Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Evap fan stoped running
Checked motor ,it runs fine no power is going to it, i am an hvac tech compressor is working fine, i have power at the 3 and 2 terminals on defrost control
  • 700 Answers
There is a thermostat that closes when the coil gets to a set temperature and that brings on the fan. That way the fan does not blow warm air into the refrigerator. Simular to the time delay on the blowers on high efficency unit. By the way I'm a HVAC/R Technician too. Thanks for using FixYa.
Posted on Dec 26, 2008
  • 42 Answers
Some of those fan motors will not run unil the defrost thermostat has closed.
Posted on Dec 22, 2008
How does a side by side domestic fridge work
Freezer one side, refrigerator the other side. Compressor is in the bottom at the rear. Often ice and water dispensers in the door.
Jan 23, 2016 | Refrigerators
Replace compacitor on Carrier 5 ton 3 phase AC
Your 3 phase unit should not have a capacitor. I'm guessing it's single phase. If it's a single capacitor than the compressor should not be going to it also. To test the motor, common to start plus common to run should equal the ohms you get between start and run. For instance, 1.2 ohms+ 2.2 ohms= 3.4 ohms. Follow the wiring diagram on the inside of the door, send model number!!
Aug 29, 2017 | Carrier Heating & Cooling
My air conditioner has stop working its blowing air inside but the fan is not spinning outside .....
If the fan is not running is the compressor not running also...if neither is running the possible reasons are 1..no power to outside unit...2..bad contactor on outside unit.is this buzzing if it is this indicates no power...3 bad capacitor,do both compressor and fan humm then quit humming and hum some more...4 high pressure switch has shut unit down because fan wasnt running if compressor was running but not fan....if your unit has this there will be a manual reset button where the lines come out of unit...if compressor was running and fan was not...1 bad fan...2 bad capacitor.. if you do not have any electrical knowhow i would recommend calling a hvac tech to come and fix unit...Thanks
Feb 01, 2011 | Samsung AS18A6RB Air Conditioner
My condensor fan hums but it will run if i give it a little turn. The motor is free but seems hot after running for 5min. The compressor it warm but lines out are not hot or cold for evap side and coil,
Start by shutting the unit off, before any more damage is done. Locate the run capacitor for the fan. It is a silver colored can, typically with two wires coming off the terminals. (sometimes 3). Mark and record the wire locations. The capacitor will have a part number and will be marked either 370VAC or 440 VAC and will have a rating in microfarads.
Bring the capacitor to an electrical or HVAC supply house and get an exact replacement. Install the new capacitor, close the unit up and re-power. If you are lucky, the fan will run, as normal. If not, you'll have to replace the fan motor. Capacitors are cheap, so, in my opinion, it is worth a try.
Jul 20, 2010 | Goodman CKL30AR30 Air Conditioner
Compressor works, fans not working, ice maker not filling with water. what is wrong
several things could cause this 1 not coolind evap caused by freon leak evap needs to get cold before fans run most modles 2 bad fans 3 im wont fill untill it reaches about 10 degrees you may need service tech sorry
Jan 29, 2010 | Freezers
HELP!!__CALLING ANY GE FACTORY TECHS
You say " all thermistors check fine " , how did you check them ? Did you check for the 5-8 DC volts at the main control board , for the thermistors ? Did you do the diagnostic check for the thermistors from the control panel ? I'm sure you know there are 5 thermistors , since the refrig has the dual evap . Possibly the # 5 is bad , since it is the freezer temp " controller " , yet if it tells the board it's not cold enough , it still sends refrigerant to the refrig evap . Since the refrig evap has 2 fan motors , can't remember if there is a damper there also . Maybe when the # 3 thermistor is satisfied , it only cuts the fans off , even though refrigerant is still going thru the refrig evap .
Oct 31, 2009 | GE Profile PSH23PGT Side by Side...
Fan in freezer not working
It runs when the compressor runs except when it's in the defrost cycle. If you have an electronic control instead of a defrost timer the control could be the problem since it runs the fans. You can test the evaporator fan. See how here> How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 21, 2009 | Arctic Air 22 cu. ft. Commercial Freezer...
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
67 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
