not best options
here is probel is not clear in usering
Solution #2
posted on Aug 08, 2005
Charlie - usenet poster
Rank: Apprentice
Rating: 0%, 0 votes
You can get additional IPs from your ISP, you can use some NAT/PAT software, or you can use a router, all of those options work and the cost is comparable. We strongly recommend using a hardware router with firewall features and a built-in switch, probably even wireless capabilities. Why a router, you might ask - A software solution would require one computer to act as a server for the other clients, and getting additional IPs from your ISP usually increases your monthly Internet cost. In addition, both alternative methods do nothing to secure your home/SOHO network.
I change the upd port in emule, close emule. I then forward that port in the 2wire 2701-G, restart...
(More)
I change the upd port in emule, close emule. I then forward that port in the 2wire 2701-G, restart emule and I get a highid. If i need to shut down the pc for updates, whatever, when I log back to emule I have a low id. I am continually doing this and the router does not have an option to edit the ports (thought strange and 2wire tech support confirmed) so I need to remove the upd application and put it back again with a new port number. I have kaspersky 2009 and wndows xp firewall is enabled. Haven't got a clue how to fix this problem
Hi! I can't open ports TCP/UDP to use eMule on my router. I fixed everything with firewall but my...
(More)
Hi! I can't open ports TCP/UDP to use eMule on my router. I fixed everything with firewall but my problem is that I'm in mexico right now and the web page http://gateway.2wire.net/ for my router is in spanish so I cannot find any port forwarding or gaming. also I downloaded the pf config to do it online but can't really buy anything right now it's not free. Also I\m not good with computers but eMule my only entertainment right now. Thank u. I don't know if u need this: TCP port i'm trying to open for eMule :5803 UDP; 26387.
