Question about Kitchen Ranges
Outer oven window shattered
The outer oven window shattered today on the stove. The oven was heated to 220C, happily baking chips and chicken nuggets as it has so many times before. I was standing in the kitchen when it happened and I can say no water was splashed onto the glass, I hadn't opened/slammed the oven door. Nothing like that. It just shattered. Is the glass replaceable or are we looking at buying a new stove? Thanks!
    President:
  • Kitchen Ranges Master
  • 2,651 Answers
Sure should be replacable, youo can cll the manufacture for a replacemnt glass, most only held in by a feww screws, cant see it being the end all for you oven
Posted on Dec 22, 2008
Im looking to replace the outer glass on an oven door STV008 Vanette GG7000. Can anyone help?. Many thanks.
Hi, Cathy.
The double-glass is held down by the inner framework, which secures with fairly hefty Philips screws.
These screws and frame can become baked on over years of fat / oil being dried and hardened into a shellac-type 'superglue'.
Lay door horizontal, or as open as it will go, pour olive oil over screws and brush edges of window and frame.
Leave to soak (unheated), at least overnight.
The interior of the door has glass wool heat insulation.
Apply rubber gloves and long sleeves if the spiky glass wool fibers irritate your skin (like mine!!).
Unscrew frame, lift glass out.
Electrical stockists which sell stove parts (may) possibly have a match, otherwise search the web, manufacturer, etc.
Jul 10, 2018 | Ovens
I have a mabe gas stove and oven, the outside glass of the oven broke, can the oven be used with just the inside glass? And can I but a replacement outside glass? I live in Santo Domingo, DR.
I have the same problem. I have a maybe gas oven and stove too and the outer glass shattered when we were moving. But we live in Boquete Panama and all these answers only really apply to the US. Any answers.
Nov 19, 2011 | Kitchen Ranges
My outer glass shattered on lower oven
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Dec 11, 2010 | Ovens
The outer glass of my oven door shattered, can I still use it until it is repaired?
Hello- I would be careful using the oven mostly because the inner glass will be VERY hot to the touch, meaning you will get burned if you touch it. If you have children I would refrain from using the oven, too risky. If it is just you, or just adults then you should be ok to use it until you can repair it. Keep in mind that you will probably lose a lot of heat out the door and it make take longer to bake. Again, be wary of the inner door glass if you use the oven. Do a test run with a low heat and see how it performs. Hope this helps, best regards.
Sep 27, 2010 | Whirlpool Ovens
The outer glass on the dooor has shattered, where
Try this link. Price is $92.00. I have replaced some of these and they are not hard to replace.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=250474&diagram_id=98440#d98440
Jan 05, 2010 | Whirlpool GR399LXHS Electric Kitchen Range
I just shatter the top of my stove ,glass ceramic, can it be repaird.. it's a glass cake cover fell handle first and 3 of the burners have cracks running through them ..do i hve to replace it or can it be...
Unfortunately no your ceramic glass top cannot be repaired and will have to be replaced. as for the burners as long at the metal heating part of it isn`t damaged and its just the outer white coloured insulation that is cracked or chipped this is okay and still operate normally.hope this helps
Thanks
Oct 12, 2009 | Maytag Ovens
Kitchen Aid microwave door -- outer glass
Lisa, I do not have a solution, but have the same problem. My KA superba micro has been used about 10 times. While it was off, and while no one was home, the outer glass in the door shattered. I suspect this may be a defect.
Jun 19, 2009 | KitchenAid Architect Series KEMC308KSS...
Oven door outer glass shattered
will need a model number to tell you the correct price ... most will have to replace the door... you can also give sears a call .. if you gripe loud ... they may replace it for you...
Sep 28, 2008 | Ovens
Outer Glass Microwave window shattered after baking popcorn
doubt anything to do with popcorn. glass like that does sometimes shatter probably a stress fracture. quite often happens with oven doors as well
Apr 19, 2007 | KitchenAid KEHC379JSS Electric Double Oven
Kitchen Ranges Logo
373 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
