Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
Olympus C-8080 LCD wont work
It was working fine no problems at all and now it wont work as a viewfinder or to view pictures. There is power getting to it because if you take the card out it shows a blue LCD screen with the words no card
  • akolaa Nov 16, 2007
    i have the same problem. I can;t view in view-finder also.
Is the battery setting set to Battery Save mode. If it is then the view screen does not work.
Posted on Sep 06, 2008
  • 594 Answers
Does it display pics off the card or menus, but no "live" views? that is a classic example of a CCD issue, common in the C5050 line due to a bad Sony suppied CCD, Not so common on the 8080 line.
Posted on Feb 07, 2008
  • Steven Wander
    Steven Wander Mar 06, 2008
    Oly has a somewhat flat repair charge for these C-8080 cameras of about 168.00. This is by far less than the cost of a replacement of this caliber. This seems to cover almost any repair short of water damage.
Hi Suddenly my g11 is blind lcd is working but camera doesn't see anything lcd is black in all modes like electronic courtain does not open exposing sensor all other functions are seems to be...
There is two ways to view your "taking picture" with the LCD and with the viewfinder, you can shut the LCD off to save battery power and use the viewfinder and that is what I think has happened. a touch of the DISP button and it will switch from the LCD to the viewfinder. here is a diagram
Diagram
With you saying the LCD is working for functions but not for taking pictures this is what I suspect is the problem.
Jan 20, 2011 | Canon PowerShot G11 Digital Camera
I have an e500. The viewer will not come on for taking pics.
Unfortunately with the EVOLT E-500 it does not have the capability for a live view LCD screen. You must shoot images using the viewfinder only. The newer Olympus SLR cameras now have both viewfinder and live view LCD.
Jul 17, 2009 | Olympus EVOLT E-500 Digital Camera
Olympus E410 viewfinder problem
As far as I am aware, you can use the viewfinder OR the live view, but not both at the same time.
This is because a mirror has to flip up out of the way to reveal the sensor for the live view to work, and the mirror needs to be in the down position to reflect the image into the viewfinder.
Switch between the two modes and double-check if there is a problem.
Also try removing the lens from the camera and checking the position of the mirror. It could be that it has got stuck in the up osition.
Hope this helps!
Jun 27, 2009 | Olympus EVOLT E-410 Digital Camera
How to view in the LCD monitor when taking picture.
Unfortunately with this camera it does not have a live view LCD screen. You will need to shoot all images with the viewfinder and then use the LCD to review them.
Nov 22, 2008 | Olympus EVOLT E-500 Digital Camera
LCD panel cracked
The price to have the LCD replaced would probably cost 75% of a new one. If you can do without the LCD and it downloads the pictures to your PC, at least you've got something.
That camera has a viewfinder, so you can still take pictures, right.
Sorry about the bad news.
Jun 04, 2008 | Olympus SP-320 Digital Camera
Nikon D50 LCD Display does not work
NatD, The D50 and indeed most SLR digital cameras [ I have a D40 ] does not allow you to take pictures using the LCD display ... this is by design, you are meant to use the viewfinder and the image you see through it is straight through the lens via a mirror block [ called a reflex pentamirror or prism ]. When the mirror is down such that you can see the image in the viewfinder it is obscuring the sensor [ the bit that takes the picture ] and when you take a shot the mirror lifts and the picture is recorded. Its this reason that DSLR's dont use the LCD to shoot, however there are a few now available that do let you do this, such as olympus, new panasonic one and higher end Nikon and Canon cameras. Hope this explains it without getting too detailed!
Dec 04, 2007 | Nikon D50 Digital Camera
Cannot see any picture in my view-finder or LCD
Sounds like a CCD issue, can yoou see menus and pre problem recorded pics on the memory cards but no live views That is a CCD issue, ala C-5050 CCD recall problem, identical symptoms.
Nov 16, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Viewfinder jammed
The mechanical link between Lens on V/F element has broken - Only Olympus will be able to do anything for you -check out the support site.
Aug 19, 2007 | Olympus Camedia C-5050 Zoom Digital Camera
C-8080 Turns off/on randomly..
Hi Galaxy,
Try running camera directly on DC from charger and see if it stays functioning.
If it does, they you either have:-
1) a faulty Lion battery
2) the battery detect circuit in the camera is faulty (reporting low battery and forcing shutdown)
3) the power switch on top of the camera may be leaky or partially collapsed
4) internal power supply circuit in camera has developed a fault.
Good luck...hope that the issue is the battery.
Kiwi-Mark
Jun 05, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
LCD Monitor on ,and the Electronic Viewfinder turned off
If you turn on the back LCD, the electronic viewfinder will remain on while in a shooting mode. There is no setting on the camera to use only the back LCD monitor while shooting. If you playback images in the Play mode, only the LCD monitor will turn on. However, if you press the Monitor button while in the Play mode, than the back LCD monitor will turn off. The image will display only in the viewfinder LCD.
Sep 04, 2005 | Olympus Camedia C-730 Digital Camera
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
360 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
