Question about Carrier Heating & Cooling
I have an electric furnace and heat pump that will at times blow only cold air during the heating season. I have checked the filter and don't believe that to be a problem. I usually have the temperature set to 74 degrees. When the outdoor temp. is extremely cold the axillary heat indicator will be on and still no heat. I can turn the heat pump off by switching to emergency heat and will get some heat from that but not as warm as I think it should be and even that will at times only blow cool air. Usually after switching between the two settings once or twice I will begin to get sufficient heat. I have checked the outdoor unit and there is no ice build up and it appears to be functioning properly. So there it is, I hope you can help. Thanks, Dan
  • 334 Answers
You are losing operation to your heat strips.
In heat pumps, there is a secondary heat source. Usually electric heat strips. (Sometimes a gas furnace, this is known as a "dual fuel" system)
The heat strips (or furnace) serve three purposes.
1 - When the system goes into defrost, the strips come on to keep warm air flowing, because in defrost mode the heat pump actually blows cold air.
2 - When its to cold outside for the heat pump to keep up, the heat strips will kick in.
3 - Emergency heat, the thermostat can be switched to emergency heat bypassing the heat pump and using only the strips.
The strips are brought on with relays, which sometimes stick or go bad.
Apparently, your heat strip relay/s are sticking open periodically and not letting the strips come on.
We can verify this with a meter. Those relays are fairly cheap and easy to replace.
Posted on Dec 22, 2008
    President:
  • 2,110 Answers
Check the thermostat and make sure the fan is in auto and not in the on position. Then check the filter to make sure it is clean. Then the fan control switch or limit switch could be bad.
http://www.hvac-for-beginners.com/
this link may help u regd this..
Goodman heating system
It really depends on the type of system you have. You will either have a furnace, high efficiency furnace, heat pump system, heat pump with gas or electric back up heat. All these systems operate differently and the problem that you are having could be caused by multiple issues, depending on which system it is. More info will be greatly appreciated. Make sure to check all filters and air flow first before going any further. The system could be over heating and tripping a limit, causing the system to stop producing heat until the unit has cooled back down.
Dec 06, 2013 | Heating & Cooling
MY HEATER BLOWS HOT AIR THEN BLOWS COLD THEN HOT THEN COLD,ICHANGED THE MOTHER BOARD, RELAY SWITCH, AND THERMOSTAT, IT IS RUN FROM A HEAT PUMP WITCH I HAD CHECKED AND IT WORKS FINE
I have a lux electric thermostat my furnace will blow out heat for about one hour to maybe three then it will start blowing cooler air,I then cut it off for thirty seconds or longer once I do that it will start blowing out heat again then it will repeat it self again what could be the problem.
Jan 07, 2010 | Heating & Cooling
Heat pump and gas furnace running at the same time.
An explanation....
When in the heating mode, all heat pumps are dependent upon the outdoor conditions to remove heat energy from the environment and turn it into useful heat for your dwelling.
Heat pumps operate more effectively in temperate climates (as in southern states) and if it's as cold as you say, then the furnace is coming on to add auxiliary heat to the space to make up for the lack of heat being supplied by the heat pump. This is normal.
Some heat pump systems are or can be equipped with a control known as a "low ambient cut out" and/or "motor master" that prevents the heat pump compressor from operating and slows or stops the condensing unit fan when it's too cold and risking potential compressor damage. When it's in the single digits outside, a heat pump is only marginally effective. and usually requires auxiliary heat (your furnace).
If the furnace keeps operating when it's in the 30s or 40s, you may want to have the system examined by a competent service technician. As always, the outdoor condensing unit should be kept clean and the furnace filter should be changed no less than monthly, unless you have an electronic air filter.
I have a Rheem Gas/Electric AC unit that provides both Air and Heat. Yesterday the heat stopped working... it blows out cold air. We've had some cold temperatures lately (low 20's) but this isn't unusual...
Heat pumps provide good heat until the tempurature drops below 35-40 degrees. After that there isn't much heat to extract from the outside air and then either the gas furnace kicks in or the electric heat strip does the job of heating the air. if you have heat strips, I would check your breakers in your panel and sometimes there are a couple of breakers right on the air handler or furnace. The ones that will be for your heat strip are 220v and will be twice as wide as your normal 110v breakers . Please don't trust a visual inspection as they can look like they are in the "on" position but are indeed tripped. Turn them all they way off and then back on. If the beakers check out you may have an open cicuit in the heat strips themselves and you will need to have a qualified HVAC tech look at your furnace to repair it.
If your furnace is a "duel fuel" and uses natural or LP gas for back up heat then your ten year old rheem probably needs a good maintenance by a qualified service tech. There is a flame sensor to clean, ignitor to check (replaces the old school pilots), burners to clean flue connections to check and much more. ALL manufacturers of any heating apliance recommend yearly maintenance. Most companies offer something for around 100 bucks. I hope this helps.
Rocco
Dec 12, 2009 | Heating & Cooling
Furnace blows cold air
Sometimes the fans kicks in by time ---or by heat...even if the heat cycles dont starts . Is this gas or electric,, name brand,.... model # ect...ect..
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Auxilliary heat just started blowing cold air
SOund like you heating element has a open limit or the sequencer is bad. Another thing that it may be is the element wire has broken. Either way it sounds like you need a technician to come out and repair.
Jan 27, 2009 | Honeywell TH4210D1005 Heater
My heat pump blows cold air for the first 10 minutes or so
Don't know how long you have had a heat pump but thats the nature of them in colder weather. Some people prefer to switch to "emergency heat" on the t-stat when temps fall below 20 or 25 degrees. This bypasses the heat pump and allows your back-up heat to heat the house. If your house is total electric your emergency heat is an electric furnace and it should handle the load if it was sized properly. Don't leave it on emergency when it warms up because your heat pump is much cheaper to operate than the furnace. As always, check your air filter since it can restrict the amount of air that moves thru the furnace, which is critical. Hope this helps
Dec 23, 2008 | Amana PTH123B25AJ Heat Pump Air...
Electric furnace blows cold air before and after warm air.
It is normal. Your house has to go down a couple more degrees because the heat pump is not working. You can solve this by rewirng you thermostat. Take off the wire that goes to Y and tape off. Then take the wires that are marked w and e or w1 and put the wires to yellow. Do not run ac with it wired like this. If you need more information please post me back
Nov 29, 2008 | Heating & Cooling
Non-working outside unit
If your unit is blowing heat inside and it's not a heat pump. It will be most likely electric heat in your case.
Sounds like you have a split unit meaning the condenser is outside and the cooling and the heat features are inside or under your home.If your Rudd is a heat-pump the outside unit will cycle/blow cold air outside in winter and hot air will cycle/blow outside during the summer season. Now, if for some reason the heat  is not coming on inside the house, would be the only reason that you would need to be concerned. Being a heat relay or breaker of could cause that problem. Hope this helps you, Sea Breeze
Oct 27, 2007 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
