Question about Toshiba TP50H60 50" Rear Projection Television
Every so often my television screeen picture shrinks to a poin where the picture is squished. it usually lasts until I turn the TV off and turn it back on. Same issue with mine. It started where the top and bottom of screen would bow in a little. That would come and go for several months. Now in the last week or so I turn the tv on and it's fine for a few minutes and then it squishes down from the top and up from the bottom to about half the screen size and bowed top and bottom.
  • zb68730 Mar 25, 2009
    I recently bought a TP50H60 toshiba that has the same problem (hooray for craigslist!). When I pulled the back off there was an excessive amount of dust. I assume this hasn't been cleaned since it was made in July of 1998. Could the dust cause this problem alone or will I still need to use the same fix?
  • 233 Answers
Your screen has gone crazy on you because your convergence IC's have gone bad.   These IC's operate at a very high temp, and usually only last 4-5 years.
If you remove the back of the set, you will want to look for the BIGGEST heatsink in there, on that heatsink, you will see 2 lage IC's , probably STK392-110, or STK392-120's or something close...regardless - you can go on ebay to order the new ones, but MAKE SURE they are Genuine SANYO IC's and not counterfiet cheapies. the cheap ones may only last 2 months..
You will also need some "Heat transfer paste" - you can pick this up at radio shack.   Once you remove the old IC's, test all the large resistors near them.. pull one side of the resistor out of the board so you can check it out of circuit. they will usually have the value in Ohms, printed directly on the resistor, but you may have to use the resistor color code to find out what value they are....However, usually if there is any damage, the resistor will look like it has been HOT or fried. replace the IC's and any bad resistors, and you should be good to go.   If after replacing the IC's and any defective resistors, the convergence is still bad, make sure to use a multimeter to check ALL fuses on the boards, --- sometimes when the IC's go, they will take out a fuse to the convergence power supply. If you find any bad fuses, replace them accordingly!   If this STILL doesnt make it look right, you will need to find out how to get into service mode and do a coarse convergence adjustment. This information can be found in the Service manual for your set. If you dont have one you can download it at   Hope that helps!
Posted on Dec 22, 2008
Philips Magnavox 9P6031C103 projection tv quit working 2 years ago (before, the picture began to shink and expand until it finally quit completely with no audio nor video -- turned it on two years later to...
Based on what you described I would say your TV has the "shrinking and expanding" fault. Its a common problem on that model and the symptoms can range from the video shrinking and expanding or no video or no audio....You can read more about this fix on the site
Jan 13, 2013 | Philips Magnavox 9P6034C 60" Rear...
Hello, I dont have a solution but I am experiencing the same problem. Did your tv get fixed ? Any solutions that you can offer ? Rudy
Jan 13, 2010 | Philips Magnavox 9P6034C 60" Rear...
No picture, last night color was going away, then today no picture
If your TV is shrinking and expanding you can get a repair kit from for less than 50.00
Comments: May 19, 2009- If your TV is shrinking and expanding you can get a repair kit from for less than 50.00 May 22, 2009- Here are the most common symptoms and example photos of this problem.
  • Video Shrinks and Expands - Over and Over - After warming up it typicaly works.
  • After a few weeks the shrinking stops and you loose all video and audio.
Its a fairly easy DIY job. Check the site
Their kits include a photo instruction guide, parts, email/phone support, etc.
Nov 26, 2009 | Philips Magnavox 9P6034C 60" Rear...
Picture problem
This is a common problem with this TV set. You can get the parts, chips, and instructions to fix it your self from
Aug 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture shrinking
This problem can be repair, its only the vertical sect..have defective capacitor or lose/cold solder. by resoldering the area sometimes will solve this.
Jun 09, 2009 | Zenith IQD61W20 TV
Picuture shrinking color fading
I have the same Tv.. Repair tech said it was the deflection board. Cost $395.00 to repair.
Feb 28, 2009 | Philips Magnavox 9P6034C 60" Rear...
The Picture on my Mitsubishi vs-60805 "shrank" then disappeared
it isnt worth it, your verticle diflection is out, that board is about 3-4 hundred, and you would probabily need a service center do it(messing with like 30000 volts)and they will probabily charge around 200
Jan 07, 2009 | Mitsubishi VS-6041 60" Rear Projection...
32 in ILO tv, goes blank
Usually the blue screen is an indication that the video signal to the TV is not present. Most of the new TV's have a video input selection button on the TV and on the remote; try changing the video input selection.
Apr 27, 2007 | iLO 3200 32 in. LCD Television
Televison & Video Logo
124 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
