Question about Sony Cyber-Shot DSC-F717 Digital Camera
Flash thing well for some reason, when i turn on my camera, the flash thing doesn't pop up like it usually does. i didn't close it any differently then what i usually do, so i don't really understand why it's doing that...
Set your hot shoe to 'off". Try that. CT
Posted on Sep 29, 2007
Camera won't shutter
So that any responder does not repeat steps you have taken, what have you attempted to do to solve this issue?
  • Turning on and off the camera sometimes will fix it.
  • If you are in AF mode and the camera cannot get focus it will not fire the shutter.
  • If it is in a low light area, reason the flash popped up, and the camera cannot find something to focus on it will not fire the shutter.
There are a number of things that can cause this, some nothing to do with an errant camera.
Cordially,
Jun 20, 2014 | Canon EOS Rebel XS 35mm SLR Camera
Flash on camera is not working
Hello. If you're shooting in Auto mode and you have turned off the flash, your camera will remember that setting and the flash will not fire. If you switch the dial on top of your camera to another mode and then back to auto it should clear the setting and the flash should now fire, if needed. The other thing to try is to hold down the the flash popup/mode button while, at the same time, turning the rear control dial. You can watch your top display and the flash modes should cycle through different options.
Dec 25, 2013 | Nikon D7000 Digital Camera
Error 05 flash doesn't pop up
spray a very very small amount of WD40 on the hings of pop up flash (use the thin RED spray tube)
Nov 17, 2012 | Canon EOS 400D / Rebel XTi Digital Camera
Wont turn on
you didn't give enough information about the problem or when did it start.
try the follow:check that the battery lid is closed properly - in many of those cameras it doesnt always close as it should.
try to connect it to a computer and see if something happens. it is possible that the camera does work but the screen is for some reason turned off.
Oct 02, 2011 | Canon PowerShot A495 Digital Camera
Error 2 in my coolpix 8800. I bought a new battery in the store they said to do that, didn't help an I changed the memory card as well, didn't help
hi your camera has system error, usually the lens unit doesn't reset after taking picture. it cause error message. you should contact to nikon service center and ask them repair cost. usually they will tell on the phone. thanks and best regard!
May 23, 2011 | Nikon Coolpix 8800 Digital Camera
Fuji finepix f810 flash wont pop up when button pressed
hi your camera is kind of getting old but it is still great. some people really like it. personally I like also. however, fuji finepix f810 has little problem like yours due to delicate design. on your flash problem could has two sequence check. first is flash circuit defective or flash tube defective. second is main pcb doesn't work properly with flash function. your local repair shop would charge around $75 to 185. Fuji camera usually charge more than other brand. I am sorry that you know. Good luck with you and best regard.
May 22, 2011 | Fuji FinePix F810 Digital Camera
Flash made loud pop sound.... like balloon popping. doesn't flash anymore. why would this happen?
It sounds like the flash tube itself blew out. This could be due to a number of things, from the age of the unit, to the electronics, to a defect or mistake in production.
Another reason could be using a flash that is not dedicated to your type of camera. Flash trigger voltages differ between make and model creating many incompatibilities.
Without more info, I cannot suggest what flash would be best for you. Sorry.
You can goto yahoo groups and find a group for your kind of camera. Ask other members what they suggest for your camera, budget and what you do with your camera.
Dec 25, 2009 | Cameras
Delayed Shutter, No Flash, and Menu Issues
Pls check your camera settings. Your shutter may be set to 10" (meaning 10 seconds). That is probably also why your pop up flash does not go up... because it feels that it will already get over-exposed pics.
To check if it is not a hardware problem, change your settings to Auto and try to shoot in a dark room.
NOTE: Please rate our help to keep this free service online
May 19, 2009 | Nikon D80 Digital Camera with 28-80mm Lens
Canon S1 flash stuck
Mine does the exact same thing but I just pop it open manually when I need it. The great thing is that unless you have a very dark night shot you can pretty much shoot with out it, but don't be afraid to pop it out manually. It will close again!
Feb 20, 2007 | Canon PowerShot S1 IS Digital Camera
Sony Cyber-Shot DSC-F717 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Terry Weaver
Terry Weaver
Are you a Sony Camera Expert? Answer questions, earn points and help others
