Question about Lenovo 3000 Y410 Notebook
Hi my laptop will turn off suddenly even though it is plugged
  • hari2sh Dec 22, 2008
    i have doubt on my heat sink...i checked my fan and it is runnig very fine....sooo i think heat sink itself is the problem
    and one more thing my laptop is lenovo 3000 N100 not y410
    Brigadier General:
  • 5,158 Answers
It may be shutting off due to thermal shutdown... basically the fan isn't keeping the cpu cool enough... check to make sure the fan is running and that the fan/cpu heatsink is clear of dust and dirt.
Robert
Posted on Dec 22, 2008
Samsung n150 laptop will only turn on when plugged in the wall. the charge light flashes green and orange repeatedly , when moving cursor over battery it says 0% battery remaining !! this just suddenly...
Hi there, it sounds like your battery is no longer functional. You will have to replace your battery in order to get this working again. Before you replace it, ensure that the contacts on the battery and the laptop are clean and connecting - the odds of this being the problem are slim, though. -Alex
Aug 15, 2011 | Samsung N150 (36725723009) Netbook
Hi,the problem with my dell inspiron1420 is that suddenly theres no sound..but if pluf in my headphones..it works...pls help..how do i fix this?thx
The most common issue when this happens, is not easy to fix. There is a pin in the headphone jack that opens a circuit when you plug the headphones in which turns off the internal speakers. Over time the pin gets worn down and stays in the position even if headphones are not plugged in. This prevents the internal speakers from getting the audio signal.
Some people have had success with poking a pin in the hole and gently prying the pin back a little. I don't recommend you do this though as you may make it worse or short something out. By all means if you want to try that, turn off the laptop first and unplug it from the A/C and take out the battery.
Most cases you will need to send the laptop to DELL for servicing. If the laptop is out of warranty, the repair might not be worth the cost.
This happens a lot and I has happened to one of my Asus Laptops. Very annoying! I feel your pain.
Regards, Chris
May 31, 2011 | Computers & Internet
360 won't turn on
Sounds like you fried your Xbox. You are right though, the lights should at least come on. You can try the new power brick and if that doesn't work then your xbox may have blown something, in which case your best and safest bet is to replace it. Sorry.
Jan 18, 2010 | Microsoft Xbox 360 Console
Laptop suddenly shut off and will not turn back on
Sometimes the voltage regulator in the battery hit a point where they fall below a certain efficiancy % they have to operate at. Once they fall below that % you must replace them, even if the battery is 100% charged. Its usually a good idea to pick up a new charger as well with a new battery since they are known to die as well. Make sure you check the socket in the back where your charger plugs into the laptop to make sure its not loose or cracked. Sometimes the plug will crack off the motherboard and not make good enough contact.. But regardless of that it should atleast turn on if the battery was charged and good. Best bet, new battery. Every 2 years you should get a new one.
Jun 04, 2009 | Toshiba Satellite M45-S269 Notebook
My microphone is not recognised by my acer laptop
just use 5 setp your problem is solve 100%
ok
  1. click stat
  2. click All program
  3. click accessories
  4. click system tools
  5. click system Restore
and select to restor point and select the date form your problem data 1 day befor
Mar 26, 2009 | Computers & Internet
Blackberry bold suddenly shut down
Lots of battery issues with the Bold. Try taking the battery out, keeping it out and connecting to PC with USB. Do any lights come on? Red light should appear. Put battery in while connected to USB.
Another fix that I found for a friend-leave the battery out of the unit for a day-put it in and plug in power cord or USB. It worked.
Mar 20, 2009 | RIM BlackBerry Bold 9000 Smartphone
Problem turning power on
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Hi
Problem is in mother board. Shot in capacitor has shown in image. Replace it....3cfd270.jpg
Jul 10, 2008 | Dell Inspiron 600M Notebook
Lenovo 3000 Y410 Notebook Logo
145 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
