Question about Toshiba TN55X81 55" Rear Projection Television
Lines on tv screen
When tv in on, lines are on the screen and it seems that they move from side to side
Sorry to inform you, but you need to have the processor or "brain' replaced. Mine did that while it was still under warranty and toshiba took care of ir qujickly and free of charge. Toshiba customer service is excellent. Give them a call. also I recall hearing about a defective part that Toshiba will replace free of charge. but give them a call and see what they will do for you.
Posted on Dec 22, 2008
  • hankinsrl Dec 22, 2008
    I think that processor is called the light engine. I came here because i have a new problem now. it made a pop sound and the picture went out. If I have any more problems with this thing I'm pitching it in the trash.
How do I fix vertical lines on my TV?
Line Defects On Vizio TV Screens - Vizio TV Help
vizhdtv.com/line-defects-on-vizio-tv-screens/
Aug 26, 2015 - If you see a line on your TV screen it might be the result of several causes. Some might be simple to fix and others may actually require you to replace theTV. Pixels on a TVs display panel are organized in groups of straight vertical lines. ...Notice the line defect above is red but they can be white, green, ...
how to repair vizio lcd tv vertical lines then fail - YouTube
? 17:05
https://www.youtube.com/watch?v=YUKMl7_19gk
Jul 5, 2014 - Uploaded by bam6972
how to repair vizio lcd tv vertical lines then fail ... I do know quite a bit, not everything but I do know my fair share about tvs. this tv needed a new ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Apr 25, 2014 - Uploaded by ShopJimmy.com
TV Repair help with troubleshooting lines on your TV Screen. ... I have Vizio M470SL. My TV has .... Why does my T.V. suck Don't buy Rca T.V..
Jan 19, 2016 | Vizio E480-B2 48" 1080p 60HZ LED HDTV
When i turn my vizio on is all it does is display vertical lines from top to bottom
mychaelmuch6
Go to menu.
press screen selection
just follow steps on how to clear or reset T.V.
Jul 23, 2012 | Vizio M420VT 42 in. LCD HDTV
Every day when I first turn on my LG HDTV model 42LH30 it has the left side completely black but the right side seems normal with a distinct center vertical line. After a few minutes the left side gets...
LCD TVs are side lit with either cathode tubes or LED's (depending on the model). This saves space and allows the TV's to be so thin. The newer LED TV's are backlit, so there is an array of LED behind the screen, but because your model is side lit, most likely with a cathode tube, that the tube is on it's way out and takes an excessive amount of time to warm up and get to full brightness. You culd try looking up a part number through LG, but my guess would be it's expensive and not easily replaced. Perhaps contact a local electronics store to see if they ofer repair service and see how much it costs versus buying a new tv.
Mar 02, 2011 | LG 42LG30 42 in. LCD HDTV
Mitsubishi 40" TV, LT-40134 Vertical lines on left side of screen
I've got the same TV with the same problem. Sometimes by moving it on the stand the lines will go away but it only sometimes temporarily fixes the problem. For a while it seemed like it needed to heat up to go away but that is not the case. It seems like there is a bad connection somewhere but i cant seem to find it. One day, one thing will fix it, then the next day it wont do the trick. It gets very irritating.
Oct 09, 2009 | Mitsubishi LT-40133 40 in. LCD HDTV
Blue red green lines around people images
this is caused by some kind of electrical interference. this can be caused by cd players,speakers, etc being too close to the tube. after you find the culprit and remove or move, unplug tv for about 10 mins, then plug back in
Sep 06, 2009 | RCA F32649 32" TV
Distorted picture on a mitsubishi ws-55613 tv
Their is no more you can do.
Seen this before.
You need a professional.
Stop using the TV until it is repaired.
Continue to use the TV and your problems WILL multiply.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Mitsubishi WS-55613 55" Rear Projection...
Wavy Lines
some type of electrical feedback try upgrading your cables or tightening the ones you have. what might work best is a line conditioner i filters out any feedback you may be getting and cleans your power supply they cost from 50.00 and up best buy or circiut city both carry them or online as well
Jul 17, 2008 | Sony KP-53HS10 TV
Red Vertical line across tv screen.
remove and reseat the system board if that doesn't cure it replace the system board part number AA94-15695A get it at www.vancebaldwin.com price $158.90.
this is what the board looks like
May 15, 2008 | Samsung TX-R3080WH 30" TV
Diagonal lines
Hi It's difficult to be sure without being able to see the lines myself, but what it sounds like is some stray RF is getting into your video signal. Although your cables are supposed to be shielded, this is a common problem. The first thing I would do is move the cables or cable you are using, in relation to any power cords hanging down behind your equipment while someone watches for the lines to change or dissapear, and is that has no effect, then if possible change the position of the VCR in relation to the tv, so that if for example it is under the tv, move it to the side, or farther away, and the lines may very well dissapear. That problem is due to a common interaction between the tv and vcr where there is not enough shielding, usually inside the bottom of the tv set. Hope this helps, good luck!
Feb 11, 2007 | RCA VR546 S-VHS VCR
Toshiba TN55X81 55" Rear Projection Television Logo
55 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
