Question about Sanyo VWM-900 VHS VCR
Recording I've tried multiply ways to try and record tv shows by the timer, but it doesn't record from the channel. The only thing it tapes is static fuzz. What is going on?
  • Kim Weichbrodt Apr 07, 2007
    The clock is set and yes I have tried recording the program when watching it by simply pushing tht lil red button, but the same thing is happening
    Novelist:
    Champion:
  • 275 Answers
Does it record when you are simultaneously watching a program? if yes, then recording circuits are OK. It is definitely a problem of settings. Try doing it again step by step. And before you program for timer recording, make sure that the VCR clock is set for correct time.
Posted on Apr 07, 2007
  • Pravin Gupta Apr 17, 2007
    What is happening? Still not recording images, and only static 'fuzz'?
    What about playback? Do tapes recorded elsewhere - Pre recorded ones, or friends' tapes play OK?
    I need this info also.
VCR won't record, just ejects tape
You have not mentioned the make and model number of the vcr. Any way the problem is due to end sensor or related circuit. End sensors are photo diods which you can check the shorting with a multy meter.
Jan 13, 2013 | Emerson Televison & Video
Trying to do a timer recording to a Toshiba SD-V296KU DVD Video Player/Video Cassette Recorder. all seems to go with the recorder device but when I do the playback it is a blank screen. Is that because the...
I have a Toshiba DVD Video Player/video Cassette recorder - the problem is that when I set the VCR to record for an hour it will record for less than that hour and eject the tape. Help!
Mar 01, 2011 | Sansui HDLCD-4212 LCD TV
Lost manual. Cannot get HR A591U JVC VCR program to record a future cable tv program. Seems I have tried everything but it does not record as I set up. It will record an existing show by pressing...
Timer Recording JVC VCR HR A591U
Timer recording can be programmed on-screen with
the remote control. The built-in timer allows automatic
unattended recording of up to 8 programs within 1
month.
EXAMPLE: Program a timer recording for the 26th day,
channel 125 (CATV), 11:00 - 11:30 PM on timer program
number 1 (Tape speed: EP).
When a TV is connected with an audio/video cable, turn the
TV and this VCR on and select the video input mode on the
TV.
• After timer recording is completed, the VCR turns off
automatically.
• You can program the timer recording while a regular
recording is in progress; the menu screens will not be
recorded.
• The timer recording will start at 20 seconds before the time
you predetermined.
Press MENU on the Remote.
Check the “TIMER REC SET”
option is selected, then press
ENTER.
Press SET –/+ to select one of
the program lines, then press
ENTER.
Press SET –/+ to select the
date, then press ENTER.
Set the start time, end time,
channel and tape speed as in
step 3.
NOTE: To record from external
source, press SET –/+
and set the channel to
"L". "L" will appear next
to CH 125 (or 69).
To enter other programs,
repeat step 2 through 4. Or,
press MENU twice to return
to the normal screen.
Press TIMER on the Remote.
The power will go off, the
TIMER REC indicator ( ) will
light and the VCR stands by
for recording.
To cancel a program:
Press the SET –/+ to select the
“TIMER REC SET” option in the
MENU. Then press SET –/+ to
select the unnecessary program,
and press CANCEL to cancel the
program.
Aug 28, 2010 | JVC Televison & Video
I can't find my manual. I need to hook it up so that I can record tv shows I like to watch when I am not home. But I didn't do it right and I am having trouble with the remote also.
You can download a manual from http://www.funai-corp.com/support/manuals.aspx . Click on Customer Support and then Owner's Manual. Remote problems - first try new batteries then try a universal or other replacement remote, http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=EWD2203+&uuid=12828737757670 .
For problems with timed recording, make sure the clock is correctly set. If power goes out for more than 30 seconds, the clock will be incorrect and the timer information will be off. Insert a blank tape (or one you want to record over). Then press Menu and then go to Timer Programming. (Use the up/down arrows and then hit the right arrow button.) Set the frequency of recording followed by the day and start time of the programmed recording. Then set the end time of the recording. Next set the channel number. (with some set top boxes and TV connections, choose 3 or 4 depending on the way the setting of the RF output. Then set the channel on the set top box and leave the box on.) Then set the recording speed. Press T-set to lock in the program. If you want to watch a tape before the program starts, press T-set (turning off the timer light). Remember to press T-set afterwards to resume programmed recording. You can't record to DVDs.
I hope this helps.
Aug 27, 2010 | Emerson EWD2203 DVD Player/VCR
DMR E55 timer recording won't work
Your recorder doesn´t have a digital tuner, let alone an HD one. You can record digital programs via your TV tuner if it gives a signal out. Connect your TV to AV1 or AV2 on your recorder and program the recorder to record from the one you chose. You must program the TV separately (I don´t know if this is possible on your TV) or leave it on and on the channel you want to record.
Feb 15, 2009 | Panasonic DMR-E55 DVD Recorder
Cannot timer record with Insignia HD TV and LG DVR/VCR
Make sure when you do the process two things: one, a blank tape or If it is a dvd recorder, a blank disk is inserted, in the tape make sure the tab that prevents recording is not broken.Two, before exit the timer recording menu, make sure that there is not a instruction that says "done" or "confirm" or any word meaning that all the steps went through.
Nov 20, 2008 | Insignia IS-LCDTV32 32 in. Television
Shows canceled?
Make sure u have signal on both tuners on the DVR ( check it in your set-up screen). both tuners should have the same siganl strength. Directv's DVRs, if installed correctly, give u the option of recording one channel and watch another, or recording 2 seperate channels( 2 tuners). If you are recording 2 seperate shows and u change the channel one of your recordings will cancel .
Sep 13, 2008 | Directv Plus DVR DTV Receiver / 100-Hours...
Static cling with 3 quarter inch tape
Ngotsa, Static is NOT the reason for your fuzzy audio. Old tapes tend to deteriorate because of 1.) the way they were stored (damp, humid, and extremes in temperature), or in, or near an electric field (motor, refrigerator, TV) 2.) the lubrication (which is on all tapes) has evaporated - making good tape to head contact impossible) or 3.) the oxide (the actually tape coating) had deteriorated. As far as the Black Backing, the black backing on your newer tapes IS there to prevent static, but mainly for static build-uop during high speed rewind; if it wasn''t there, you'd actually see sparks, and you'd ocassional zaps in the sound (not overall fuzziness).
Feb 06, 2008 | Quantegy 456 Reel-To-Reel Recording Tape
Sanyo VWM-900 VHS VCR Logo
130 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
matt martin
matt martin
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
