Question about Maytag MER6769 Gemini Electric Kitchen Range
Same oven - Maytag Gemini- won't shut off
I purchased a Maytag Gemini in April of 2008. In Sept. we began to experience problems. The Upper oven would not shut off. We had the control board replaced, but it is beginning to do it again. It is now Dec. of 2008. I have visited consumeraffairs.com and I can't believe the problems with this stove. Maytag is not what it once was. We are seeking legal advice.
  • Anonymous Jan 27, 2009
    the oven wont turn off!!!#!@#!@#!#!@
SOURCE: Maytag Gemini stove with the f-1 and f1-2 problem
your lower oven temp sensor is bad. part # 12001656
Posted on May 15, 2008
  • 415 Answers
SOURCE: Maytag Gemini Stove Code F1-4 (bottom door won't open)
F-1 error is a Temperature Runaway. It Maytag's way of letting you know that oven overheated. Nothing you have done but it may have shorted out the oven sensor or the keypad. Check the sensor and see if it's closed. If it's okay, replace the keypad.
Posted on Oct 25, 2008
SOURCE: Maytag Gemini gas top oven does not work.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}I had the same problem, same symptoms...
You probably need to replace the baking igniter, (Igniter,bake burner
Part Number: AP4102011 made by MAYTAG).
I tested the igniter function by (CAREFULLY) jerry rigging a bridge to wire the BAKE igniter to the BROILER controls. (Push/click plugs accessible by opening up the stove back) Testing the broiler controls this way the bake element remained cold. I then did the same test but connected the BROILER igniter to the BAKE controls and got a good glow. This indicates that the controls work but the Bake igniter's faulty!
You can access the bake igniter by removal of 2 screws at the front at the platform just inside the top oven. The broil and bake igniters appear to be identical but the push/click plugs are reversed at the back of the stove. (hence the CAREFUL jerry rigged wiring bridge.) The parts and wiring are pretty simple and visual once you get the covers off. Opening up the stove back is just a matter of removing several screws. UNPLUG the stove before you work. If you test as I described, make all connections while UNPLUGGED and then plug it in only for the brief test. Unplug again while disconnecting/reconnecting. Hope this helps.
Posted on Dec 04, 2008
SOURCE: Purchased at Maytag Gemini MER6770 in 2000. It
Sounds like the cancel (or stop) button is making contact by itself. Clock (oven control board) may need replacement.
One option to buy it new, your part number is 12001661
Coupon "New10" chops 10% off.
Another is to send the clock to be rebuilt. Google "stove timer rebuild", you'll find plenty of companies which can repair your original clock. In case you need it, the original part number is 74004542.
To get to the clock, remove the back of the control panel. Good luck.
Posted on Oct 25, 2009
blueextc3221
  • 15935 Answers
SOURCE: Maytag Gemini mer6770aw
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Maytag gemini electric ignition won't shut off
Your valve switches are defective. Sometime they will do that if you recently had a boil over and they have got wet. Try turning the breaker off for 24 hours to see if the fixes the problem.http://www.on-timeappliance.com/ovenrepair.html
Mar 27, 2012 | Maytag Gemini 30" Self-Cleaning...
Getting a F1-4 error code on my Maytag Gemini model # 6772. Came home to the upper oven at full heat with the control panel beeping. Extremely dangerous situation where the oven would not shut off at the...
Hi greg_shanoia,
The F1:-4 error code means "Runaway Clean Lower oven". You need to check the oven temperature sensor, replace if necessary.
Hope it helps.
Thank you for using FixYa.
Sep 21, 2011 | Maytag MER6772 Gemini Electric Kitchen...
The oven shuts itself off after preheating.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jun 03, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Range displays error code f9-5
HI. This indicates that there are serious issues that concern the operational value of the main control abord(ERC/Clock).
This will require you to replace the ERC, asap.
ERC_(Electronic Range Control Board)
F9-5_Hardware conflict(watchdog)
Nov 08, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Oct 24, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini Dual Oven MER6772BCA
sounds like the broil elemnt in the upper oven is shorting itself out part number 74004106, probly 45 bucks. leave the circuit off adn replace it... the wire(s) leading to it are always live.theres a few screws across the top of the cavity holding it up
Apr 09, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Gemini electric oven
Well my friend these type ovens have eyes and sensers. It could be that you left something on the sensor when you were cleaning it. That is if it is not self cleaning. Self cleaning gets real hot and could affect your appliance in some way. It shouldn't but it might.
Aug 06, 2007 | Maytag MER6772 Gemini Electric Kitchen...
Maytag MER6769 Gemini Electric Kitchen Range Logo
278 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
