Question about Whirlpool Duet GHW9150P Front Load Washer
Wash cycle has ended and door will not unlock.
Whirlpool Duet washer. Pressed the end of cycle button for 3 seconds and door does not unlock. Any tricks other than taking panel off?
  • Anonymous Jan 19, 2009
    how to unlock the door when there is a door lock fault and not take the machine apart whirlpool washer duet
    President:
  • Whirlpool Master
  • 2,651 Answers
Welll there are 3 screws across the bottom front of the panel (torx 15) the lower acees panel can be removed, from there you can gain access to the backside of hte lock assy and manually release it. simply run your hand up the right side, just below the lock/latch assy ther is a quarter sized/teardrop shaped pull cord. thos will release the door, for you
Posted on Dec 22, 2008
How-To Unlock The Controls For A Whirlpool Duet washer
I have unplugged the machine and plugged it back in and restarted, just like when a computer needs to be reset/cold boot.
Jul 03, 2015 | Whirlpool Duet GHW9150P Front Load Washer
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool duet washer console lights out
The machine shd be "on". At the right end of machine panel is a button "end of cycle", keep this gently pressed for 3 to 4 seconds. The machine will unlock. Do it again and it locks. This is the child lock feature.
Pl click helped, if helped, thanks.
Apr 09, 2013 | Whirlpool Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    Duet ht washer control locked. How do I unlock it? Really need your help
    Hello & Welcome to FixYa
    This is a common issue with Whirlpool Duet washers however, your whirlpool duet washer can be reset to resolve the control lock problem. Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset the control. Please get back to me if you have any other questions.
    Kevin
    Apr 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Duet GHW9150P Front Load Washer: my door lock how rto unlock it...
    Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
    If helped, pl rate me good!!
    May 16, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    My control keys are locked
    The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
    Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
    May 16, 2010 | Whirlpool WED6400S Electric Dryer
    Door will not unlock on my whirlpool washer wfw9200sqa
    Power must be on. Hold down the 'end of cycle' button at the right side of the panel for 3 seconds. Wait for 2 minutes then try the door.
    Mar 22, 2009 | Whirlpool WFW9200S Front Load Washer
    Press and hold the end of cycle button for 3 seconds..
    Jul 10, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Control locked
    is any thing on or working check to make sure door is latched
    Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool Duet GHW9150P Front Load Washer Logo
    82 people viewed this question
    Sal De
    Marvin
    Marvin
    Gerry Harvey
    Gerry Harvey
