Question about Panasonic GigaRange KX-TG5432 Cordless Phone
Answering Machine always on
I purchased KX-TG5432M model 2 years back and has been working well till now. There was an incoming call but since nobody picked up the call, it went in to answering mode. Since then the answering machine light is on and I am just not able to switch it off. In addition, no other keys work in answering machine or intercom - basically no keys work on the base unit. Please suggest a solution. Thanks, Murali
SOURCE: Phnoe and Answering System Inoperative - E1 flashing
I read about this, and while you were gone, if your power went out, try unplugging the batteries from the back of both phones for a few minutes & put them back in..I hope this helps!
Posted on Jul 03, 2008
Centernet
  • 38 Answers
SOURCE: How to change the answering maching message
Depending on how your automated attendant is programmed, you will need to either change certain prompts or certain Custom Service menu greetings. Without knowing how your system is configured, I can't be more detailed, sorry. However, we can fix this for you over the Internet with our remote support package...
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
Posted on Oct 14, 2008
SOURCE: panasonic kx tg7200fx and kx tg 1100 compatible for use in intercom
A few days ago I bought Panasonic KX TG1100 - but the base unit does not ring - only the handset!
Can I do anything about it?
Posted on Nov 20, 2008
SOURCE: Problem with answering machine on Panasonic Model # KX-FPG376
i followed the advice posted & it worked fine after that. thanks.
Posted on Nov 25, 2008
SOURCE: panasonic answering machine not working
We had the same problem. Unplugging the unit and restarting it again solved the problem.
Posted on Mar 03, 2009
NEED USER MANUAL FOR KX-TAG931S PHONE HANDSET What I really need is how do I make the incoming call go to Voice Mail without it ringing 4 times.
You may download the KX-TGA931 manual from http://shop.panasonic.com/shop/model/KX-TGA931T?support
The number of rings is controlled by the answering machine or voicemail system on your phone line. It cannot be changed from the handset. Please refer to the documentation for whatever answering machine or voicemail system you have.
If you require further assistance with the answering machine or voicemail system, please tell us the make and model.
Sep 23, 2013 | Panasonic KX-TG5210M GigaRange Supreme 5.8...
I would like to change the answering machine message
Record a Personal Greeting
Access the answering system from any handset. Wait until the system finishes its announcements, or press 5 (Stop) to skip them.
Press 8 (RecNewGreeting).
Wait for the system to say "Record greeting," then begin speaking.
When you're finished, press 8 to stop recording. The system plays back your new greeting.
To keep this greeting, press End. To re-record it, go back to step 2.
Aug 21, 2013 | Panasonic KX-TGA101S Cordless Handset
Hi how do i connect panasonic kx t7731 phone to kx tm 100b answering mcchine. i do not know what system i have and i connected as manual and it is not working. thanks
That's because whatever system it's connected to, it either has to be in the port by itself, or you have to BRIDGE the answering machine in system programming. You pick.
If it's a port on a TA series, you can tell the system there's an answering machine on it and it will let you override the incoming playback and pick a call from the line.
Carl
Aug 18, 2011 | Panasonic KX-T7731 Corded Phone
Phone time is reading 2 hrs. later than actual time; have reset,
Whoever is controlling the incoming calls is sending a different time zone. If it's the telco, call them. If it's a VoIP carrier like Vonage or Packet8, get them to let you log into the box and change the time zone offset.
Carl
Feb 25, 2009 | Panasonic KX-TG1033S Cordless Phone
Answering machine not picking up phnone messages
I think that you can reset the system to factory settings by unplugging all power cords and waiting ten minutes, try this out.
Dec 16, 2008 | Panasonic KX-TG1033S Cordless Phone
Nov 22, 2008 | Panasonic KX-FPG376 Plain Paper Thermal...
Vtech A5874 answering machine not working & letter A shows.
Somehow the answering machine was clicked off, but the announcement was on. Therefore I could not receive messages, but my recording was still on as if I was receiving incoming messages. I just played with the various on/off switches till it worked. For me, just plain luck.
Sep 28, 2008 | Vtech i6772 Trio Cordless Phone
Answering system
It first sounds as if the handset isn't charged properly. Check the battery status first. The manufacture advises to charge the system for approx. 7 hours before any use occurs. Second, make sure that the registration took, when programming the phone originally. I would de-register the handset by: 1 {MENU} i {0}{0}{2} 2 {3}{3}{5} i {OK} 3 Select the handset you want to cancel by pressing the desired handset number ({1} ? {4}). Then re-register by: 1 Handset: {MENU} i {0}{0}{1} 2 Base unit: KX-TG6021/KX-TG6022/ KX-TG6023 Press and hold {LOCATOR} until the IN USE indicator flashes. KX-TG6051/KX-TG6052/ KX-TG6053/KX-TG6054 Press and hold {LOCATOR/ INTERCOM} until the IN USE indicator flashes. LAfter the IN USE indicator starts flashing, the rest of the procedure must be completed within 1 minute. 3 Handset: Press {OK}, then wait until a beep sounds. 4 {OFF} Third, make sure that the display on the handset does not show "SP-Phone" in the display, if it does press the phone icon button. Fourth, Do you currently have voicemail from your phone service provider? If so, the answering machine will not answer. Make sure that the answering machine portion is turned on. Do this by: Press {ANSWER ON} to turn on/off the answering system. When the answering system is turned on, the ANSWER ON indicator lights. When the answering system is turned off, the ANSWER ON indicator turns off. If there are any further questions or comments, please post here. Please rate this solution through fix-it. Thank you
Jun 22, 2007 | Panasonic KX-TG6021 Cordless Phone
Panasonic GigaRange KX-TG5432 Cordless Phone Logo
35 people viewed this question
Top Panasonic Lands Phones Experts
Henk de Ruiter
Henk de Ruiter
Marvin
Marvin
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
