Xincom XC-DPG602 Router
Problem for Xincom XC-DPG602 Router (XCDPG602)
What ports do I need to open to permit VPN traffic?
By Phoebe - usenet poster
Clarification Request
Posted by raj26n on Mar 20, 2008
My internet is not working
Same Problem
Feb 09, 2009
-   Same problem. Dynex E402 will not allow VPN pass through. Opened all the suggested ports with no success. Finally opened all ports from 1 to 65,000, No good. Dynex help desk gave up & suggested contacting the Geek Squad or returning the router.-   tjwalker2006
Sep 16, 2008
-   i'm not able to connect to my VPN from home knowing that my router is 3com-   Romeo4ever
Apr 06, 2008
-   DIR-625 IPSec cisco vpn will not connect. It works with other routers but not my home D-Link. Do I need to open ports manually?? Thanks. Gary-   Gary0251
Solution #1
posted on Aug 08, 2005
Somewhat Helpful)
Beresford
Rank: Apprentice
Rating: 0%, 0 votes
For PPTP VPN connections, you need to open TCP port 1723 (for PPTP tunnel maintenance traffic). PPTP also uses IP port 47 for tunneling data. Port 47 is designed for "General Routing Encapsulation" or GRE packets.
For L2TP VPN connections, you need to open UDP port 500 for Internet Key Exchange (IKE) traffic and UDP port 1701 for L2TP traffic.
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #2
posted on May 22, 2008
Very Helpful)
RajBangalore
Rank: Guide
Rating: 95%, 6 votes
yes u have to open port manually port usually udp50
udp500 ipsec 50 udp 4500
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Dec 26, 2008
Not Rated)
steve613
Rank: Apprentice
Rating: 85%, 1 votes
You need to find out what port the VPN is running on. It could be anything. However, common VPN ports are not blocked normally and your problem is likely something else than a port issue.
Was this helpful?
Yes
No
Solution #4
posted on Nov 15, 2008
Not Rated)
adamtarshis
Rank: Apprentice
Rating: 0%, 0 votes
My dns wasnt resolving over the vpn
Check on the Transport tab of the cisco vpn client setup (under modify).
I checked "Enable Transparent tunneling" using port 80 as well as "Allow Local Lan access"
Was this helpful?
Yes
No
Solution #5
posted on Aug 30, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
to clarify, its protocol 47 that GRE uses, not port 47
Popular Solutions for Xincom XC-DPG602 Router
Questions and Unsolved Problems for Xincom XC-DPG602 Router
Do you recommend Xincom XC-DPG602 Router (XCDPG602)?
Answer
Answer
The router power on and off when I connect the internet cable
Answer
I change the upd port in emule, close emule. I then forward that port in the 2wire 2701-G, restart... (More)
Answer
Hi! I can't open ports TCP/UDP to use eMule on my router. I fixed everything with firewall but my... (More)
Answer
dgffdfgf!-- SPpider-Layouts.com - CSS Linker - Generator - MEDIA BOX -->
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Xincom XC-DPG602 Router:
Top Router Experts
Rank: Guru Guru
Solutions: 1351
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Router Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
