I have usb headphones a few years old. Will not work with vista
The insignia headpones not conet whit my latop
Posted on Dec 22, 2008
No sound upon installing E-MU 0404 pci card and driver
Hey ya'll.
I had the same problem with everything installed,icons on the screen etc...I took my stuff to my computer wizard and he came with the following solution which is:
Make sure that you have a Windows XP "SP2 or GREATER" this is the kicker.Go to the requirements sheet if you need more info.
Anyway I did that upgrade from SP1 to SP2 and it works like a charm with pristine sound.
Good luck fellows.
monsieur M.
Mar 18, 2009 | E-Mu 0404 Sound Card
Western digital usb hard drive doesn't work with windows vista
Windows Vista is still playing catch up with compatabilty of devices.
Makes you wonder why you left XP doesnt it? i do this for a living, and i will not touch Vista for a few years yet, while they work the bugs out.
Jan 19, 2009 | Western Digital Computers & Internet
Dell inspiron 1520
Try uninstalling the software, then re-install it again and only plug the headphones in when asked to do so, this will enable the program to pick the headphones up and install the correct driver, if windows picks it up as new hardware and tries to install the drivers for it then it will not work correctly.
What version of vista are you using 32 or 64?
Nov 21, 2008 | Dell Inspiron 2200 Notebook
MB ports no longer working
Does the probem persist even if you disconnect the USB headphone? If it does, then it points to problems somewhere else in your system. If it does not, then it's very likely that the USB headphone itself is the cause.
USB headphones aren't like headphones that you just plug into your soundcard. USB headphones has their own "soundcard" that's built into the device itself. Thus USB headphones will work regardless of whether or not you had another soundcard installed. This is usually USB headphone's benefit, not being dependent on other soundcards and having its own discreet settings.
In your case though, it's also likely that the USB headphone's driver itself is causing conflicts with other parts of the system. If this is the case, it would explain why your system is freezing.
As far as the longevity of the motherboard itself... these days computer chips are producing so much heat, it's very likely that motherboards/CPU/memorhy do not last longer than 3~5 years. The parts simply break down much faster than they used to.
Nov 05, 2008 | PC Chips P21G (881038000916) Motherboard
Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
Jun 17, 2008 | Insignia Bluetooth Wireless...
Noise concelling head hpones
Same here, my QC 3's stopped working, bought a new battery and nothing happened. Called Bose 1-877-210-3782 followed the prompts for "english" and "headphones". My QC 3's are 3 years old and out of warranty. Bose agreed to replace the headphones for $75 with free shipping. Better than paying a few hundred. Replacement set will have 1 year warranty.
Apr 27, 2008 | Bose QuietComfort 3 Acoustic Noise...
Plantronics Bluetooth Headset P590
This is a "known issue" that I have raised to Plantronics. Whether they do anything about it, remains to be seen. The workaround I have discovered seems to work with both of my P590 headphones that stopped charging:
1. Plug in the USB charging cable to a laptop or computer that is powered on.
2. Connect the USB charging cable to the headphones
3. Connect the 3.5mm headphone cord cable to the headphone output on the laptop of computer (this is the long cable with the normal 3.5mm stereo plug at each end)
4. Plug the other end of the 3.5mm cable into the P590 input.
The headphones should start charging.
Carlos (New Zealand)
Jan 28, 2008 | Radio Communications
Windows vista
If it's a few years old, then probably Vista drivers are not available. Check on the website of the supplier / manufacturer.
I'm afraid Vista will cause a lot of people to buy new hardware because the driver isn't available.
Dec 03, 2007 | Computers & Internet
209 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
