Question about Gateway GM5088 PC Desktop
Onboard video has failed..how do I change in bios to video card ?
Without any video on the gateway GM5088 because of a failed onboard video chip how would I be able to change in the bios to disable the onboard video so I may add a video card on the available pci-e slot? I was told this is a common problem with this model motherboard where the video output fails!
  • 3 more comments
  • atwazup Dec 22, 2008
    I understand what you mean......but when the video card was installed I still did not get anything on the monitor to be able to get to the bios to disable the board chip! Thanks anyway
  • atwazup Dec 23, 2008
    Yes the Monitor does work but yet nothing after installing the video card in the slot!
  • Loteck May 11, 2010
    You did connect the monitor to the new graphics card?
  • kiran_g4e
    kiran_g4e May 11, 2010
    r u sure..about that problem is in vedio chip..
    is monitor working good??
  • kiran_g4e
    i think there is no need to change ur bios settings...
    install ur vedio card, bios automatically detects and support for basic display after that u need 2 install drivers in windows..boot ur windows in safe mode..uninstall onboard drivers..
    i will check it and catch u again....k
  • 34 Answers
First install the video card in the pci slot first so that you have access to your monitors screen for you to disable the on board video chip or video card, go to the CMOS setup by pressing del key. once there you can browse through the CMOS setup to disable the on board video chip.
Posted on Dec 22, 2008
  • jsnow007
    jsnow007 May 14, 2012
    Dude, I have set the video to pci I have done everything but take a hammer to this thing. Windows is not detecting the new video card and I have tried 3 different ones that I know work,is there a jumper on the motherboard? what am I missing here?
NO ONBOARD VIDEO
Hello here is the ASUS homepage:
http://support.asus.com/Download.aspx?SLanguage=en&m=P5N73-AM&p=1&s=22
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
Your pci-e graphic card is failing or has a defect.
The problem could also be the power supply, not giveing enough power.
When you add a pci-e graphic card on the mainboard, the onboard graphic should deactivate itselves.
Try to remove the pci-e graphic card, and use the onboard graphic.
If still no picture, change the power supply.
Its not possible to change settings in the bios blindfolded.
You can reset the bios by removeing the cmos battery.
But ofcouse it could also be the mainboard itselves failing.
This is rarely happening, so i hope its just the power supply.
Try also to look for visual defects on the mainboard, especially the condensators on the mainboard.
Good luck
Apr 14, 2013 | Computers & Internet
Install new video card in Gateway GM5072 with Pheonix bios and disable oonboard video
There should be an option to disable the onboard VGA connection within the BIOS of the computer.
Plug your monitor into the onboard video output to do this.
Dec 24, 2011 | Gateway GT5220 PC Desktop
EV3A GT520 video card installation makes my screen go blank. My gateway computer has an integrated chip for video, and does not even recognize the new card but its plugged in, fan working, etc.
some bios settings disables the add on video cards. to enable them go to bios setting by pressing DEL or F12 while power on your system. (u will see that a message appears "press ----- Key to enter bios settings). after entering bios setting u will see onboard VGA enable/disable. u have to disable onboard VGA in order to get the display thruogh VGA card.
Sep 21, 2011 | Nvidia GeForce GT 520 1 GB DDR3 Video Card...
Problem with onboard video of a compaq sr2032x
The onboard video card is actually set to secondary when you plug in a PCI or PCI-E video card. If no video image is showing then there may be further damage inside the mother board.
Apr 29, 2010 | HP Compaq Presario SR2032X PC Desktop
Monitor (no signal) after replacing mother board and CPU
try only connect Monitor and keyboard, and check for booting (disconnect all the rest (HDD, CD DRIVE, Sound Card, Network Card, ....) then try connect one by one and always off to change hardware config.
If dont work with monitor and keyboard, try reset bios(jumper),check again, then replace memory modules (must be compatible to new motherboard), evan dont work, send back the motherboard for defective motherboard.
Jan 14, 2010 | Gateway Intel (El Paso 2) Motherboard P4...
Pc powers up but no video on screen gateway 420gr desktop
Yes generally speaking when you drop in a videocard it typically will disable the built on one. You may have to disable it though. I know you said you did not see the onboard video in BIOS but there is almost always a setting in there to turn it off.
Sep 17, 2009 | Dell Dimension 8200 PC Desktop
The monitor doesn't go on. the orange standby light blinks on and off. is there a reset?
Sounds like the issue is with your video card/onboard video chip or the connection between the monitor and the pc. Verify the cable from the monitor is connected to the pc firmly & snugly. See if the monitor gets a picture on a known working pc. If so, then it's a (relatively) simple fix - work on the videocard - if add-in, try reloading drivers, ensure the onboard video is disabled in the BIOS, or (worst case) replace the video card. If it's onboard, again, try replacing/updating drivers and, if that fails your next step is to either get an add-in video card, or replace the mobo.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/chris_796687fbded27b53
Aug 13, 2009 | LaCie Electron III 22" CRT Monitor
Media Center has an Intel graphics chip on the mother board. How do I omit using it so I can install a PCI video card?
Have you tried adding the card and see if it defaults to the card rather than the onboard video? Many BIOS are set that way by default.
Go into your BIOS and look at the onboard devices. It is preferable to tell your BIOS to first look for an add-in card and default back to onboard if you don't find one. But you can disable your onboard video, then save and reboot.
Jul 18, 2009 | HP Media Center m7060n PC Desktop
Pcmcia cards show up as mtd-0002
if you go into sound and multimedia you can change the preferred output/input items to your PCMCIA card rather than the onboard systems. you could also try disabling onboard systems in device manager too.
Oct 07, 2007 | Gateway 7210GX Notebook
Gateway GM5088 PC Desktop Logo
789 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Steve Allison
Steve Allison
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
