Question about Samsung HCN529W 52" Rear Projection Television
My TV switches to "Standby - Timer" after 10 minutes of viewing.
  • Samsung Master
  • 5,138 Answers
Turn Timer OFF in menu.
Posted on Dec 30, 2008
Is turning itself about every 20 minutes is one week old . it is not the stand by . standby is switched off
maybe you turn on the tv timer try to disable it or try to unplug the tv for 10 minutes...
Sep 13, 2015 | Televison & Video
Standby/timer flashes and screen goes black
How many times do this standby light flashes at one time switch ON? Count it. These flashes are fault indications. From the number of flashes, you can get an idea about which section circuit inside it is faulty. After confirming it, If you wish to get more details of these blinking codes, check this link.
Mar 02, 2013 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby light is flashing 10 tims Model KV-HR36
Try unpluging your T.V. for 5hours+, then turn it back on. Worked for It's called a "hard reset" by sony.
Otherwise
Do the following steps
  1. Check the Sony remote for a button labeled "Sleep." This allows you to cycle through the sleep settings and determine how long you want the TV to remain on.
  2. Step 2 Press the "Sleep" button. You'll see a number come up onscreen: usually 15 or 90. When you press it again the number changes, moving up and down in increments of 15. This is the number of minutes the TV will remain on before it goes to sleep. As you cycle through it, you should see a setting with the words "Sleep Off" appear onscreen. If you leave it there, the sleep setting should cancel, allowing you to turn the set off when you like. If you miss it, just keep pushing the "Sleep" button. It will continue to cycle through the options until "Sleep Off" appears once again.
  3. Step 3 Access the timer function to shut off the timer by pressing the "Menu" button, then cycling through the onscreen options until you reach the "Applications" setting. Press it, and then cycle through to the "Clock/Timers" option.
  4. Step 4 Highlight the "Timer 1" setting and press the "+" button. If it's showing a given time, you'll need to deactivate it. Use the up and down arrows and move through the possible options until you come to the "Off" setting. Leave it there; that should shut the timer off.
  5. Step 5 Repeat the process with the "Timer 2" setting, a little further down the "Clock/Timers" menu. Set it to the "Off" position just as you did with the "Timer 1" setting.
  6. Step 6 Press the "Menu" button when you are done to exit the menu and return to the screen. You should be able to view the Sony TV as normal with no danger of it turning off.
good luck
Aug 08, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Insignia 37" goes into standby mode
I am experimenting with Insignia's and there is a feature whereby if a signal is not detected the TV will switch to standby mode (in about 10 - 15 minutes). It's documented as a tiny "note" in the manual under "Understanding the basics - Turning TV on or off"
I don't know if the TV resumes when the signal is restored or if you need to power on manually.
You are probably experiencing a glitch with the signal or the TV thinking the signal is not there. Are you watching a clear picture when this happens? I would first check to see if the signal is too weak (like using a signal booster). If that is not the case, it's probably the TV acting up.
I hope this helps.
Is this
May 26, 2009 | Insignia 37" LCD Flat-Panel HDTV
TV keeps turning itself on and off, onto standby
I managed to find a local repair man who fixed the problem. He put in a new transformer.
Dec 01, 2008 | JVC AV-32D305 32" TV
Power goes off automatically
The flashing light is not a stand by...that a service light telling you it has a problem that needs to be fixed...
Apr 14, 2007 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Samsung HCN529W 52" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
