Question about SanDisk Sansa e140 MP3 Player
Screen backlight works but nothing shows on screen! HELP!
Hello, Yesterday, I went to turn my e140 on and it stayed on for a little while and then shut off, so I replaced the battery and pressed the Power button, it turns on, the back light on the LCD works, but no text or anything shows up on the screen, but it still plays MP3's, its so frustrating I cant see what Im playing. Also I updated the firmware and it does the same thing, but this time it wont play music. I want to exhaust all my options before I give up on my Sandisk e140? Is there anything else I can do?
SOURCE:
Syd_
  • 47 Answers
SOURCE: My Sansa e250R, 2 gigs, froze. Help!
It seems like your E250R is experiencing a temporary system error due to a corrupted song, and needs to be reset. Try to "Soft Reset" your player, press and hold the "Menu" button until the LCD light and scroll wheel light turn off. Since the player was probably left on for more than 7 hours (as you indicated), you would need to re-charge the player before proceeding further. Charge it for at least 2-3 hours. Next, try to format the player to rid of any corruption then re-transfer the songs. If you have subscription songs, then I would suggest to delete the song you last played which caused the error. I hope this helps. There is another solution for the player, but for now this might actually resolve the issue. Let me know the results. :)
Posted on Apr 23, 2007
informatica
  • 1114 Answers
SOURCE: SanDisk Sansa e260 MP3 Player
To reset the player hold in the power button for at least 20 seconds, when you release the button the player should restart on it's own. If it doesn't then try again holding the power button for a little longer. If for some reason the player becomes unstable and resetting doesn?t resolve the issue, then try the Sansa Connect Recovery Tool which will clean up your player and restore it to factory settings. You can download this tool & get instructions on it's use on the following link: http://www.sandisk.com/Retail/Default.aspx?CatID=1532 Please update the question & let us know if the information given was useful to you - Good Luck!
Posted on Aug 15, 2007
SOURCE: BAD TRACK ONCE AGAIN JUST WONT PLAY ANYMORE
You have a corrupt file - bad file...
Corrupt files for sansa -
Plug your player in, in MSC mode.
Right-click on it.
Click "properties"
Click "tools"
Click "Error Checking"
Check both the boxes on the error checking window that pops up, and click start.
After it finishes, check your player to make sure your player is normal.
If that don't work then format = http://www.sandisk.com/Retail/Default.as...
Posted on Oct 10, 2007
SOURCE: How to unfreeze mp3 player
Try Holding the Power Button for 20 sec for a Power Reset of the device Turn on the Player ,hold the Power button for 5 sec.
Posted on Mar 28, 2008
  • 684 Answers
SOURCE: sandisk e140 mp3
Try to Format the Mp3 player wat u can do is Connect the Mp3 player to the computer go to My computers there u will find the
Mp3 player as a removable disk just right click on it and click on format and format it it will solve the problem
Posted on Aug 03, 2008
My acer is not coming on ,there is power going into my lap top but the screen is completly blank?
Bring your laptop under sunlight. If you look very closely and can see your screen then your backlight went out. Otherwise there might be a loose/broken connection to your lcd.
Jul 03, 2012 | Acer Aspire 5535-5050 Notebook
HP Pavilion g series g7 black screen but occasion flicker shows it is up and running.
Hook a spare monitor to the video output usually on the back, if picture is okay! the problem lies in the inverter board, "just below the screen" or the backlight behind the LCD display, or the video cable from the screen to the motherboard has come loose from the plugin. But if both show the same symptom it means the Video Graphics Card is defective, normally built into the motherboard.
Apr 01, 2012 | HP Computers & Internet
Hello, When i turn my computer on the screen clearly turns on however there is nothing on it. It is just black but that sort of off black that is lit up. It makes some sounds as if it is doing something...
Hello !
Connect an external monitor and if it works, your problem is the display's backlight or inverter board.
If you were experiencing discoloration in the screen (pinkish lower light hues) before it failed, that would indicate a CCFL backlight issue. If the screen suddenly went dim on you rather than a slow degradation the inverter would be indicated.
In either case, a technician in your area should be able to help. Evaluate to see if the repair is cost-effective.
Hope this helps.
Oct 28, 2010 | Toshiba Satellite M35X-S149 Notebook
I have been using a Toshiba laptop model "Satellite A135-S2276", since January 2007 without any problem. Yesterday morning I was using the machine and took it to the university in my bag and in the...
Hello !
Since an external monitor works, it is the display's backlight or inverter board.
In either case, a technician in your area should be able to help. Evalaute to see if the repair is cost-effective.
Hope this helps.
Oct 18, 2010 | Toshiba Satellite A135-S2276 Notebook
3 year old 42in LG LCD TV scrren went blank
You will either have a fault with the inverter board which drives the backlights or a faulty backlight in the screen. If the problem is a backlight then a replacement screen is the only cure. One or the other is breaking down after it has been opn for a certain period of time, have an engineer call out & check with a tester if it is a screen problem.
Dec 19, 2009 | LG 42LC2D 42 in. LCD HDTV
Samsung monitor picture clicks off after 2-5 seconds...
Yes, It sounds like the backlight inverter circuit is shutting down. No inverter power, no backlight. On some monitors the inverter circuit will shot circuit the power power supply which makes the power light flash on some it just kills the backlight. You can usually check with a flashlight. Hold the flashlight pointed at the screen and see if you can see any of the icons or background picture. If you can then it is the backlight circuit or backlight tubes, usually the circuit.
Buddy
Jul 24, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Monitor stuck on black, menu buttons not responding
It's sort of a solution, but I work in a computer shop and got this screen in yesterday. I looked at it closely and it's actually the backlight that died. I pulled it apart and found that three of the 820uF/20V capacitors had swollen up. If you replace them then you should be fine, but I went for a different approach and took the inverter board from a laptop and put the in the screen and used an external power supply. It's a bit dark but it works fine now.
Aug 08, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
LCD backlight not working
Hi.....It would appear your backlight has "blown" (it is just a thin,long bulb in the bottom of your screen)....It will need replacing ....Although you could purchase one yourself to fit it would be best to leave this job to a service engineer
Hope this helps
May 14, 2008 | Compaq Presario M2000 Notebook
Screen
Change Batteries
Oct 11, 2007 | SanDisk Sansa e140 MP3 Player
SanDisk Sansa e140 MP3 Player Logo
42 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
