Question about Toshiba DVR610 DVD Recorder/VCR
Toshiba D-VR610KU I'm looking for an RCA adapter that fits into coaxial (screws on) on the cable box and has a male adapter that slips into female input of coaxial input of the Toshiba. I've been scanning the Radio Shack site and can't figure out which 1 it is. Can you help? Thank you
  • olgagabe Jan 27, 2009
    Yes, on 1 end. I had read a comment a while back that said I needed an RCA adapter for the end that goes into the Toshiba. The standard coaxial doesn't work. Thanks
    Problem Solver:
  • 6 Answers
All coaxial inputs or outputs on any unit is the screw-post type. The female part is a standard coaxial cable that slips onto the posts on the unit. Are you trying to convert Coaxial to RCA?
Posted on Jan 27, 2009
I moved the Mintek Tv from my bedroom to the living room, the tv cable cord will not screw into the Tv, I was told that I need a adapter, coax to av-rca, is this correct? What do you think?
Not sure due to lack of information to go on
I. think you need a tv coaxial female to f plug male adapter
really depends on the TV cable cord what is the gender of the end of the cable if it is coaxial male then the adapter needs a female coxial
if the tv has a female socket hole then the f type part of adapter needs to be a male.
The tv manual may shed some more info on the type of RF antenna coaxial connector. it uses.
RCA can be confused as av is to do with with hooking up a Video recorder with Video output being the yellow plug and audio with Red and white plugs.
http://www.4cabling.com.au/rca-audio-and-video-cable-10m.html?gclid=COyD3pvqpsUCFYqCvQodP38A1Q#.VUa9JZM_xhI
I think you need a RF coaxial adapter rather than AV RCA if you are connecting tv to a tv antenna or tv antenna splitter device.
there is a RCA standard that has adapter like below link http://www.radioparts.com.au/product/30255099/pa5099-%27f%27-plug-to-rca-socket-adaptor#.VUa7uJM_xhI
again gender types are needed to be considered before deciding if correct type of adapter..
You could research the rca rf standard to see if it is used in your country. My country uses Pal coaxial standard.
http://www.ebay.com.au/itm/like/271684688400?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=107&chn=ps
May 03, 2015 | Mintek Televison & Video
How do i get my Panasonic ct1388yd to register it's picture and its sound of my game console
The modulator is outputting channel 3 or 4 analog not digital. Channel 3 digital is not channel 3 analog. You have the opposite problem of those trying to receive TV on an older Analog TV. You need to rescan your channels to add the analog input. Assuming you TV still scan for those like mine does.
P.S. - BNC!!! Really?? I only see those on security systems these days.
Apr 16, 2015 | Sega Video Game Consoles & Games
How do I connect the coaxial cable?
This is quite simple. Your wall box is a male connector. The TV input is a female one. Make a cable with resp; female and a male connector. Unless the wall box has a 'screw on' connector. (FC10 f.i.) Then you need this special item and/or crimp tools in order to fit this FC type connector to the coax cable. Not simple.
Oct 12, 2014 | Televison & Video
CANNOT FIND CABLE CONNECTION FOR AKAI TV LCT42V6TN
They don't make a coaxial to RGB or Component adapter. I know they make a coaxial to RCA. If you go that route you would just connect the coaxial to the video. Now if you do this not sure as to what would happen with sound, if you would have it or not. It is possible but not sure. The adapter I am talking about is called a
UHF Female to RCA Male Coaxial Adapter. Which can be found at most Radio Shacks. If this doesn't work I would contact the cable company about a cable box that they could then run the coaxial to and then the RGB or Component cables to the TV.
Hope this helps.
Mar 01, 2009 | PC Connection RG6 Bulk Coax Cable, Plenum...
Toshiba Satellite- A135-S4477 unable to connect firewire
There are generally three different types for firewire connectors. In the laptops its usually the mini contact(type 2) so is even on the camcorders. on the desktop PCs and MACs however it could be. either type 1 or the type 2. There is a thired type (B) which is less common.
