Question about Kenmore 24032\24036 Top Load Washer
Series 110 (old) Kenmore washer does not drain...
The washer fills, washes, but after wash cycle, it does not drain. I can manually advance it to the point where it spins (after initial drain stage), but all it does is slosh the water around in the basket...
I am hoping this is just a plugged drain hose, but having read other advice, am afraid it might be more involved. I am going to first try checking the hose, but would appreciate any further advice.
  • onthethejob1
    onthethejob1 May 11, 2010
    belt ,,drive or direct drive
    Novelist:
    Scholar:
  • 72 Answers
The drain pump may be clogged. I had the same problem and found a bunch of polyester fiber fill from a comforter my wife washed clogging up the water pump. Once cleared, it worked fine.
Posted on Dec 28, 2008
How do I check and replace the water level sensor on my Kenmore 80 Series Hvy Dty Washer?
Try eserviceinfo.com/index as per your 80 series. There are various downloads there that may help access the water level sensor which is most likely the problem.
Aug 08, 2014 | Kenmore Washing Machines
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Kenmore 110 washer fills and does the wash cycle but wont drain or spin. Totally shuts down after wash cycle. What do I need to replace
sounds as though the lid switch has gone bad, either that or the motor has lost the reverse winding on it.. most likely lid switch tho.
the lid switch is only "seen" by some older kenmore "110" series at the end of the wash cycle, or end of the rinse cycle. it purpose is to keep the unit from spinning if the lid is opened so no one looses an arm, etc.
generally the console on those machines hinges over backward so you can remove the cabinet top and 3 sides as a unit together..
the lid switch is under the machine top and isn't easily accessible without removing the cabinet.
May 20, 2010 | Washing Machines
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Kenmore model 110 23832100 stps after wash cycle before the rinse cyle. The old water has not drained.
If the machine fills, and washes and won't drain or spin out the water you need a direct drive coupling. It is located at the bottom and is on the motor shaft and consits of 3 pieces. Check this first, easy fix and not expensive.
Nov 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Washer will not cycle
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Oct 24, 2008 | Kenmore 15864/15862 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
164 people viewed this question
Sal De
fordexpert
 Brian Main
Brian Main
