Question about Reddy Heater-170,000 BTU Kerosene Deluxe
155 My heater runs fine for a while and then it starts to smoke. It worked fine for 2 years and now has the problem.
  • BigBeave May 11, 2010
    This model can use multiple fuels. Are you using Diesel?
  • 92 Answers
Check your air lines that go to the burner nozzle for any breaks and clean all of the filters.
Posted on Jan 23, 2009
What does gm code 155 mean and how to fix it
For most models, code 155 is for a problem with the heater circuit for the O2 sensor bank two in front of the catalytic converter. It could be the sensor or the circuit.
Code 300 is for a random miss.
Code 1380 is also for an engine miss if it is from the engine computer.
Mar 06, 2013 | Cars & Trucks
J power and smokes white
Possibly a head gasket problem (as the head heats up it warps slightly, allowing coolant to seep into the cylinders, which is the source of the white smoke--steam) Is the motor using coolant?
Aug 17, 2012 | John Deere 420,1020,2010,2020,2510,2520...
The heater shorted out, sparks, electrical smoke. Is it salvagable or should I replace?
Yes you could say it has died 18 years has been very good time to look for new . I don't think you will get parts for it now .
Feb 23, 2012 | Lakewood Oil-Filled Electric Radiator...
My heater is a.pro 155 it worked fine all last year but I got it out of my storage area for use this winter. It will start an run for about 15 seconds and trips the reset on the unit. What would make this...
First, locate the true model of the heater. Pro 155 only designates a series of heaters. It does not designate the actual model or technology used.
The reset (Safety Device) is the system's safety shut off. If everything is in perfect operating form the photocell looks into the chamber for a flame. If the flame goes out (flame-out), the the photocell sends a signal to the reset and the heater shuts down.
You must troubleshoot to find out whether your problem is a fuel delivery problem or an electronics problem.
My first look would be to look into the eye of the photocell for an insect or nest of some sort. Next check the fuel tank for water or debris that may be restricting the fuel flow and causing a flame-out.
Check out this link for more tips
Nov 05, 2010 | Reddy Karosene / Desel Forced Air Heater...
What is the oil to gas ratio for a Homelite ST-155 trimmer?
40 to 1,,,40 parts petrol to 1 part oil,,,,1/2 oz oil to 1 pint or petrol
but iv all ways ran mine on 30 to 1 ok,,it smokes a little,,but if its smoking there is oil getting to the piston and bearings,,,so the engine will live a lot longer,,,my pall runs his on 20 to 1??? now that smokes!
but he's run it on this for 25 plus years??? and he gun's it to death,,
so il say no more!
Jun 13, 2010 | Homelite Garden
I have a ready heater pro 155 BTU and the sitting
I certainly can. I have a tip at http://www.fixya.com/support/r4124129-yearly_maintenance_reddy_heaters which explains what your problem is and where to get the parts and gauges to fix it. I recommend getting the better gauge if you are going to keep your heater. Let me know if you need more help.
hardrocko
Thanks for using FixYa
Mar 02, 2010 | Reddy Heating & Cooling
150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
My Dyna Glo heater forced air heater worked great last year. I run it on Diesel and ran it empty before putting it away for the summer. Went to fire it up and it wouldn't work. Replaced all of the cracked...
the filter in the tank line is partially clogged with gel from useing diesel fuel you should really use a anti gel agent when running a sulphur type fuel in a unit designed for white gas/ keosene
Jan 20, 2010 | Kitchen Ranges
Fan turns on starts blowing and a lot of smoke.
when you start it the smoke starts wright away it is not getting the right air flow takethe top part off and started see what it does if it stays running try to ajst. the fens ok .
Dec 26, 2008 | All-Pro Kerosene Garage Shop Heaters - All...
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
