Question about Refrigerators
Hi, I need some help. Our 10 month old Dometic 3 way fridge RM 2553 developed a cooling problem due to not beeing level. What can I do to undo this ammonia block. Took the M-home for a drive but no result. Peter
    President:
  • 2,692 Answers
I have read in the RV mag that some have turned them upside down and let them sit for awhile and it fixed the problem.
Posted on Dec 22, 2008
It was working fine it was unplugged to be moved now it wont work on electric or gas its a rm 760 gas or electric domestic
When operating on Electric, if the rear of the cooling coils get warm and the fridge is level, but the refrigerator does not get cold then it is more then likely your cooling unit that has failed. Visit ArctiCold Refrigeration We keep it cold for info on replacement cooling units.... I have also attached a video with tips on diagnosing the RV fridge,
Arcticold New replacement cooling units can be purchased from Ebay Dometic RM760 Brand New Manufactured Cooling Units LIFETIME WARRANTY
Sep 16, 2013 | Dometic Refrigerators
Dometic RM 4224 won't cool on gas or electric. The stack in the back gets super hot, the fridge is not cool at all.
First ensure that the fridge is level. If the fridge is level and still not cooling while there is heat on the rear of the fridge, then you will require a replacement cooling unit. Give Arcticold a call 1-888-782-6665 Web site: ArctiCold Refrigeration We keep it cold
Online Store: http://www.rvfridgerepair.com/
Aug 22, 2013 | Dometic Refrigerators
Dometic Refrigerator Model RM 2820 Stopped working purchased 5-4-2004 . Tom Collins
Hi Tom,
If your fridge quit working altogether, check your DC fuses in the fuse box, as well as the back of the fridge under the black plastic cover (3 amp). Though the fridge uses LP and 120vac to cool, it is controlled by 12 volts.
Apr 30, 2010 | Dometic RM2620 Refrigerator
Freezer working, fridge isn't.
It is possible that your cooling unit is failing due to a blockage. The solution used to cool starts at the top of the fridge and works its way to the bottom. If there is a blockage in the cooling unit it could produce the symptom you have explained.
Jul 06, 2009 | Dometic NDR 1292 Refrigerator
My dometic 2553 3 way fridge wont get below 10 degrees celcius
my 3-way fridge won't work on anything, coils in back get hot but nothing to worry about, hoot.
Dec 09, 2008 | Refrigerators
Silhouette by Dometic RV fridge
Tuna, it sounds like your thermistor is bad. Once the fridge reaches 40 degrees, the thermistor is supposed to tell the board to stop cooling and maintain. You can test it with an Ohmmeter.
May 07, 2008 | Dometic RGE400 Top Freezer Refrigerator
Refrigerators Logo
162 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
