Question about Mitsubishi VS-1250 TV
Mitsubishi black diamond tv
My girlfriend bought a 14" black diamond tv two years ago, and now when she turns it on, the image appears briefly, 2/3 seconds, and then goes bright blue... The entire screen. The sound is still audible, but no picture. She never turns it off, except by remote. I turned it off at the wall, leaving it overnight, but this has not made any difference. Can you suggest anything. The tv has hardly been used. Thankyou so much.
    President:
  • 1,284 Answers
Might be a bad CRT or bad video output IC that drives the CRT that would cause this issue.
Posted on Apr 07, 2007
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
Blue diamond 32" tv bought just more than 12 months ago. no picture. A BLUE SCREEN FLASHES BRIEFLY FOR A SECOND AND THEN TOTAL BLACKNESS
Contact any private service technician. Never go to the authrozed service center for Nelco to rectify this fault. In this case. surely; you'll be cremated there. Gopakumar Gopalan Google
Mar 07, 2015 | Televison & Video
Right half of LCD screen goes dark. Like the brightness and colour are bleeding away. The image is still slightly visible beneath the dark. Some horizontal lines also appear across the entire screen, about...
I have the exact think happening on my Samsung LN46A530 and it has just been 2 years since I bought it. There better be a cheap fix for this because a $2,000 product has to last a lot longer than 2 years.
Aug 21, 2010 | Samsung LN46A530 46 in. LCD HDTV
I have a Mitsubishi DLP WD-57734 and white spots just started appearing I have owned the TV for 2 years and only one person in family uses it and not video games have replaced the lamp on time
The projection engine have problems,it the cause.Two years tv shouldn't have this problems already.Call talk to mitsubishi,might get some help the cost of the repair.
Jul 03, 2010 | Mitsubishi WD-57734 57" HDTV
I have a VX1962WM monitor. When I power up my PC I can see an image briefly then the screen goes black. When I power the monitor down and back up I again see an image briefly and then it is gone. I have...
That's right, the problem is related to inverter, but source of it - backlight lamps (if you see an image for fractions of seconds) or MOSFETs (if you see an image for few or more seconds). Image shows up, that means inverter starts, but then goes off because inverter controller turns into protection caused by something. Checking lamps is not that hard. Disconnect all cables coming from the screen and remove chassis with PCBs, so you will keep the display itself only. Next, at the edge where high-voltage wires are coming from, there you will see tiny philips screws, take them off. Then gently and very straight pull lamps assembly off the display, one and then another. If lamp is bad you shall observe contrast black ring or black dots near to the electrodes. Bad lamps must be replaced, you can buy them on ebay, for instance, just search CCFL 19". Or, if you don't care about total brightness, you can substitute faulty lamp with 27 pF 3kV capacitor, soldered across appropriate HV-connector on the inverter board - this will work also.
Sep 14, 2009 | ViewSonic VX1962wm LCD Monitor
HTC Touch Diamond - Powers up and down while plugged in
from a power off device.
press and hold the center joystick button, and the volume down buttons.
dont leave those two!
and now power on the device. wait for a gray screen asking you to make a clean boot. press the volUP or volDOWN button and after about 5 minutes your device will make an hard reset (clean boot) and will restore it to factory settings.
good luck!
Aug 29, 2009 | HTC Touch Diamond Smartphone
Mitsubishi 1080 diamond tv screen turns off
Your tv has a lamp inside (refer to your user's manual) make sure is in good condition.
Mar 21, 2009 | Mitsubishi Diamond WD-65831 65" Projection...
VS 7071
Do a hard reset or factory reset and it should work again
Dec 15, 2017 | Mitsubishi VS-70707 70" Rear Projection...
Televison & Video Logo
247 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