The link shows all the types, male and female:
http://www.l-com.com/content/Article.aspx?Type=N&ID=95
Hope it helped
/BS
Feb 24, 2009 | Toshiba Satellite A135-S4527 Notebook
Need an RCA Adapter for a TOSHIBA D-VR610KU
If the RF Modulator will convert a coaxial signal to an RCA output signal, fine however, you still need a tuner to select the channel on the TV you want to record. This unit is primarily for dubbing or copying DVD to VCR or VCR to DVD. There is no tuner in the unit to get the cable signal. Try hooking up an additional VCR, that probably has a tuner in it and use the RCA out of the 2nd unit to the RCA in of the Toshiba. Hook the coax to the input coax jack of the 2nd then RCA out to RCA in of the Toshiba. Choose what channell you want to record on the 2nd unit. You may have to choose Auxillary mode on the toshiba the press instant record on the Toshiba. Again, this unit is a Player or Dubber. Not designed to record TV shows without an external tuner. I hope this helps. If you use a 2nd VCR just to get the TV Signal, you won't need the modulator.
Jan 21, 2009 | Toshiba DVR610 DVD Recorder/VCR
Tuner replacement on RCA D52W20
If you are comfortable doing some small repair work, you might be able to fix this with stuff you have laying around.
All you need is:
1 - 8" piece of coaxial cable with male connector on one end
1 - set of RCA cables (Red/White/Yellow)
1 - coaxial coupler
2 - small wire nuts
electrical tape
Take the back housing off of your TV. You may have to unscrew the small nut holding the threaded connector to the TV. This threaded connector should connect to the motherboard with a male RCA prong that should be soldered to the component on the motherboard. You will need to carefully cut
& remove the old soldering & wiggle the connector off. This is the hardest part, but it WILL come off with a little trying.
Now get your coax cable and strip off about 2" of the black outside housing ONLY. Your solid copper` interior cable should be protected by a small plastic coating which is covered in braided wire. You'll need to be careful not to cut the braiding off. Untangle the braiding down to where your cut stops and try and get it all on one side of the cable so you can twist it all together and make a nice wire. Now strip about an inch off of your interior plastic sheathing to reveal the small solid copper wire on the very inside.
Get your RCA cable and cut about 6" off of the one yellow side. Follow the same process above to get a braided sheathing wire and a solid copper wire. Attach this yellow wire to the coaxial cable by twisting the two braided wires together and the two solid copper wires together. Use your wire nuts & electrical tape to secure your connections making sure none of the wires can touch each other.
Connect the yellow cable's male prong into the component on the motherboard and attach your coaxial coupler to the male end of your coaxial cable. If you saved the small nut from earlier, you can re-attach this new coupler to the housing on your TV. Screw your housing back on the TV and you should be good to go.
Jan 11, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Speaker wire to coaxial cable
Yes ! all you have to do is go to radio shack and tell them you want a coaxil to RCA adapter (screw coaxial into wallplate and plug RCA end into sub and your all set!)
Please rate answers and help keep this site FREE!
Thank You
Dec 28, 2008 | JVC SP-PW100 Subwoofer
Cable in connection
Most TV models/cable providers uses the F type of coaxial connector as shown below. 7c21c7e.jpg
However, some versions intended for other regions (Europe & Middle East) uses the PAL type of connector likewise shown below.
If your model uses the latter and your cable provider uses the F type, what you need is a straight F type Female to PAL Male adapter. Or it could even be just the other way around.
They are available in most electronic parts/supply store or online. You can try here, here or here.
Hope that this be of idea/help. Pls post back how things turned up, r should you need additional information and/or if your cable connectors are of different types. A photo of the connectors would be nice.
Good luck and kind regards.
Jan 06, 2008 | iLO 3200 32 in. LCD Television
Realistic
snickers1 hi, if I googled in the right scanner, yours is an older one with an antenna that screws into a stud inside the top cover. Here is a link to a site that has a lot of the older stuff covered. He's been selling CB stuff for over 30 years. You'll have to look at your scanner inside to see if it's male or female thread. I hope this helps with what your looking for,, Mechanic
http://www.kenselectronics.com/lists/amfm.htm
Dec 30, 2007 | Radio Communications
Toshiba DVR610 DVD Recorder/VCR Logo
213 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
