Question about SMC2804WBR Wireless Cable/DSL Broadband Router 4 x 10/100Base-TX 1 x 10/100Base-TX Wireless Cabl... (SMC2804WBRFT)
Two router home network problem
Two router network issue here.
Cable Modem > Linksys BEFSR41 > SMC2804WBR
My parents want the linksys to stay as is (it is wired). I want to add the SMC b/c it is wireless. The problem is, the two routers aren't playing nicely.
I have an ethernet cable attachine from Port 2 of the Linksys (wired router) to the WAN port of the SMC (wireless router).
I've rebooted the wireless SMC router and tried resetting it back to factory defaults (using reset button) but I can not get any of my computers to see it. When I am in internet explorer, I can go to 192.168.1.1 and see my Linksys fine. I should be able to see my wireless router (192.168.2.1) the same way but I CAN NOT.
I was able to log in last night to the wireless but today I can't. Last night I was messing around with the settings on the SMC. I disabled DHCP b/c from what I understand I don't want two routers handing out IP addresss. I think I accidentally hit some sort of clone feature as well. So I hope that did not screw anything up. I would assume Fac default would put everything right again though....HELP!!! : (
    Scholar:
  • 62 Answers
Can you still connect to the Internet with the Linksys router? I suggest that you go ahead and reset the SMC router to clear up your previously configured settings. Then before reconnecting it to the linksys router, make sure that you can access its web interface via 192.168.1.1. Don't disable DHCP as your computer won't be able to obtain an IP address from it automatically. Do not change other settings. Next, disconnect the ethernet cable and check if you can access the router interface wirelessly. Once done, connect SMC's WAN port to Linksys' numbered port. Make sure SMC's WAN light is on, as well as the light for the port you used on the Linksys router. Check if you can get online.
With this configuration, the linksys router is now acting like a modem, and the SMC as your router. As long as you're online when wired to the linksys, you should also be able to access the net on the SMC once you physically connect them.
Posted on Jul 14, 2009
Install router on windows XP
you could download the quick start from linksys.com for that but basically there is no installation necessary with windows, it's a network device that does not need to be installed. simply plug it in.
Jun 09, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Slow or no connectivity with linksys modem
- Changing the LAN IP Address of your Linksys will do to fix the issue.
Mar 16, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFSR41 Cable/DSL Router and RCA DCM425 Connection issue
hi,
first u configure the modem as bridge. And then u connect the linksys router, wht ever u config u configure in the router. it should work fine.........
Mar 12, 2009 | Linksys Wireless-G WRT54G Router
Woodenthings
Your provider probably sent you either a cable modem or adsl modem. If you connect the single port on the modem to the WAN or Internet Port on the Linksys and then connect the computers to any of the 4 ports that are grouped together, it should work.
Mac or PC, it makes no difference and drivers are not needed.
Unless this is a new router or it is one that you personally configured, I recommend resetting it back to factory default by holding down the little red button for 30 seconds, this eliminates any configuration issues that someone else may have introduced.
Jan 03, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
I have linksies router and 2 wire modem will they work together?
If the Modem has an ethernet port (looks like a large phone plug like the ones on the router) connect an ethernet cable from it to the "internet/wan" port on the router. If it doesn't there isn't much you can do.
Dec 30, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
2210 modem to befsr41 router connectivity
HI
JUST GO TO THE SETTING OF ONE OF THEM AND CHANGE THE DEFULT GATE TO CHANGE THE THIRD NUMBER BY ADDING ONE OR SUB. ONE
Dec 12, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Computers & Internet Logo
139 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
