Xincom XC-DPG602 Router
Problem for Xincom XC-DPG602 Router (XCDPG602)
When I install a new router it won't connect to the internet ?
By Ross - usenet poster
Same Problem
Aug 21, 2008
-   WONT CONECT TO INTERNET-   Guest
Jun 26, 2008
-   can not load driver
-   Guest
Apr 04, 2008
-   I keep getting a message Network adapter not connected. I can connect my laptop with the yellow cable ok. However my other PCs are asking for a security key.-   Hel-2-one
Mar 24, 2008
-   I GOT NEW DLINK DI-704P BROADBAND ROUTER WITH PRINTER SERVER BUT IT DOESNT CONNECT TO THE INTERNET
-   rsgolez
Mar 23, 2008
-   when i try to setup my Netgear DG834GB/v3 the internet port does not lit. Evrything else is done according to the instruction manuel. My DSL line is 256kbpsonly.-   nifzi
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
Lizzy
Rank: Apprentice
Rating: 0%, 0 votes
You usually have to reboot the modem before it would work with another device.
The majority of cable/dsl modems bind to the network adapter's MAC address at boot time. What that means is if you disconnect the Cat5 cable from your computer and try to connect another device, it won't work until you reboot (unplug) the modem. In theory, you have to turn off the devices before (un)plugging network cables anyway ;)
Was this helpful?
Yes
No
Solution #2
posted on May 29, 2009
Somewhat Helpful)
peterjamesII
Rank: Apprentice
Rating: 75%, 1 votes
reset your IP/TCP in windows XP with the START > RUN > cmd > netsh int ip reset c:/resetlog.txt
restart the computer and you should be good to go -- after much frustration and about to reinstall windows, this was my last resort, it worked. The computer just needed to be reset for the new ISP to come into effect.
Was this helpful?
Yes
No
Solution #3
posted on Jul 14, 2008
Somewhat Helpful)
lecare
Rank: Apprentice
hi when i type the number http://192.168.0/ does not open
Was this helpful?
Yes
No
Popular Solutions for Xincom XC-DPG602 Router
Questions and Unsolved Problems for Xincom XC-DPG602 Router
Do you recommend Xincom XC-DPG602 Router (XCDPG602)?
Answer
Answer
The router power on and off when I connect the internet cable
Answer
I change the upd port in emule, close emule. I then forward that port in the 2wire 2701-G, restart... (More)
Answer
Hi! I can't open ports TCP/UDP to use eMule on my router. I fixed everything with firewall but my... (More)
Answer
dgffdfgf!-- SPpider-Layouts.com - CSS Linker - Generator - MEDIA BOX -->
9 Other Users Have The Same Problem - Continued
Comment by elgori, posted on Jan 31, 2008
I can't get internet connection with a window computer how can I fix the problem ?. I have already check all the IP address and all the DNS and everything is OK but I can't conect to internet
Comment by Guest, posted on Jan 02, 2008
after installing router could not connect to server. unpluged and pluged in again. swopped ip subnet and gateway address with server modem, no luck. have enabled automatically uptain ip address, loads more still no luck. possibly bug during reboot? what do you think?
Comment by zeyar, posted on Dec 19, 2007
i cannot set up the prestige 334 router with the computer.i can't go online.but when i use the moden cable i can go ,why?pls may i know it and how to solve it out?
Comment by Guest, posted on Dec 17, 2007
when i connect the router in the system then my computer will not connect to internet
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Xincom XC-DPG602 Router:
Top Router Experts
Rank: Guru Guru
Solutions: 1349
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
