Refrigerators Logo
Posted on Dec 22, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Leaking water dispenser
I have a Kenmore refrigerator. The water dispenser in the door is leaking. How can I fix it?
Anonymous
Level 3:
President:
  • Master 373 Answers
  • Posted on Dec 22, 2008
Anonymous
Master
Level 3:
President:
Answers
373
Questions
Helped
192894
Points
1748
Check the "drain pan". during defrost cycle it is filled completely.Try to shift the water out of it during every defrosting cycle.
1 Related Answer
Anonymous
  • 1122 Answers
  • Posted on May 31, 2008
SOURCE: Kenmore elite refrigerator door leak
your drain in the bottom of freezer is clogged or frozen,use a hanger or if it is frozen use a hair dryer,thanks-mike
Line going to door water dispenser leaking under refrigerator kenmore model 363.9537750
If at fitting tighten the connection. If the pipe is leaking then replace it.
Kenmore side by side model 106.5xx. The ice bucket has ice but the dispenser on the door will not release the ice. I hear a click but nothing happens. I removed all of the ice from the bucket and the...
The freezer part is working but the refrigerator part is leaking water from the left side upper corner .there is like a vent from, where the water is leaking and the refrigerator side is not cooling any hint or advice will be appreciated thanks
Side by side refrigerator- water dispenser clogged and now leakin
i'd shut off the water take apart and clean change water filter.
Kenmore side by side water dispenser
my water line in trp door is leaking how do i get to it i cannot figure how to but can see it Ed Nixon ( some body help)
Leaking water
turn the water off its behind the unit on the wall .
you might have a busted pip in the door but only tech' can fix that ....
Leaking
it is a plugged drain hose in the freezer remove the back cover and clean out the drain hose...it will stop your leak
1helpful
2answers
Top Kenmore Refrigerators Experts
vince
Johnny 1000
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
