Question about Apex Digital GT3215 32" TV
APEX TV TV screen has a key on left bottom,needs a code to unlock tv, do not know the code need help.
  • 2 more comments
  • rob_ehlers Jul 01, 2008
    I have the same problem my kids were playing with it and I dont know how they locked it. Please help if you know how to fix this problem.
  • bartcoco Jul 21, 2008
    we have unplugged the unit for twenty four hours.
  • mikepippin Dec 05, 2008
    My daughter was playing with the remote and locked the t.v. The screen is blue and there is a red key in the bottom left hand corner.
  • shit lipps Feb 21, 2009
    same as the others t.v locked
    Problem Solver:
  • 8 Answers
Go to this web site and you will find the codes and sequence for their tv, there are two dfferent codes. www.apexdigitalinc.com
Posted on Sep 17, 2007
One day i turned on my TV and the screen is completely black and the green light keeps blinking...what should I do...
Posted on Dec 20, 2009
Press & hold the mute button, then press the "F" (function) red button, it's usually on the upper left hand side. T.V will unlock
Posted on Nov 15, 2007
    Genius:
  • 1,074 Answers
Lift out the eeprom from off the pc board and resolder it back.after taking it out it will reset itself.good luck
Posted on Apr 07, 2007
I have an apex tv that has a lock(key symbol) on the lower left corner of the screen. The tv seems to be locked how can I unlock it? I using a phillips universal remote.
Hello
Just try the following to unlock your Apex TV.
Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
  1. To use the override code:
  2. Hit the MENU key to get to the menus.
  3. Go down to the SYSTEM menu and hit the right arrow on the remote control.
  4. Once in the SYSTEM menu, go to PARENTAL GUIDE. It will ask for your code.
  5. Enter the override code listed above. From here, you can turn on and off different rating restrictions, as well as set a new code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired
OK.
Dec 27, 2010 | Apex Digital AT2702 27" TV
Unlock apex tv model # AT2702
  • If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
  • If your TV asks for a 4-digit code or password please enter 3308 or 6688 to unlock the screen or reset any preset rating levels.
  • If you have a GT2011J or GT2011S Television, hold the (Display) button for 10 seconds, it will unlock the screen. If password or code is requested, try 3308 or 6688.
Hope that helps..........
Jul 20, 2008 | Apex Digital AT2702 27" TV
Help
My television has a picture of a red key at the bottom left side. I can not unlock this, does anyone know how?
Sep 16, 2009 | Apex Digital AT2008 20" TV
Apex tv locked
Let me know if this helps.
May 24, 2009 | Apex Digital GT2015DV 20 in. TV/DVD Combo
try this manual;
[PDF] AT M C T
On the remote try pressing the ( F ) button and the mute button at the same time on your remote control.
Here's the link for the 2402s manual:
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=4db1185db9d3369
Pass Code Menu
This menu allows you to change the access code for the Parental Guide
functions of the TV set. Pressing the “Menu” key when Pass Code
Control is highlighted. This will turn on or off the Pass Code function. With
the Pass Code function ON, you can also change the Pass Code. Use
the down arrow key to highlight “Pass Code,” then enter the new Pass
Code using the numeric keypad. Press the left arrow key when finished.
1. The factory default pass code of 6688 is also the override code, in case
you forget your new pass code.
2. The factory defaults have TV-MA and MPAA-X ratings blocked . Hope this may help you
DON'T FORGET TO RATE:
Apr 17, 2008 | Apex Digital AT2702 27" TV
HELP to unlocked tv
You will need the original remote control to unlock this set. Apex TVs use a four digit code to control the v-chip. The override code for many models is 6688. Other sets may not have one, or may have a default code of 1225 instead of an override code.
No matter what the V-chip code is set to, the override code will still work. If you have a blank screen with a red key on the bottom left, simply press the (function or F) button and the mute button at the same time. This will unlock the screen and allow you to view the channel as desired.
Mar 07, 2008 | Apex Digital AT2002S 20" TV
Apex GT2015 20 inch television
TVs Power Supply Unit may be faulty and you will have to get it fixed.
Opening up the TV may void the warranty.
Its better talk to TV Manufacturer's Tech Support.
Jan 09, 2008 | Apex Digital GT2015DV 20 in. TV/DVD Combo
Television problem
According to Apex, you can disable the parental lock using the following information.
Oct 28, 2007 | Apex Digital GT2715DV 27 in. TV/DVD Combo
My TV is completly locked up
You need a APEX remote to unlock the parental controls. You and go to there web site to get the ording info and he preocedure to unlock the tv. www.apexdigitalinc.com
Apr 19, 2007 | Apex Digital AT2708 27" TV
Apex Digital GT3215 32" TV Logo
425 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
