Question about Sony Playstation 3 (PS3) Console
I have video feed but no video feed-had recently ran console on an HD tv with HD cables but now i have it on another tv that is not HD using the regular AV cables-am wondering if i need to reconfigure the ps3 from HD setting?
  • 40 Answers
Yes you do, to reset the PS3 just press the power button and hold it until you hear the second beep, then let it go, your ps3 will go through the video setup again.
Posted on Dec 22, 2008
Hello, I recently hooked my Xbox 360 up to my surround sound system using a digital optical cable ran from the xbox to the TV (optical cable from 360 to sound system) Sound and video works great for...
HDCP is the "handshake" protocol used by the Xbox to communicate via HDMI to your TV. The optical cable wouldn't have anything to do with this error. So far the only solution that's been found to this issue is to ensure that the HDMI cable is properly plugged in and power off/on both devices and see if the handshake is restored. If this doesn't work you may need a new HDMI cable.
Jun 27, 2011 | Microsoft Xbox 360 Console
I have a ps3 that i tried to hook up to our emmerson tv through an hdmi cable and the tv screen says format not supportedf why?
If you recently moved the PS3 from one tv to another, it's setup to work on that other tv.
Press and hold the power button on the PS3 until you hear a beep. This should default the video output to whatever is plugged in and the PS3 should output normally via the HDMI connection.
Mar 05, 2011 | Sony Playstation 3 (PS3) Console
Hi I have recently purchased a HD TV I connected my playstation to it via HD cable and I cant seem to get it to work on my old TV now can you please help? Kind regards Jackie
Yes,Go to your PS3 settings, and go to your videooutput settings, there you should be able to selext AV cable or HDMI cable. If not, let me know!
Grtz!
Sep 28, 2009 | Sony Playstation 3 (PS3) Console
No picture, only sound through HDMI port
You have the video [yellow cord] on the wrong rca jack. Or a bad video cord. Should be easy to fix.
Mar 24, 2009 | Sony PlayStation® 3 (60 GB) Console
I recently purchased an xbox, but because of the cable box, i dont know to to get video
Your cable box and TV should have RCA input jacks (Red, White, and Yellow) Red & White are for Audio and Yellow is for video feed...
HD Receivers & HD TV's are just slightly more upgraded with better video feed connections.
HD video can use three color coded RCA jacks for the video feed or a HDMI cable; if you can use the HDMI connection on your TV I recommend using that because it's less confusing to plugin the input cables. Try turning your TV to it's side to see what inputs you have available to connect your device to.
After you have it pugged your device into the input jacks press the "Input" key on your TV remote and power up the device.
Most TV's have more than one input, so you may have to cycle through the TV inputs by press the input key again until the video feed is displayed.
(If you don't have a "input" button on the TV or remote control you can try entering channel "00")
Nov 28, 2008 | RCA T09081 9 in. TV/VCR Combo
Can't get video via HDMI
Go to here
will tell you how setting Video output
Nov 12, 2008 | Sony Playstation 3 (PS3) Console
HD feed problem
this tv can only process 480p and 1080i as hdtv signal. Check your motorola to see if it is outputing something like 720p....
Sep 17, 2008 | Philips 30PW850H 30" TV
Xbox
what HD is your TV? 720p, 1080i, or 1080p? have you tried using all these HD settings?
Dec 26, 2007 | Microsoft Xbox 360 Console
HDTV Cable box conflict
This set does not support 480I in the DTV mode, only 480P and 1080I is supported. Try setting the analog setting in the cable box to 480p and that should take care of watching the set in DTV. Most cable boxes have a setting for format changes in the customer menu, depending on the type of box. If you are able to change the format, then the other inputs will not work since they need a 480I signal, as well as VCRs. Another setup could be to use the S-Video cable or Video input jacks to get a better picture in 480I instead of using the cable input. However, when changing from HD to Analog, you will have to change to the correct input on the set as well. Hope this helps.
Dec 24, 2006 | Samsung HCJ655W TV
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
