Question about GE Spacemaker JVM1640SJ Microwave Oven
Microwave is not working
I put frozen sausege in the microwave and set it for 1 min (not deforsting, regular 1 min) and after 10 sec it made a loud sound, i though the sausege pupped but it was from the microwave i guess since it not heating anything anymore,
is there a way to fix it or i need to replace it?
  • 1 more comment
  • bagutr Dec 22, 2008
    spacemaker XL1400
  • kadams84112 Dec 23, 2008
    same thing, every thing on the oven works but the ability to heat.
    Thanks
  • kapeyton Dec 27, 2008
    Our unit does not heat and now makes a loud humm when running. Also a smell of burning wire.
  • GE Master
  • 9,098 Answers
With the symptoms you have, I would most strongly suspect a blown high voltage rectifier diode or a bad magnetron, or a loose and possibly corroded connection on the magnetron's terminal.
The diode is a fairly cheap fix, and the mag will cost more.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
(if it's not shorted or burned, it's probably okay)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Dec 25, 2008
How do I set the clock on a Panasonic microwave nn-e271wm
To set the clock, you need to press Timer/Clock twice. Then press the 10 Min keypad several times until you get to the correct hour. Then press the 1 Min keypad as needed to get to the closest 10 minute period below the current time. Finally press the 10 Sec keypad several times to reach the current time. Then press Timer/Clock once to exit the time set feature.
Panasonic has the manual for the NN-E271WM on their downloads page: http://www.panasonic.eu/Downloads/en_GB/popup.html . Enter the model number and then click View. You will need to accept the Panasonic Terms Of Use and click View again. The direct link to the manual is currently http://tda.panasonic-europe-service.com/docs/2z5845f124z3z39cabz656ez706466z25z9709ff8b3ba329b0c218b9bf248a6442e93022b3/tsn3/data/ALL/NNE281BMBPQ/OI/912715/NN-E271WME281BME281MM.pdf . See page 21 in the manual (23 in the PDF) to see the procedure.
I hope this helps.
Dec 05, 2016 | Panasonic Microwave Ovens
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Can't set the clock on a 1987 Quasar Superwave convection Microwave MQ8777BW
I had a similar problem--no manual--but found this way to set the clock:
1) Be sure colon is flashing (unplug and replug)
2) Press the 10 HOUR/MIN, 1 MIN, 10 SEC/MIN, and 1 SEC/MIN buttons until the correct time displays.
3) Press the CLOCK button.
Hope this helps.
Mar 24, 2010 | Microwave Ovens
OVERHEATING - Magic Chef Microwave M# MCO160S
Generic questions and comments:
Does your microwave have a "popcorn" setting and are you using it? Is there a rotating table in your machine? Is your popcorn bag elevated on top of a bowl or similar? Are you using some other "sensor" setting? Can you use straight time setting and get it to go past the 1 min 45 second mark?
On my microwave, it takes just about that much time and the popcorn is done ... BUT only if I elevate the bag to about the middle of the oven.
Let me know if this works for you.
a
Sep 21, 2009 | Microwave Ovens
The timer is running fast. It counts down 1 min in 5 sec. Clock and other functions appear to be working ok.
The unit is set in demo mode, Check your owners manual for instructions to get back into regular mode.
Jul 25, 2008 | Maytag Microwave Ovens
Sanyo microwave EMS667W, diff high power ratings
A couple of things: If the dinner is in an aluminum pan, DON'T put it in your oven. Typically, high power units need about 3-5 minutes to heat a dinner so you should have heated it through. The power default is usually full power. Usually, there is a minutes button that should give you incremental minutes for programming.
Try using a standard nonmetallic cup (beaker) and fill it with water. Heat for 2 minutes. The water should be boiling hot. If not, your oven is not doing it right.
Mar 10, 2008 | Microwave Ovens
Microwave dying
next time set a cup of water inside and set it for 1 min press the start button then hold the door in see if it runs thru the cycle let me know
Jan 20, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
74 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
