Question about Sewing Machines
Old Singer Athena 1060
Something is wrong inside where the bobbin sits. when the needle goes down, a metal part slides in from the right side and almost breaks the needle off. it was working fine until today when I wound a new bobbin. A thread caught down in there and was difficult to remove. since then, I've had this problem. would rather not take it into a shop during the holidays because I have some projects planned. pls help.
3 Suggested Answers
SOURCE: singer 1060
slide open metal plate, there is a little white finger button with a target symbol on it just to the left. Slide this all the way left, leaving plate OPEN. If your top needle is threaded correctly, you should now be able to push the foot pedal to sew adn the bobbin will refill. make sure not to go past the outer white line on the bobbin case. good luck. the target button will go back to the original position when you slide the plate closed.
Posted on Jan 05, 2009
SOURCE: my singer athena 2000 won't
Yes, the hook timing is off. You need to either take it to a service repair center, or do the timing yourself. If you're mechanically inclined, go to youtube and look for a video by Nilsandkatrina about how to repair your sewing machine. He gives a very good example.
Posted on Nov 29, 2011
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Bottom tension adjustment on singer athena 1060 sewing machine
Have you tried putting the Bobbin in up the other way, and sliding it through the bobbin case !!!!
Nov 21, 2013 | Sewing Machines
Threading bobbin singer athena 2009
Sorry... hate to say it but modern home singers are $%#&*@.
Have you tried a new bobbin? If the "spindle" spins... the bobbin should spin. Maybe your bobbin is busted or something?
Aug 02, 2012 | Singer Sewing Machines
Singer Athena 2009 needle hitting plastic in bobbin case
here's something to check
is the needle inserted all the way in to the needle holder?
needle--flat side goes to the back of the machine
is the needle clamp screw tight or loose?
if the needle is correctly in the needle holder & the needle clamp screw is tight --then the needle bar is out of time & need to be serviced
IF YOU DO HAVE TO TAKE IT TO BE SERVICED AFTER YOU GET IT HOME STOP RIGHT THEN & SEW ON THE MACHINE TO MAKE SURE THEY FIXED THE MACHINE & IT SEWS LIKE IT SUPPOSE TO, I HAD ONE CUSTOMER THAT TOOK THEIR MACHINE TO A SHOP & THEY CLEANED IT AGAIN & DIDN'T FIX IT BUT CHARGED THEM FOR IT & THEY BROUGHT IT TO ME TO FIX & IT HAD TO BE RETIME
did you get a instruction manual for the machine if not check at singer
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number---2009
Click search--if you don't see a manual--contact singer customer service
Feb 11, 2012 | Singer Sewing Machines
The needle goes down and jams immediately
the problem of your machine is your needle it is not in her right position, and adjust your tension.
Mar 30, 2010 | Singer 3820 Mechanical Sewing Machine
How do you thread a singer 9836c machine
I have this machine and the manual but it will be difficult to explain without the diagram. Here are the instructions without the diagram ... I'm assuming that you know some parts of the machine i.e. the foot etc
NB. thread the bobbin FIRST - points number 8 onwards....
1. Raise take-up lever to highest position on machine by turning the hand wheel towards you and make sure the presser foot is raised.
2. Place spool of thread on the spool pin at the back making sure spool cap is firmly in place to keep it on.
3. Take thread and place through the thread guide (plastic bit same side as spool pin) a under and over action. Across from this guide is a small metal wheel on top of another loop pin on the top at the front of the machine. Take the thread and put through the loop pin. 9Thread should come out on top of the pin towards you).
4. On the front of the arm is a tension wheel numbered between 0 - 8. The thread should then be placed down the front of the arm, underneath the tension wheel (behind the body part of the arm not under the wheel) and lifted up to catch the tension spring unseen behind the wheel. It should then be threaded through the eye of the metal piece (that moves as the needle goes up and down).
5. The thread should then be passed down the gap in the body work and down through the middle of the metal spiral loop in the front near the needle.
6. The thread should continue down through the horizontal clip just above the needle.
7. The needle should be place with the flat part at the back and held firmly with the screw. The eye of the needle will face you. The thread should then be threaded through the front and out the back and under the foot leaving a six inch tail.
Your thread should now come off the spool move towards the left through the plastic guide, across the top of the machine at right angles, through the metal loop; down the front of the machine (you can't see the thread as it sits behind the body) and reappears through the metal arm hole that goes up and down with the needle. It should then come down through the metal spiral and behind the clip above the needle, through the eye of the needle and away from you under the foot.
8. The bobbin needs to be wound. The bobbins are particualr to each make of machine. So only singer bobbins can be used on Singer machines. The bobbin winder is the metal pin on the right on the top of the machine.
9. To wind the bobbin. Place the bobbin over the metal pin nad push firmly down. It is located on the top on the right hand side.
10. Place thread on the spool pin as before and thread the cotton through the plastic thread guide.
11. Take the thread as before but rather than going through the metal clip on the top at the front, place it anti clockwise partly round the metal wheel on top of the metal clip (don't go all the way around) and across to the right where the bobbin has been placed.
12. The thread should be wound clockwise as many times as required not to slip off when the thread is automatically wound with the electic foot peddle.
13. Push the bobobin manually to the right along the groove in the body and press the electric foot peddle. Bobbin should wind moving the thread up and down (not necessarly evenly) and filling the bobbin. Fill about 80%. Leave a six inch tail.
14 Pull the plate forward under the needle. Place bobbin in its slot. The thread should be in a clockwise direction and when the bobbin is placed catch the thread under the groove found on the left at the top of the bobbin case. Close the plate with the thread coming out above in the slot under the needle.
15 Manually turn the hand wheel a couple of times until you can see the bobbin thread making a loop with the stitch thread and pull through.
16 Both threads should be under the foot and away from you.
17 Tension normally is around 5 -6 on the tension wheel with standard cotton and polyester cotton thread. To tighten the tension the number should increment upwards.
Machine is a cracker and according to my local shop never goes wrong. I have had mine since 1999 and that's true.
Hope this helps.... I would send you the manual but I'm not sure how you keep email addresses private.
Good luck.
Jun 29, 2009 | Singer Sewing Machines
Singer 1060
Aug 20, 2008 | Singer 1120 Mechanical Sewing Machine
Inserting needle on old singer machine
Hi Terry--
If your machine is 40-50 years old, it might be a Singer Featherweight portable. (If it is, you have one of the very best machines ever made!) On the Featherweights, the flat of the needle faces left (and the needle is threaded from right to left). The bobbin goes in a bobbin case; you'll see a small notch when you look down on the bobbin in the case. That's where the thread goes. I'll email you direct with more information.
Lookingpast
Dec 26, 2007 | Singer CE-200 Quantum Futura Computerized...
Sewing Machines Logo
387 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
