Question about Husqvarna Chain Saw 20" Bar
Chain oiler inop
I have a Mcculloch 435 Chain saw and the chain oiler doesn't work. Does anybody have a breakdown on what parts are in it and how the oil flows? The screws came loose on the pump and I don't know if anything is lost.
This is a common problem and requires replacement of the pump. remove the bar and chain, the pump comes loose with a few screws. under it you'll see the filter which could be clogged, but not usually as contaminants are not likely to enter the tank. Small engine shops can order the new pump for you, hope this helps
Posted on Jan 02, 2009
How to fix chain saw automatic bar oiler?
possibly plugged up with sawdust blow clean with air compressor
Feb 16, 2015 | McCulloch Garden
MCC1514 oil
Most any chainsaw , chain oil . Just so it is not dirty and will not clog the oiler.
May 17, 2014 | McCulloch 14" Electric Chain Saw Mcc1514
Mcculloch Mini Mac 30 Oiler does not work. cant figure out if it is the Oiler or the manual pump to feed the oiler
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Dec 11, 2012 | McCulloch 1975 Mini Mac 30 Chain Saw Sales...
Mac 3816 chain oiler doesn't work
Contact us
User manuals
McCulloch Service
Nov 21, 2012 | McCulloch Fuel Gas Tank 3816 Maccat 18 16...
McCullough Eager Beaver model#40010205 392 chain saw manual/parts
Contact us
User manuals
McCulloch Service
Nov 19, 2012 | McCulloch 14" Electric Chain Saw Mcc1514
Husqvarna chain saw oiler problem
I fear you are correct about the oiler problem. I see a lot of oiler problems on these saws. Sooner or later Husky will have to address it. Ask the dealer about modifying your oiler; the 350 has an adjustable and might fit 1 or both of these saws. I think Husky needs to admit the nonadjustable is a mistake, and come up with a fix.
If you want to do some research start with the IPLs here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
Please post back (below) with what happens at the dealer. Take your buddy and his saw with you! Good Luck. HTH
Lou
If Husky starts modifying all these with 350 oilers I want compensation...LOL
Feb 17, 2010 | Husqvarna 450 e-series 18" Chain Saw
Mcculloch eager ****** no oil going to chain
The oiler pumps on Macs are the usual suspect, try this:
Oil System Plugged.
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar) Clean the saw oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw. If no, continue with 2.
  2. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out (clean or replace, difficult to determine serviceability). Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Build an IPL number like this:
McCulloch Manual
Illustrated Parts Lists: (IPLs) are fairly simple, on the underside of McCulloch saws is a black and yellow tag; the upper number (“Power Mac 320” 600021H) is the model, below it a serial number (11-18555). These 2 numbers are combined to create an IPL number (“Power Mac 320” IPL number = 11-600021H). The IPL number can be used to find the correct IPL for every McCulloch parts supplier I have found. If the parts supplier only list part numbers the proper IPL is the source for the part number.
If you can not find parts please repost with the IPL number and I will share my secret Mac parts source.
Lou
Dec 03, 2009 | Drills
My chain saw is a Mc Culloch - 2116 AV model bought in 1994-
This is a little complicated so I’m going in small steps.
http://www.m-and-d.com/parts.html
Click “Illustrated Parts Diagrams ON LINE”
Click “Click Here for Parts Lookup”
Changes to “Select OEM” Window reads “Briggs & Stratton ▼” Click the arrow and select “McCulloch Power”
Click “Gasoline-Powered Chain Saws”
Click “11-600035-20”
Click “Powerhead Assembly” Item 1 is the oil pump $9.48
You can construct a veryry detailed parts breakdown for your saw with a little effort. I recommend you do it.
If you were looking for a sprocket earlier it is on the same detail page as the oiler $12.05.
There is a shipping and handling charge from M & D (about $9) if all parts in same container only one fee.
I’ve found McCulloch parts here I can get no where else and they are reasonable.
Given this detail and a little effort on your part she can oil again. Even this thread is closed you can still add to this thread below the advertisements. I'll try to remember to check for additional questions. Good Luck with your project
Lou
Nov 02, 2009 | Garden
Oiler does not work on Mac 3200 chain saw
I cannot find any 3200 series IPLs. Individual models can be found here:
McCulloch IPLs
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
If this is a Chinese Mac (MTD) they are very difficult to work on. Most saw shops will not repair one. GL
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
Lou
Oct 20, 2009 | McCulloch Garden
Can't get the chain oiler to work. Using standard bar oil.
You can always put some penentrating oil in the saw oil tube by the bar, spray it in with the plastic straw attatched. Sometimes this will clean things out. As far as the tube being un attatched,,,, taking case apart is usually the remedy - kinda takes a while... :) Hope this helps you, Rick.
Apr 19, 2009 | Garden
Husqvarna Chain Saw 20" Bar Logo
209 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Mike Squire
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
