Question about PfaFF Creative 7570
My Pfaff 2140 giving message main motor blocked.
My Pfaff 2140 was working fine today when out of the clear blue, without any lockups from threads, I got the main motor blocked message. However, the machine will prepare for various stitches until you push the foot feed and then I get that message. I would have thought something might have the bobbin threads tangled, etc. but not the case. The wheel will turn. Is there anything I can do without having to call an out of town technician and take the machine to be looked at? I suspect it is something simple if I only knew what to try.
Thanks, PKD
  • rjsheese Feb 01, 2009
    I have the same problem. No tangled threads. When the needle descends, it seems to be hitting the bobbin case. Can successfully do a straight stitch or a zigzag, but none of the other fancy stitches without getting ther error message.
  • Anonymous Feb 25, 2009
    Exactly as you stated - out of the blue "Main motor blocked" message and upper thread is being caught on something in the lower thread block, instead of going through smoothly.
    I haven't been abusing the machine at all, last stitch I used was the triple "join" stitch and the fabric was canvas, not too thick. I don't get it!
  • 4 Answers
I have gotten the main motor blocked message several times. When I get this, I always remove thread, both top and bottom. I change the needle too. 75% of the time my problem goes away. If the problem is not solved, I unscrew the casing in the front of the bobbin, and look for anything that might be obstructing the bobbin. While I've had lots of "blocked motor" messages, I've never had to get a tech to ook at it. Sometimes, if you leave it overnight too, the sewing machine fairy will change something and the problem will solve itself in the morning. Re-thread, re-bobbin, re-needle. to start.
Posted on May 27, 2009
RickE1
  • 202 Answers
SOURCE: upper thread getting tangled in the bobbin
Always remember T-N-T. Thread, Needle, Tension. Assuming its threaded properly, is the needle all the way in and facing the right direction? These symptoms also suggest the bobbin may be in the bobbincase upside down thus turning in the wrong direction. Hope this helps.
Posted on Aug 23, 2007
  • 192 Answers
SOURCE: my bobbin keeps getting tangled up when I sew
Take the thread out of the top and bottom and turn the handwheel by hand to see if the machine will rotate smoothly.
Rethread, making sure that the thread is in the bobbin tension slot and that the upper thread is in the tension and the take up lever.
Sorry for the delay in response. I just found the sight this evening.
Posted on Nov 14, 2007
RickE1
  • 202 Answers
SOURCE: Timing is off on my Pfaff 2140/2170 machine.
Basically on any sewing machine to time it you will need to separate the two gears that drive the hook. Usually loosen the set screws that attach the gear to the shaft and separate them.
Time the hook first. On center needle position, set the hook so that the point is behind the needle when the needle bar has risen about 2.5mm.
2) Set the needle bar height. Choose the needle position which is the last for the hook to pass.
(Left on most machines, right on older Vikings) At this point, place the point of the hook behind
the needle and set the needle bar height so that top of the eye is just barely below the tip of the
hook.
3) Check feed timing. Set the stitch length to the longest stitch. The needle should enter the
fabric just as the teeth drop below the surface of the plate.
Posted on Dec 20, 2008
SOURCE: bobbin thread bunches up creating a tangled mess under the plate
This could either be due to the bobbin being wound too loosely, or the tension on the top thread is too loose. This just happened to me the other day, and I thought it was the bobbin thread, but then I put another bobbin in with a different color than the top thread (this is a huge help in diagnosing thread issues), and I was surprised to find that it was actually the top thread that was a big loopy mess on the underside of the fabric. I fixed it by tightening the tension on the top thread (quite a bit), and everything was fine.
Posted on Jan 23, 2009
Mimito7
  • 128 Answers
SOURCE: Tension Problem on Pfaff 2034, bobbin loops
Rule of thumb.. Loops on the bottom, problem on the top. Loops on the top, problems on the bottom.
Set your upper tension at 4, and rethread the machine from the top. Just before you thread the needle, but the presser foot down. If the thread pulls right thru easily, then the thread is not thru the tension wheel right. Because, if you can't pull the thread thru with the presser foot down, you have it threaded right.
Posted on Apr 25, 2009
I have a Pfaff embroiodery machine. I was embroidering a name and all of a sudden got the message main motor blocked wghat should i check to fix this problem? message
There are many excellent sewing machines, and Pfaff is one of the best. Ergo, the company will answer any question! Online........
Jan 22, 2018 | PfaFF Sewing Machines
Pfaff 2170 main motor blocked;Tried again, same message. It works fine for five or 10 minutes, then stops and message comes up. after overnight rest, same thing happens. tension, cleaning is fine.
Take it back where it was serviced and tell them they did not fix the problem. They should either repair it or give you your money back. If the motor is having issues, there could be something seriously wrong.
Mar 19, 2017 | PfaFF Sewing Machines
Why doesn't it communicate with my Pfaff 2140?
sounds like there not compatable, have you checked with pfaff technical support about the problem,
here's their number
Toll free assistance - 1.877.746.4375
here is a link for their support page
Machine Support
Mar 22, 2016 | PfaFF Creative 7570
Keep getting check upper thread message
You have left threads in the thread path that you can't see or get to without a technical knowledge of the necessary "cleaning process"
Go and see your machine repair man who can show you how to get to the problems areas without messing up the mechanicals even more.
Feb 01, 2014 | PfaFF Sewing Machines
I have a 2140 updated.. Main motor block message appers and its not blocked.
Sounds like, Burned out motor bearings.....QUit using the machine and have it properly repaired by an authorized repair technician.
Jan 28, 2014 | PfaFF Sewing Machines
Blocked motor message for 2140. Has happened 3 different times. Sewing machine repair is two hours away and I need my machine today. I did all the thread things suggested with the bobbin, re threading,...
You said the hand wheel barely moves. Is that all the time? If the hand wheel is hard to turn the motor is getting overloaded and is protecting itself by stopping and giving you the error message. You need to determine why the hand wheel is tight. There could be thread caught or something might need lube. These are non oiling needed machines however sometimes a linkage might need fresh lube.
Sep 12, 2013 | PfaFF Sewing Machines
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
Sep 26, 2012 | Sewing Machines
Pfaff 134 thread unravels
try changing the needle--make sure to use every thread guide
try a different thread
check for any burrs on the needle plate or on the bobbin case
clean under the needle plate & in the bobbin area for lint or loose
threads
Aug 16, 2012 | PfaFF Sewing Machines
My pfaff 2170 says "main motor blocked" how can I fix this?
It happened to me... Check the bobbin and thread in the shaft ... Pull out the bobbin and remove all thread from the shaft. Pull out any thread remains with the tweezers. Check the feeder dogs and the needle (see Owner's Manual 2:7). Re-insert the bobbin (see Owner's Manual 2:12).Make sure that you use a good quality thread and set everything up correctly. Good luck!
Sep 09, 2010 | PfaFF Creative 7570
hook.
Dec 14, 2008 | Sewing Machines
Sewing Machines Logo
1,425 people viewed this question
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
