have a close inspection!
Feb 18, 2010 | Microsoft Xbox 360 Hard Drive (20GB)
One red light e68
This behavior occurs when an Xbox 360 Hard Drive hardware failure occurs.
1. Turn off the console.2.
Remove the hard drive. For more information about how to attach or remove the Xbox 360 Hard Drive3.
Reattach the hard drive, and then turn on the console.4.
Obtain the latest automatic update for the Xbox 3602.gif. To do this, connect to Xbox Live.5.
If you continue to experience this behavior, contact Xbox Customer Service.
Nov 18, 2009 | Microsoft Xbox 360 Console
XBOX 360 e68 all hard drives
Unfortunately you can not fix that problem on your own, you need to call Microsoft at 1-800-4-My-Xbox
Aug 29, 2009 | Microsoft Xbox 360 Console
Bottom right corner red flashing light error e 74
From the Xbox website sounds like you have a HDD failure / issue.
Try the following steps to resolve the problem: 1. Turn off your Xbox 360 console. 2. Removethe Hard Drive. For more information about how to attach or remove theXbox 360 Hard Drive, click the following article number to view thearticle in the Microsoft Knowledge Base: 906204 (http://support.microsoft.com/kb/906204/ ) How to attach or remove your Xbox 360 Hard Drive 3. Reattach the Hard Drive. 4. Turn on your Xbox 360 console.Ifyou continue to experience this problem, obtain the latest automaticupdate for your Xbox 360 console. To do this, follow these steps: 1. Turn off your Xbox 360 console. 2. Detach the Hard Drive. 3. Connect the console to the Internet through an Ethernet cable.Notes • Toobtain an automatic update without your Xbox 360 Hard Drive attached,you must have an Xbox 360 Memory Unit or an Xbox 360 that has built-inmemory. • If you cannot connect to Xbox LIVE, running a recent game (2007 or newer) causes an automatic update to be installed. • You can also obtain the latest Xbox 360 system software from the following Xbox Support Web site: http://www.xbox.com/support/ (http://www.xbox.com/support/) If applying the latest automatic update does not resolve the problem,please contact Xbox Customer Service. If the Customer Service agentcannot help you resolve the issue, you may have to replace the HardDrive. Discuss your replacement options with the agent.
For moreinformation about how to contact Xbox Customer Support, or to submit arepair request, please visit the following Xbox Support Web site: http://www.xbox.com/support/
Jul 25, 2009 | Microsoft Xbox 360 Console
MY XBOX 360 HAS 1 RED LIGHT FLASHING, WHEN STOOD ON ITS SIDE THE LIGHT IS BOTTOM RIGHT
one red light flashing on the ROL of your Xbox 360 console that's an indicator of a hardware problem with the console connection to one of the parts connected to it as the hard drive or cables. first disconnect all power and AV cables from the back of your Xbox 360 console and also unplug the power cord from the wall socket, wait for a minute then reconnect them all back and try to turn on your Xbox 360 console once more. If that doesn't work, it seems then to be a fault with your Xbox 360 hard drive so turn off the console again and remove the hard drive then turn on your Xbox 360 console without the hard drive, supposed then to work fine, it might be an intermittent issue and when you reconnect the hard drive your Xbox 360 will work fine all after, or it will just work fine without the hard drive so it will be then definitely a fault with your Xbox 360 hard drive so call Xbox 360 customer support to exchange the hard drive for you. The Xbox 360 console might even keep giving you the same error code even after you remove the hard drive so it will then appear to be a fault with your Xbox 360 console not the hard drive & also in a case like this we need to contact Xbox 360 customer support to exchange the console.
Jun 06, 2009 | Microsoft Xbox 360 Console
Hard drive won't read downloads
Hello my name is Tim Ehrhart, your whole problem is the fact you cant get it connected to the internet, ou have to be able to connect so the 360 can update the patches for the games because when microsoft repairs the xbox they erase all the updates you had. I hope this helps but it sounds to me like you need to plug the ethernet cable in and try to recover your gammer tag and account. Please let me know if you need anything further.
Mar 18, 2009 | Microsoft Xbox 360 Console
RROD
Step1 Go through several different runs to make sure that your Xbox 360 is really broken. For example, if you’re getting an error message when you put in a disc, try a different one. The problem can sometimes be the game you’re playing and not the console. Step2 xbox360sn_thumb.jpg Look here for the Xbox 360 serial number. Gather your serial number. Before calling Microsoft, make sure that you write down the serial number of your console. This is found on the back of the system. Step3 Contact Microsoft. Although you can contact Microsoft through email, they will only take care of repairing an Xbox 360 over the phone. Call (800) 4MY-XBOX and describe the problem to the technician. Step4 Receive shipping box from Microsoft. After you talk to a Microsoft customer service representative, they will ship a box to you. This box is used when you send your system back to them for repair. They provide postage and tape for sealing the box so that you don’t have to pay for anything. Step5 Prepare Xbox 360 for shipment. With the shipment box, you’ll also get instructions for sending your system. The most important thing to do is remove any accessories. Be sure to keep hard drives, games, cords,controllers, and personalized faceplates. Step6 Ship Xbox 360. Once you have your console boxed up, you’ll need to bring it to UPS. Although Microsoft pays for the shipping of your defective Xbox 360, you still need to get it to the shipping company. Luckily, it’s relatively easy to find UPS stores in most cities. Step7 Watch the status of your shipment on the service website that Microsoft provides. Log on to http://service.xbox.com to see how the repair process is going. You should typically receive your fixed Xbox 360 in a few weeks. The whole process should take about a month.
I think next time you should call Microsoft and know what you are trying to do.
Jun 22, 2008 | Microsoft Xbox 360 Console
XBox 360 hard drive
ur hard drive might be infected i dont know about a do it your self fix but u might get microsoft to fix it for u
Jun 10, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
48 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
