Question about Samsung RS2630SH Side by Side Refrigerator
Overfilled ice tray lots of shattered ice, no "cubes"
The water level is a little too high, the ice tray freezes over the entire top, when the ice tray ejects, all I get is lots of shattered ice chips, no crescent shaped "cubes."
  • 700 Answers
Hold in the freezer temp and the power cool buttons for 12 seconds, when the display changes toggle the refrigereator button untill desplay sAYS 03. Then toggle the freezer temp button or poew freezew button to a lower setting than what you have now.
Posted on Dec 22, 2008
Water in back of ice tube and in with ice cubes freezes
leaking water tray or water level to high check for any cracks and check water level after first harvest
Nov 05, 2015 | U-Line Icemaker
My ice freezes as a block when dispensed into ice tray
There are water level adjustment screws behind the plastic cover of the ice maker to adjust the water level when it refills after dumping a tray of ice. When there is to high of a water level it spills over onto the cubes freezing them into a big block. Try to adjust the level of water. There is a arrow which tells you which way to turn the screw to get a smaller fill fixing the problem.
May 04, 2014 | Refrigerators
Kenmore side by side model #515541 01--replaced water filter -water dispenser works great but no water coming into ice maker - what could be problem? we purchased this used-is there something we have to do...
I had the same problem. Sometimes the tray overfills and freezes in the little line that fills the ice cube tray.
I solved the problem by taking an ice pick and clearing the ice from the end of that little waterline until the water started flowing again.
Feb 10, 2011 | Kenmore 57029 Side by Side Refrigerator
My icemaker fills the tray but when the water shuts off it drips on the the ledge under the tray and ice builds up. Also now my ice cube tray seems to be leaking.Are parts available or does the entire unit...
My ice maker would not return to a level position after dumping out the ice. When the water turned on to refill the ice tray, it would run off the tilted ice tray and into the ice basket thus freezing all the ice cubes in the basket together. To remove the icemaker, there are two screws that hold the icemaker to the top of the freezer. Turn off the icemaker. Remove the left screw and loosen the right screw by removing the screw on the left. Slide the icemaker outward and it should come loose. Unplug the power connector from the icemaker to the freezer. The ice tray can be removed from the icemaker by gently pulling the tray to the right and the slot it goes into on the left side of the icemaker to the left. Once the tray is out of the assembly, inspect the round plastic shaft on the left side of the ice tray. Mine had two flat spots that were worn into the plastic from use. I used a dremel tool with a round barrel sanding disk at the tools lowest speed to remove the flat spots and decrease the overall diameter of the shaft which stopped the tray from sticking. Reassemble the ice tray in the icemaker.
Mar 10, 2010 | LG LSC26905TT Side by Side Refrigerator
I set the ice maker feature to make cubes with my samsung refrigerator rs2555sw. But the ice maker makes a ice chunk. All the cubes are frozen together with a flat and thick layer of ice on top..
Hi and welcome to Fixya.
Remove the front cover after the ice tray has dumped cubes and remove all of the water from your ice maker tray.
Then depress the test button on the bottom of the icemaker (in front on bottom) located about 1 inch from the lower rh corner.
The icemaker fill cycle should add just enough water to cover barely cover the tray. (see page 32 of the 25 Sept 2005 user's manual)
If it is overfilling the icemaker fill time / water level needs to be reduced on the ice maker module. A normal fill cycle is about 7.5 seconds.
Another thing that will cause larger cubes is high water supply (utility co) pressure.
A temporary fix would be to slowly close the refridgerator water supply line's shut off vavle so that the water flow restricts.
The real solution is to investigate ice maker fill time, and the function of the icemaker water supply solenoid vavle for possible Delayed closing of the internal diaphram.
Feb 06, 2010 | Refrigerators
The Ice maker does not make cubes.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
ICE DISPENSER
Dmuehr,
Are you sure it is a leak. Is the solenoid actually cutting off BEFORE the tray is full of water? If not, it is not a leak. The filling time for the icemaker water tray (where the ice freezes) varies depending on the local water pressure. With higher pressure, the tray may overfill. Your icemaker motor module timer may be set too long for your specific water pressure, so that the tray overfills. There is an adjustment on the module for shorter or longer fill time. You will need to remove the icemaker (3 screws probably) and reset the timer. It may take 2 or 3 tries to get it so the trays are about 80 to 90% full.
Jan 07, 2009 | Whirlpool GS6NBEXR Side by Side...
Ice bucket/bin frozen in place
mine was overfilling because the ice was getting stuck on the way out. So some stayed in the tray and when the water would refil, it would overfil and go over the stuk cubes. leaving it to overflow to the bottom and freeze like yours.
Sep 09, 2008 | U-Line Icemaker
Ice cubes melt together
check the fill cup on the rear of the icemaker to see if any ice is frozen in the fill cup if so remove the ice
May 06, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
159 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
