Question about Bose 901 VI Main / Stereo Speaker
What kind of amplifier and other accessories are recommended for bose 901 speakers
    Problem Solver:
  • 9 Answers
I would recommend a high power 2-channel amplifier, minimum 16 guage speaker wire, and of course the Bose 901 active EQ that matches the series of your speakers. I use a Yamaha mx-830 power amp & cx-830 pre amp 170 wpc They (Bose) claim that they're unlimited power handling, But if you use a amplifier with to little power and overdrive it to make it louder, you could damage the speakers or amp. With my 170 watt class A amp,the 901 series 6 will blow wind across the room. Go with the best amp you can afford! best for money- Yamaha,Denon,Onkyo!
Posted on Jan 07, 2009
  • Voltaire Labuguen
    Voltaire Labuguen Aug 02, 2015
    Hi Sir. Will you recommend a Yamaha power amp Model P 2500S, 250 watts/ch for the 901?. Or a Yamaha Integrated amp Model A-S701, 100 watts/ch ?. I'm planning to buy an amp but cannot decide which one?
Bose 901 equilizer connections to sansui G901DB
It sounds like you may have only the 901 loudspeakers, and not also the companion 901 equalizer box. You must install the 901 equalizer properly--using the tape monitor loop of the G901 receiver. If you of not, the 901 loudspeakers will perform poorly.
Jun 17, 2014 | Bose 901 VI Main / Stereo Speaker
I just purchased 2 used pairs of Bose 901 series III. The problem is they came with just 1 active EQ. Can I all 4 with just one EQ. Thank Tyler
Yes, if they're all on the same 2 amplifier channels.
If you're pondering some kind of employement in a multichannel system look around fixya for the dozens of post I've made addressing various scenarios. Keyword: Bode 901
Jan 16, 2011 | Bose 901 VI Main / Stereo Speaker
`Which ampliphier is compatible for my Bose 901 series 6 with equilazer.
Ideally, an amplifier or receiver should have either a "Tape Monitor" selector switch and Tape Input & Tape Output jacks, OR have Preamp Output & Amp Input jacks to enable insertion of the Bose Active equalizer into the circuit before the amplifier stage. Power requirements - according to the 901 Series VI manual:
"Your 901 speakers are designed to work compatibly with receivers or amplifiers rated from
10 to 450 watts per channel."
If you have questions not answered by the manual, you can contact customer service at The Bose Corporation in Framingham, MASS toll free at:
1-800-999-2673
Hours of operation:
7 AM - 2 AM ET, 7 days a week
I hope this helped & good luck!
Nov 22, 2010 | Bose 901 VI Main / Stereo Speaker
Bose 901 series 6 equlaizer problem
Only a careful experiment with steadily increasing volume would reveal the answer. Or measure the resistance of your cobbled work to see if it sufficiently high to avoid amplifier stress.
Original Bose 901 drivers in many series' are available on eBay and other places. I would NOT mix drivers within an enclosure. They should all match in every respect. Bose typically uses some very low impedance that totals to 8-ohms as wired inside.
There are many 'golden ears' who have used 901's without the Active EQ at all or improperly configured and they have been happy with the sound. Sonic beauty is in the ear of the beholder.
I would NOT forgo the EQ.
Jul 11, 2010 | Bose 901 VI Main / Stereo Speaker
What would be the best amplifier for a pair of bose 901 series v1 speakers. they are 450 watts max. i need good clean power and lots of it. what do you recommend.
I'm partial to any old Carver amp. Some M-400 Cubes bridged to 400 WPC would blow the walls out for you. Or if you want to keep some semblance of peace and hearing ability, I'd just get a nice M-200 for them. I've had both set-ups and the M-200T is fine without being dangerous.
Dec 01, 2009 | Bose 901 VI Main / Stereo Speaker
I have bose 901 speakers. what kind of amplifier(equipment) doI
You will need a pre-amplifier,a tuner,and a cd player.also the Bose active EQ that matches the series of your 901s.
Jan 02, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 and Tube amp
Yes! When the Bose ~Steve901 first came out that was the amplifier of choice -like the McIntosh classic amps. The 901s have their own equalizer as that speaker system is a phased-array,
Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
How to connect bose 901 speakers to 5.1 setup?
The solution is simple and cheaper than you think.
The analog 5.1, 6.1, 7.1 outputs on your receiver should be active even with digital inputs that you want to hear. Your receiver turns everything it processes into analog output just before the speakers anyway so there's no loss of access to multichannel sound this way.
What I did was to buy a separate amp for the 901's and feed the Front L&R analog audio out to the EQ which is directly in front of the amp. The Active EQ is only for the 901's which don't have woofers or tweeters so Bose flattened out its final response electronically with some serious boosting at both ends. Having it in line with any other speakers would feed them a grossly over-compensated signal.
Your receiver will drive the rest of the speakers.
This is the cheapest way to have your 901's and hear them, too. Since the 901's are really efficient you don't have to buy a big amp that would heat the room. I'm using a separate Carver amp with 2x100w for mine.
Sep 09, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 v1 adding a amplifier
You may connect an additional amplifier to the Rec Out or Line Out from your existing receiver.
Please note the Bose 901 equalizer can be used to connect to one amplifier only.
Do let me know if you have any further questions.
Nov 28, 2007 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
657 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
