Question about Toro Lawn Mower With Toro Power Tools
Toro single stage 6.5 hp snowthrower loses power after use
We have a 6.5 hp snowblower that we purchased 2 years ago. It was working fine last year but this year when we use it it works fine for 2-3 minutes and then the auger/impeller loses force. It does not propel even in a few centimetres of snow. We have replaced the gasoline and engine oil. Any suggestions?
  • 1 more comment
  • jpark18 Dec 23, 2008
    wow, I have the same problem. I snowblower works fine for the first 5 minutes. Then it start to lose power and I can't even blow a few inches of snow. Any advice?
  • jacky_wisdom Jan 11, 2009
    Hi, Thanks for your help. But where's the pulley? Do I need to take the cover off the side to view it. How do i adjust it?
  • schiavone652 Jan 13, 2009
    same problem here - repair guy has no idea as to how to fix
boscia
  • 163 Answers
SOURCE: snow thrower won't throw snow
the problem could be the snow is to heavy for the motor to keep up, if thats the case you may need to upgrade to a more powerful model or try not to overload it. take it a little slower so the motor can keep up. but try tightening the belt. with your pointer finger push down on the belt it should have about a half inch give, if it moves more than that its too loose and probably slipping under load
Posted on Dec 13, 2008
  • 81 Answers
SOURCE: Toro Personal Pace self propel problem.
Your self-propel is probably belt driven. Belts can make an awfully lot of noise when unhappy. Possible it has rolled over and is running on the wrong side of the belt or is worn and just needs replaced. Hope this helps.,
Posted on Jun 19, 2009
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
SOURCE: i have a toro ccr 2450 snowblower. i bought it
No if your belt is shredding there is something rubbing on the belt. Check the idler/tightner pulley see if it spins freely. Check make sure nothing but the pulleys are touching the belt when it is engaged.
Sam
Posted on Jan 08, 2010
Testimonial: "Thank you for the quick response."
  • 16 Answers
SOURCE: My Toro CCR 2450 GTS Snowthrower loses power after
have found that even with self propel mowers-- the brake cable is worn and makes it hard if not impossible to start.
Posted on Nov 30, 2011
I have a MTD snowblower yard machine.how to adjust
There should be metal shoes on the side of the snowblower. They have adjustment bolts that allow the auger housing to move up and down. loosen them and adjust to how close you want it to the ground. It also depends on the model. This process only applies to large self propelled models which are a two stage snowthrower. if its a small single stage there is usually no adjustment.
Oct 19, 2014 | Garden
Toro snowthrower coil condensor points
If you have changed sparkplug and coil and cleaned flywheel, you probably have a kill wire problem. Disconnect kill wire from coil and try again.
Apr 04, 2014 | Tecumseh Enduro Horizontal Engine 5 HP...
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
How do I clean carburetor
check out this YouTube video for cleaning a single stage snowblower carb.
http://www.youtube.com/watch?v=KYj5oH0vNVg
Dec 15, 2013 | Toro Power Clear Snowblower 418ZR - 38272
I think the float is stuck on My Toro snowthrower 38272
It's possible. Is it all green and sticky inside the bowl?
Nov 04, 2013 | Toro Power Clear Snowblower 418ZR - 38272
My Toro CCR 2450 GTS Snowthrower loses power after it gets warmed up. New spark plug and fresh gas with proper oil mix.Why?
Mine does same. Wait a half hour, restart, runs good for 20 minutes and slows again. Just had it in for a tune up. Machine is only three years old.
Dec 31, 2010 | Toro Lawn Mower With Toro Power Tools
I have a toro ccr 2450 snowblower. i bought it
Sam
Jan 08, 2010 | Toro Lawn Mower With Toro Power Tools
Snowthrower. Won't even fire. Can I just clean carburetor?
See my tip on diagnosing small engines. It works for 2-stroke or 4-stroke engines.
It is best not to use starter fluid. Aerosol carb cleaner is what I use.
Jan 02, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
412 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
