Question about Rosewill R900J 19" Flat Panel LCD Monitor
The menu bar is on the side of the computer
I wanted to change it to the bottom of the monitor
  • 40 Answers
I would like the version of the version of windows even though all are basically the same so here goes.. Right click the bar and make sure it has the 'Lock the Taskbar' option unchecked, if it is unchecked, good, if it is checked, uncheck it. then you left click the taskbar and drag it to whatever side of the screen you want it on.
Posted on Dec 22, 2008
  • 58 Answers
If you're referring to the Windows Start menu, grab it with your mouse, hold down the button, and drag it back to the bottom. If you're referring to a different menu, please clarify with a comment.
Thanks,
Connie :)
How to Mod Using Modio?
    1)SB Flash drive for Xbox
    2)Choose game save you want to mod, and move it to USB
    3)Take USB out of Xbox and plug into computer
    4)Open up Modio 5
    5)Check button that says gamesaves
    6)In bottom right of window, there's a search bar, where you can type the name of the game
    7)Find a file you want to download and double click it
    8)Click button in bottom right of new window
    9)Exit out of windows and main menu for Modio
    10)Click Open save from device from main menu
    11) Leave window open, you will need it later
    12)Click on open and save on main menu
    13)Find file you downloaded earlier, and double click it
    14)Put save file from device on right side, put other file on left side
    15)Left side window bars delete them all
    16)Copy numbers from right side window, and paste them in corresponding bars on left side window
    17)Close out right side window
    18)In bottom right of remaining menu, click button that says rehash and resign
    19)Find button on open window that says Save to device
    20)Take out USB and plug into Xbox
    21)Move modded file onto Xbox
Oct 20, 2016 | Video Game Consoles & Games
Pioneer 4000 shuts off when touching anything
Reload software from Pioneers support web sight.
Jul 23, 2012 | Pioneer AVH-P4000DVD Monitor
Want to move the "menu bar" from the bottom of the
Hi tobrandon...
Hold down left click and move the mouse to the side you want the bar, the release the left click.
Bar will be on side of desktop now.
Do the same thing to reverse the change
Please take time to rate me thumbs up
Sep 11, 2011 | Dell Inspiron Mini 10 Notebook
I have a IBM T210 flatscreen, 20.8 inch. I have done everything possible with the resolution inside windows. I have also gone through every setting in the menu's of the monitor. The monitor is working...
Can u change the screen from 16:9 ratio to 4:3 or regular if it's available in the menu? Black bar at top and bottom generally signifies widescreen...16:9
Feb 03, 2018 | IBM T210 (Pearl White) Monitor
I purchased a Dell ST2320L monitor. When I am in Windows, there are black bars on the top and bottom, as well as the sides. When I am gaming, however it is full screen. How do I adjust the monitor in...
thats really odd that windows 7 doesnt give you full screen but the game does? change your resolution settings around to see if that helps altho i doubt it. check menu settings on your monitor and see if you can change its aspect ratio
Mar 23, 2011 | Dell ST2320L Monitor
Black strip left hand side of moniter screen not being filled
The monitor should have some kind of menu, accessible through the buttons on the side or bottom. In there you can move te display area to the left. If you then get a bar to the right, you should change the monitor resolution to the highest it can display.
If the bar on the left persists, you should check wether the PC-monitor cable is properly insterted. If so, try another cable. If that doesn't help either, try another monitor.
I hope this helps,
Yannick.
Oct 05, 2009 | LG L192WS LCD Monitor
Black Bars each side of my new monitor wide screen
Right Click on an open spot on your desktop.
If your Operating System is Windows XP, choose Properties from the menu box that pops up when you right click.
A new window will open up. Click the Settings tab at the top right.
On this menu you should see a slider bar near the bottom left under "Screen Resolution". Left Click and hold the mouse button on the grey button and move it on the slider bar over to the right one spot. Then click the Apply button on the bottom right of the box. The screen may flicker for a second and your desktop will change size. If the screen covers the whole monitor and the black bars are gone, that may be the correct resolution. Click OK on the box that has a timer and is asking if you want to keep the screen that size. If the screen does not look correct, click No and you may need to slide the button one more spot over and try the next resolution and Apply until it looks correct.
Under the slider bar as you move it over a line at a time will be 2 numbers like this 1024 X 800, and when you move the bar over the numbers will change. I believe the optimal resolution setting numbers for the 20" monitor you have should be 1680 X 1050 for the widescreen. You may want to try that setting. If it looks too small, try sliding the bar to the left and try each resolution setting.
Here's a screetshot of what the Box with the slider bar looks like: http://technophobik.co.uk/vxp_control_panel/f007_settings.asp
If you have Windows Vista, (it is similiar to XP):
Click the Start Button and click Control Panel in the Start Menu
Click Appearance and Personalization in the new window that opens up.
Click Personalization, then click Display Settings at the bottom
A new box will pop up with the grey button on a slider bar near the bottom left under "Resolution" Slide the button to the right to the next line one spot over on the slider bar and then click the Apply button. The screen may flicker and change the size of your desktop. Click OK if the screen looks correct or click No if it doesn't look correct and try sliding the button over one more line.
Jan 21, 2009 | HP W2007 LCD Monitor
Menu not in centre of screen and unable to see volume bar
1. Solder the vertical IC. & IC supply capacitor.
2. change the vertical IC
Oct 20, 2008 | Samsung SyncMaster 1200 NF (Ivory) 22" CRT...
Onscreen controls don't respond
You have five buttons at thee right-hand bottom of your screen (just under thee edge). They are (from
left to right) the Main Menu button, the Down button, the Up button, the Input button and the Power
button (under the light).
To adjust your screen press the main menu button. Once the main menu screen is up, toggle
through it using the Up/Down buttons. Once you see what you want to adjust, move over to the
right side of the menu by pressing the Input button. Now use your Up/Down buttons to highlight
what you want to change. Once it is highlighted, press the "Input" button again. Now use the
Up/Down buttons to adjust your settings.
Once you have adjusted the settings, simply press the main menu button to exit.
Sep 10, 2008 | Hannspree 22" widescreen LCD Flat Panel HD...
New gateway monitor
The problem was solved by going to the the main menu, touch twice, touch second button from bottom till arrow is next to the X icon, touch fourth button from bottom, then press second button from bottom till arrow is pointing to the earth icon. Change to American. :>)
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Rosewill R900J 19" Flat Panel LCD Monitor Logo
56 people viewed this question
Top Rosewill Computers & Internet Experts
Steve Allison
Steve Allison
Ian Ballard
Level 1 Expert
Alun Cox
Are you a Rosewill Computer and Internet Expert? Answer questions, earn points and help others
